Old 11-16-2016, 12:33 AM   #197
Reamer
Drives: 2015 FRS
Originally Posted by byun View Post
There is a check box on the flex fuel kit page to add the upgrade...
Reamer is offline   Reply With Quote
Old 11-16-2016, 12:35 PM   #198
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Reamer View Post
If you'd like to add the Mark 1 +, we can always accommodate that when you arrive.
-Zach
Old 11-16-2016, 12:39 PM   #199
Reamer
Drives: 2015 FRS
-Zach
Haha, I wish I was having the work done by y'all but I'm in Texas and I'm going to PRT Performance. I'll just get the +1 and have it added when I put on my JRSC in a couple months.
Sent from my HTC 10 using Tapatalk
The Following User Says Thank You to Reamer For This Useful Post:
Old 11-16-2016, 03:40 PM   #200
DeliciousTuning
No worries; I'll be happy to help whenever you're ready!
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Reamer (11-16-2016)
Old 11-19-2016, 08:05 PM   #201
Reamer
Drives: 2015 FRS
Thanks to PRT Performance, @pleong, @DeliciousTuning, and @CSG for everything it took to get my car moved over to flex fuel, and the oil cooler/radiator combo from Jackson Racing installed the other day. Still had some 93 in the tank so I'm sitting around e60 right now but the added torque is definitely noticeable and it pulls harder through the power band. The ACE/FF tune from delicious drives like it is OEM and while I may notice some details I want changed down the road, the initial impressions is no complaints whatsoever.
Sent from my Pixel using Tapatalk
The Following 2 Users Say Thank You to Reamer For This Useful Post:
pleong (11-21-2016)
Old 11-23-2016, 01:14 PM   #202
vgi
Drives: frs
@Delicious I'm sorry, just couldn't pass by, thought it's funny
first post
vgi is offline   Reply With Quote
The Following 2 Users Say Thank You to vgi For This Useful Post:
DeliciousTuning (12-04-2016)
Old 01-08-2017, 08:27 PM   #203
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
@DeliciousTuning
@sales@delicioustuning.com
Speaking as far as ECUTEK, this is kind of a technical question. But does FlexFuel kit report as the ( O2 1x2 v ) reading from 0v to 5v? The app is reporting 8% and the same PIN is reporting 0.4v, the rear O2 voltage is reporting 0v no matter what. The box does have a green flash light as well.
I want to make sure its not defective.
If my math is correct 0.4v of 5v = 8%
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-09-2017, 09:25 PM   #204
DeliciousTuning
Originally Posted by GsxrMe View Post
@DeliciousTuning
Mk 1 kits operate on a 0-5V scale for 0-100% ethanol content. Mk 1+ kits operate on a .5-4.5V scale for 0-100% ethanol content.
Hope this helps!
Sincerely,
Zach
Old 03-23-2017, 03:25 PM   #205
byun
byun's Avatar
Drives: 2015 BRZ CWP
Hey Zach, any updates on the app for iphone?
byun is offline   Reply With Quote
The Following User Says Thank You to byun For This Useful Post:
CA86GRL (03-23-2017)
Old 03-23-2017, 03:51 PM   #206
CA86GRL
CA86GRL's Avatar
Drives: 2016 FRS
I second that. I'm bringing my FRS in on the 3rd..
CA86GRL is offline   Reply With Quote
Old 05-09-2017, 07:55 PM   #207
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Is there any effect to long term fuel trims with the rear O2 taken out of the loop?
Old 05-09-2017, 10:28 PM   #208
steve99
Drives: FT86
If your using rear 02 for flex input, the tuner dudes will disavle the rear o2 compensations and any cel codes associated with rear o2 so all will be fine
The front o2 is the one use for fueling
Old 05-10-2017, 11:24 PM   #209
Yoshoobaroo
TRACKBREAD
I know, but the rear O2 sensor is used to affect long term fuel trims. That's why Ecutek recommends disabling LTFT when eliminating the rear O2 sensor.
Old 05-11-2017, 12:14 AM   #210
VABeachBRZ
Do you guys know if the Apple Store is getting the DT ethanol app?
VABeachBRZ is offline   Reply With Quote
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 09:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 01:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
