| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Glorious BRZ Master Race
Drives: Subaru Libird
Spare Tire Specs
Anyone know the width and offset of the OEM spare tire? Did a quick search, couldn't find anything, maybe I have to search harder when I have more time. Want to approximate a spacer size I'll need to fit it with my BBK.
#2 |
Country Boy 4 Life
What size spacer is needed to fit a stock 17x7 with your BBK? I think it would be the same size spacer to make the spare fit.
Edit: Been thinking about this. Two things. 1. A 25mm or 30mm bolt on spacer should work. 2. The spare is going to be smaller diameter than your upgraded tires. Meaning if you get a flat on the rear, you should move a front wheel tire to the rear and put the spare on a front non-drive axle wheel. Different diameters are bad for the differential. Last edited by Leonardo; 11-28-2016 at 06:16 PM. |
#3 |
What spare tire?
#4 |
Senior Misanthrope
I don't have a full answer for you, but I can say the stock spare + 15mm spacer does NOT clear the AP sprint kit.
| The Following User Says Thank You to kch For This Useful Post: | Leonardo (11-29-2016) |
#5 |
Drives: 2014 GT86
Stock spare was 16" or 17"? IIRC from few threads about space-saver spares there was also one 17" subaru spare that fit, maybe it may increase chances of BBK clearance?
#6 |
Called Subaru of America and they recited info from the users manual: 16x4T (not sure what T means), no offset info. Going to figure a needed spacer size from my BBK fitment template.
| The Following User Says Thank You to switchlanez For This Useful Post: | Leonardo (11-30-2016) |
#7 |
Off Topic
Can your BBK even fit in a 16" wheel, or will you need to push the wheel far enough out that the BBK completely clears it?
What about a 2004 (5x100) STI spare wheel? Those can at least clear the STI brembos, so they'll have a better chance of fitting your BBK. You could probably find one on eBay or NASIOC fairly cheaply. |
#8 |
Drives: 2014 GT86
T is just like "J", rim contour / tyre bead profile shapes.
| FS: OEM Spare Tire | zeal86 | Wheels and Tires | 7 | 12-08-2016 09:37 AM |
| WTB: Spare Tire | kanundrum | Want-To-Buy Requests | 2 | 11-15-2016 11:30 AM |
| Replace Only 1 Tire? / Spare Tire Question | chermo12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-28-2015 01:44 PM |
| Spare tire | ??? | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 09-28-2014 06:46 PM |
