Old 10-17-2016, 02:44 PM   #29
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Ya I thought we had it. At this point I think he needs to look elsewhere other than just focusing on tires. Could have a bad damper, improperly seated spring or any of a 100 other things with the modded suspension. We all got so wrapped up in the tires that we are totally overlooking many other possibilities.
Originally Posted by OP
About a week ago I swapped the rear wheels around and it starting pulling to the right rather than the left.
There are 2 possibilities. 1) OP is wrong and the pull didn't change sides 2) The OP is right and the pull did change sides therefore the suspension can't be the problem.
Unless when the wheels were swapped around they swapped the dampers too.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Ultramaroon (10-17-2016)
Old 10-17-2016, 02:53 PM   #30
Ahhhh I missed that line!
Shit, back to square one AGAIN.
Old 10-17-2016, 03:41 PM   #31
Originally Posted by Spartarus View Post
I just though he may have had some inside sides on the outside.
I suppose not. Back to square 1.
Not necessarily. We've clarified but the condition has yet to be verified.
I did as well. Thanks, guybo. If the direction of the pull follows a particular wheel, that's a strong indication of tyre mismatch.
OP, are all four of your tires mounted properly on their wheels? Are you absolutely certain they are all the same size?
edit: ok, a lot happened since my last visit. Meh, I summarized.
guybo (10-17-2016)
Old 10-19-2016, 08:34 AM   #32
Midjetv8
Drives: 2013 Toyota 86
All the dimensions and sized printed on the tyres is the same. Have it booked into a different tyre shop to get them to uninstall, check everything and reinstall the tyres. Shall report back if I have any luck! If not i'll live with it until I wear through them.
Midjetv8 is offline   Reply With Quote
The Following 2 Users Say Thank You to Midjetv8 For This Useful Post:
Tcoat (10-19-2016), Ultramaroon (10-19-2016)
Old 10-19-2016, 11:36 AM   #33
lupindub
Drives: Scion FR-S
Just an FYI even if the tires are directional and you mount it the wrong way, it won't make a difference performance wise in dry conditions. It only starts to get hairy when you get into wet/slippery conditions with directional tires being mounted the wrong way.
lupindub is offline   Reply With Quote
Old 10-19-2016, 11:49 AM   #34
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yeah in autocross, I'm told people run their RE71Rs backwards on dry days to even out the wear. No idea if it's okay to do, but I suppose that's a different circumstance than putting tens-of-thousands of miles on a DD tire.
Stang70Fastback is offline   Reply With Quote
Old 11-15-2016, 05:10 AM   #35
Midjetv8
Just a quick update, problem has been fixed. Swapping the front right and the rear left corrected the pull. Car feels mint now. Bridgestone tech couldn't give me an explanation as to why. But it works so it's all good!
The Following User Says Thank You to Midjetv8 For This Useful Post:
Ultramaroon (11-15-2016)
Old 11-15-2016, 09:35 AM   #36
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
Won't this be a problem again when you rotate your tires?
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
Old 11-15-2016, 10:30 AM   #37
Midjetv8
I'll tackle that hurdle once I get there. I'm just going to enjoy the car for a bit first.
Old 11-15-2016, 10:53 AM   #38
My guess is that even though the tires may not be directional they all still need to be mounted with the tread in the same direction. Swapping two opposite tires would have reversed the direction on both and now they match the others. There is nothing else it could have been.
Aggressively pulling to the left on acceleration sero901 Issues | Warranty | Recalls / TSB 39 01-12-2021 06:39 PM
Pulling up floor rug? ndsleep612 Cosmetic Modification (Interior/Exterior/Lighting) 1 12-11-2013 02:23 AM
Brz pulling trailer? subiesteve Southwest 7 11-20-2013 10:04 PM
94 octane not pulling Scalzo Forced Induction 44 10-08-2013 11:15 PM
Pulling your FRS off of the lot, what are you bumpin'?? poormans_LFA BRZ First-Gen (2012+) — General Topics 201 06-09-2012 10:52 PM
