junior mafia
Drives: ‘20 sti limited
header swap vs. my 'green' side.
im thinking about installing an uncatted jdl uel header while keeping the rest of the exhaust stock. excited about the potential for a bit of subie rumble and the pickup in midrange and high end grunt but the eco friendly part of me is curious if the stock cat on the front pipe does any decent job of filtering out exhaust pollutants? don't know if anyone has explored that at all or actually tried to bring their similarly setup car through a sniffer test to see.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
#2 |
Drives: frs
Go catless and let your grandchildren deal with the pollution. If you keep all exhaust components stock, will be quiet anyway
| The Following 7 Users Say Thank You to Teseo For This Useful Post: | -Phil (11-28-2016), aagun (12-06-2016), D_Thissen (11-28-2016), gramicci101 (11-28-2016), meWant (11-30-2016), Reggaeboyz (12-01-2016), sugoi (11-28-2016) |
#3 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Not gonna lie, I have thought about the environmental effects of being catless. Some times I think about putting a catted header on too, but I enjoy the sound and power of a catless header too much.
| The Following User Says Thank You to weederr33 For This Useful Post: | perryair (11-28-2016) |
#4 |
Drives: 2005 Toyota Camry
The biggest part of the pollution will be when you first start the car. At cold startup, you're basically polluting about the same as a car from about 20 years ago before OBD-II.
After cold start you should have same tailpipe as a normal car and should pass tailpipe emissions should it be needed. -alex |
| The Following 2 Users Say Thank You to mav1178 For This Useful Post: | Mr.Impreza (11-28-2016), strat61caster (11-28-2016) |
#5 | |
junior mafia
| The Following User Says Thank You to perryair For This Useful Post: | sato (12-04-2016) |
#6 | |
Aftermarket header/OP/FP systems with a high-flow catalytic converter emits less tailpipe than stock. Apex'i and HKS are two companies that offer this setup. -alex |
| The Following 3 Users Say Thank You to mav1178 For This Useful Post: |
#7 |
Drives: Honda Accord Euro
#8 | |
Drives: 2014 Subaru BRZ Ltd.
But as others have stated, the real problem is the warm-up period. Even if you could move the O2 sensors back and replace the secondary with a three-way, it would still take significantly longer to warm up.
*question everything*learn something*answer nothing*
#9 |
Because compromise ®
Drives: Red Herring
I'm not sure about that. I had JDL catted header and catted front pipe (200 cell cats) and my car failed emissions test here in Aus.
#10 |
Drives: Late 2014 Subaru BRZ
Either install a header the car is dieing for or sell it and hug some trees with a Prius!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#11 |
Mr.Fujitsubo
Drives: 2018 STI
If you care about the environment and don't want smell just leave at least 1 cat in the car.
In my 2002 Subaru WRX, we have 3 OEM cats. I removed all 3 and just had 1 200Cel cat in my downpipe. Had no smell and no issues. For this car I'd suggest Catted Header + Catless Front Pipe.
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() Last edited by Mr.Impreza; 12-06-2016 at 10:59 AM. |
#12 |
Drives: 2017 BRZ
Well, if you believe in government subsidies and the mess it creates to grow as much corn... which may still be better than gasoline, mind... try E85 for a greener burn.
And keep your eyes out for an available Tesla roadster. |
#13 |
junior mafia
murica. bikinis. beer. football. powar. giggity.
thanks for the constructive input, those with it. i never knew about 2 vs 3 way cats and i guess just having the stock front pipe is something im comfortable with after the research.
#14 | |
Senior Misanthrope
| The Following User Says Thank You to kch For This Useful Post: | G-awesome (12-05-2016) |
| Side Grill Swap | JetSpeed | BRZ First-Gen (2012+) — General Topics | 3 | 05-15-2016 04:15 PM |
| Green wire on passenger side seat | Ryaquinn | Electronics | Audio | NAV | Infotainment | 3 | 11-18-2014 09:17 PM |
| Replacement windshield with "green tint/green shade" | extrashaky | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-07-2014 11:02 AM |
| SWAP GTS86/FRS Side Vents for BRZ | GTS86 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-23-2013 03:01 AM |
| Side Vent Swap? | Allankh | CANADA | 0 | 12-19-2012 02:26 PM |
