Old 11-10-2016, 11:17 PM   #1
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Wierd Electrical issue - no windows + no trunk after battery replacement
Hello.
I just swapped my OEM battery into my 2013 Scion FRS in place of my lightweight battery so I can store the lightweight one in a heated environment on a trickle charger for the winter.
Now my windows do not move when I open or close the doors and my trunk does not work with my key fob or interior button. (I checked the disable button in the trunk.)
The only other thing I have done since everything was working is I have removed the carpet and seats to install my new fixed back seats.
Any ideas?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-11-2016, 12:00 AM   #2
Lorico
Drives: 2015 FRS
sounds like a dead battery, have you tried trouble shooting? using your old battery? then using a multimeter to check the new battery, etc?
try charging your new battery first?
Lorico is offline   Reply With Quote
Old 11-11-2016, 03:29 AM   #3
Like @Lorico mentioned ...... first make sure the battery is up to speed.
Then, I suggest you check the fuses.
Old 11-11-2016, 07:20 AM   #4
Takumi788
JHerbert Racing
Takumi788's Avatar
The battery is fine. The car starts and everything else works as usual. I had 12.5 volts with my multi meter. I checked a few fuses under the hood and under the dash with no luck.
Old 11-11-2016, 09:55 AM   #5
Where did you unhook all the wiring for the seats? Wouldn't think it would be related but the fact they stopped after doing that seems a bit more than a coincidence.
Old 11-11-2016, 11:00 AM   #6
Takumi788
JHerbert Racing
Takumi788's Avatar
Just the two connections from under the seats.
Old 11-11-2016, 11:06 AM   #7
Well that should rule that out then.
Won't help with the trunk release but have you tried doing the window reset?
Old 11-11-2016, 11:15 AM   #8
Takumi788
JHerbert Racing
Takumi788's Avatar
Embarrassingly no. It was late and I was on my way out of my shop when I realized the issue and just figured it must all be related. Troubleshooting rule number 1: never assume. I will do that tonight.
Car Audio Battery Replacement brzstormtrooper Electronics | Audio | NAV | Infotainment 0 03-23-2016 08:38 AM
oft windows issue help FISHBURGLAR Software Tuning 3 07-29-2015 02:19 PM
Replacement Battery slizoth Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-09-2014 03:04 PM
Car broken into - no replacement windows yet mrblue BRZ First-Gen (2012+) — General Topics 7 01-10-2014 02:59 PM
electrical issue? unichip and left led fog light not playing nice tracerit Software Tuning 2 10-07-2013 10:09 AM
