Old 11-10-2016, 12:22 AM   #1
Amputechture
Drives: 2014 BRZ
Amputechture
Greetings! Owner since June 6th of 2015, it's been a blast. Prior owner of an SW20 Mr2 Turbo.. Most of my photos are older, and they are scarce. I'll be updating this here shortly.
2014 Subaru BRZ Premium
Engine
JDL Single Scroll Turbo Kit
Garrett GT2860RS .82 AR V-Band discharge
Tial MVS External Wastegate
Tial Q BOV
JDL Fan Shroud/SPAL slim fans
Infamous Performance 3 Port EBCS
Ecutek RaceRom ECU, tuned by James M/HRI
OMNI 3-BAR MAP Sensor
DEI Turbo Blanket
DEI Titanium Wrapped Downpipe, Manifold, Overpipe
JDL Equal Length Turbo Manifold
JDL 3 Inch Downpipe
Tsudo 2.5 Overpipe
Berk 2.5 HFC Frontpipe
Greddy Supreme SP Catback
K Motor Dual VTA Catch Can/PCV Delete
FA20DIT Oil Cooler
Prosport Boost Gauge
HKS super fire spark plugs
DriveTrain/Suspension/Wheels/Tires
Exedy Stage 1 Clutch
STI Motor Mounts
KartBoy Transmission Insert
Whiteline Differential Outrigger Inserts
Whiteline Positive Traction Kit
Perrin rear shifter bushing
Pentosin Trans/Diff Fluid
Winmax W2 Brake Pads
17x9 35 Enkei RPF1 Gunmetal
245/40/r17 Continental ExtremeContact DW
RSR Superdown Springs
SPC Camber Bolts
SPC Rear LCAs
Exterior
Toms Tail Lights
TRD Rear Spoiler
Helix smoked side markers
15% tint
Amputechture is offline   Reply With Quote
The Following 2 Users Say Thank You to Amputechture For This Useful Post:
Lonewolf (11-16-2016), swarb (06-28-2017)
Old 11-15-2016, 01:57 PM   #2
Amputechture
Drives: 2014 BRZ
Been getting some strange behavior at wide open throttle, it seems like right when full boost is reached my RPMS hang for a second before the engine speed begins to climb. Almost like hitting a soft rev limiter where ignition isn't cut, but doesn't increase. It does this for a split second and then carries on as normal. Tuner says I've maxed out the MAP sensor, also I'm hitting 90% duty cycle on the stock PIs. Anyone ever experienced this? Looks like I'll be going flex-fuel sooner than I thought :-).
Old 11-18-2016, 11:06 PM   #3
Amputechture
Drives: 2014 BRZ
At long last, installed RSR Superdowns, Enkei RPF1s wrapped in Conti Extreme Contact DWs, SPC Rear LCAs and SPC camber bolts. Also did some boost and exhaust leak testing for good measure, everything went okay except for my alignment.
https://s11.postimg.org/5t7w4fw83/20...31_resized.jpg
https://s13.postimg.org/shynitqcn/20...19_resized.jpg
https://s14.postimg.org/wdlgziqa9/20161116_133447.jpg
Before and After with old wheels from prior owner and stock suspension in the rear. No clue what the guy that had the before me was thinking.
https://s17.postimg.org/71txrd4rj/banda.jpg
So this is my before and after. My appointment was at 5:30 with the shop closing at 6. The guy made it very obvious that he was not happy about my car having to go on the rack and didn't hide it. Come to find out he did my alignment with my old wheels and tires in the back of the car. This guy must have had no clue what he was doing, my eyeball alignment was better with the exception of front toe. I am going to demand that they re-do my car, to me this is unacceptable. From what I have been told by countless people with firsthand experience, I should be able to be at -1.5ish Camber F/-2.5 Camber R with 0 Toe F & R.
https://s14.postimg.org/hukya0lc1/alignment.jpg
The car is super darty with the rear toe out and the turn in is ridiculously quick, not in a good way. On a brighter note, I am ecstatic with the new Conti ECDW's...my old Nitto NeoGens were getting lit up all of the time and I could not put any power down in first gear and if it were cold enough I could not hook up in 2nd either. They are extremely quiet and have a very refined nature. I haven't done much cornering or hard driving yet but I am enjoying the surprisingly compliant feel of the RSR springs. I was worried that they would be jarring and bumpy feeling but they are well matched to the stock dampers and I say with complete confidence that the car is considerably more comfortable than it was before this Saturday. In other news, my tuner turned the boost down a little because I was maxing out my MAP sensor and also hit 90% PI duty cycle in a 3rd gear log. No longer breaking up and running smooth. I really want to pick up a new MAP sensor to get that extra bit of kick back...but my sensible side is telling me to wait until I'm ready to jump to flex-fuel to do so being that I'm taxing the factory fuel system.
Old 11-26-2016, 01:30 AM   #4
Amputechture
Drives: 2014 BRZ
Got another alignment today:
-1.8 FL Camber////-1.9 FR Camber
-0.08 FL Toe////-.07 FR Toe
-2.0 RL Camber////-2.1 RR Camber
0.12 RL Toe////0.08 RR Toe
Car has loads more grip and feels exponentially more stable in pretty much every situation. Should I be worried about the amount of Toe in that I have in the rear in regard to tire wear? I requested 0.05-0.08 Toe in Rear.
Old 12-19-2016, 07:15 PM   #5
Amputechture
Drives: 2014 BRZ
Old 04-12-2017, 02:09 AM   #6
Amputechture
Drives: 2014 BRZ
Update: Had the car re-tuned a couple of months ago by Bob Richards (Circuit Motorsports). Put down 289/225 on a Mustang dyno. I was told stockers read at 156 or so on these particular rollers, so I should be a **** hair or two above 300. It was a bit of a stressful and rushed situation towards the end. Bob started street tuning the car at 11 AM and we visited King's Performance around 3 to use their dyno. There was a guy with a Cayman waiting to get tuned and by 9 PMish both him, his tuner, and the shop owner pretty much told us we had to wrap it up. The Porsche owner had driven up from Ft Myers...much further than I had traveled so it was the right thing to do.
Pretty happy with the end result with the exception of the 3,500-4,000 area was absolute shit and the graph reflects it. Fortunately, Bob cleaned it up remotely and it feels better now. Part throttle is still meh.
I may go visit a Nissan guy that has a dynojet near me to see how things look after Bob's revisions...but I don't really give a shit about numbers so we'll see. Right now I'm completely satisfied with how she feels. Newborn keeping me busy too so trips to the dyno will be hard to come by for awhile.
The Following User Says Thank You to Amputechture For This Useful Post:
ShadowReaper (10-21-2017)
Old 06-28-2017, 11:19 PM   #7
Amputechture
Drives: 2014 BRZ
Tuned last week by James/HRI. My drive-ability was absolute shit on Circuit's tune, fuel trims all over the place. Feels like an entirely different car now...I'm making some real torque now and need a clutch pronto. Have an Exedy Stage 1 on the way.
Lonewolf (06-28-2017)
Old 06-28-2017, 11:45 PM   #8
Lonewolf
Lonewolf's Avatar
Drives: Moped
James is one of the best for sure!
Old 10-23-2019, 03:48 PM   #9
Amputechture
Drives: 2014 BRZ
Replaced the old journal bearing precision for a GT2860RS. Loving it.
https://ibb.co/0nsmX0b
https://ibb.co/C790TT8
https://ibb.co/PQ3Pppy
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
