Old 11-07-2016, 08:36 PM   #15
ort895
ort895's Avatar
Will be taking my car to Subaru this Wednesday morning, I'll update then.
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
The Following User Says Thank You to ort895 For This Useful Post:
Ultramaroon (11-07-2016)
Old 11-10-2016, 12:16 AM   #16
ort895
ort895's Avatar
Brought my car in around 9:40am today. They ended up calling Subaru Tech Service around 4 and never got a call back so I'll have to make another appointment to leave my car there. They will be giving me a loner car Incase they do actually find anything wrong.
At this point in time they think it's an upper valve train issue.
Ultramaroon (11-10-2016)
Old 11-23-2016, 01:12 AM   #17
ort895
ort895's Avatar
Update
They think its actually a bearing in my brake vacuum pump going bad so they are going to be replacing that on "goodwill". Bad news, the part is back ordered till the end of January so i will be giving back the loaner car (2017 forester...actually pretty sweet) back until they have the part in.
Old 11-23-2016, 10:36 AM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I have that same noise. Been that way for 60,000 kms but it has gotten slightly worse.
Old 11-23-2016, 10:39 AM   #19
ort895
ort895's Avatar
I'm just glad it's not an issue with the actual engine block, or at least they are pretty sure.
I probably wouldn't push the repair but they are going to cover the repair cost so
go_a_way1 (11-23-2016)
Old 11-23-2016, 10:50 AM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yeah I wonder if my dealer will cover it for me even though I am slightly out of warranty. Too bad the parts on back order. I wonder if this issue is why my car is making slightly less vacuum then it should cuz I was having issues getting the BOV to open I doubt it though haha everything runs fine
Old 11-23-2016, 10:52 AM   #21
Ya. Take your car in and ask for work out of warranty. I dare you! Video the look on the guy's face when he opens the hood though.
go_a_way1 (11-23-2016), ort895 (11-23-2016)
Old 11-23-2016, 12:18 PM   #22
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
bahaha!! yeah that's the catch it doesn't even look like a FA20 in there anymore. Hell I think I will take it in just for shits and giggles so I can see the reaction I get from the staff
Old 11-23-2016, 08:28 PM   #23
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
You both have 13s, 13s have rocker issues if i see all the time on here. Get it fixed bro, dont shoot out a rocker arm
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Old 11-23-2016, 08:30 PM   #24
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Its not a consistent clatter like a rocker would be. It comes and goes too
Old 11-23-2016, 11:16 PM   #25
ort895
ort895's Avatar
Going to get the pump fixed and go from there.
go_a_way1 (11-24-2016)
Old 03-14-2017, 11:27 AM   #26
ort895
ort895's Avatar
Alright boys and girls, its time for an update. The part finally came in and i had it installed by Parkway Subaru in Wilmington NC. They actually put it in for free for me because when i originally had the car being looked at i was just outside of warranty range, so i just want to give a big shoutout to them as they have always looked out for me.
So the actual part that they replaced was the Secondary air pump, creates a vacuum at idle and all that jazz.
Did it actually work? Well yes, the noise has completely gone away and now i can breathe again knowing its not a valve train issue or anything like that.
The Following 4 Users Say Thank You to ort895 For This Useful Post:
DarkSunrise (04-09-2017), Kimsey47 (03-14-2017), Tcoat (03-14-2017), Ultramaroon (03-14-2017)
Old 03-14-2017, 02:14 PM   #27
Is it an automatic?
edit: nvm. I see. I think it's that cam-driven pump on the right side.
Old 04-09-2017, 02:32 AM   #28
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
I have the same issue as well. By secondary air pump do you mean the vacuum pump in the Automatics? thanks in advance
shaynek is offline   Reply With Quote
Transmission knock tofurun Engine, Exhaust, Transmission 7 07-08-2016 06:45 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 10:39 AM
Oft knock brady86 Software Tuning 26 07-15-2015 11:14 PM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 05:12 PM
