Old 06-08-2015, 11:53 AM   #99
SisterBlue22
SisterBlue22's Avatar
Drives: "Frances" - 2013 FR-S in Firestorm
For the record, my 2008 xB came set on the "tC" setting as well...I think that's just the default for everything.
SisterBlue22 is offline   Reply With Quote
Old 06-08-2015, 12:58 PM   #100
zman
zman's Avatar
Drives: scion frs
So all scions have the same head unit?
zman is offline   Reply With Quote
Old 06-08-2015, 01:07 PM   #101
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
Originally Posted by pkny View Post
Got my FR-S on Thursday, and found out that the dealer set the FR-S base audio to tC in the Car type (EQ) setting instead of FR-S. Oh well, that's a easy fix.
Here is the instruction for changing the Car Type (from p.52 of the manual):
To display the SETUP menu, press
and hold the MULTI KNOB while
the power is in "OFF" position.
When the MULTI KNOB is turned,
the setting item of the SETUP
menu will switch in the following
order:
SUB-W CTRL, OPENING, CAR TYPE
CAR TYPE:
A menu for setting up the vehicle
type.
pressed, switches in the following
order:
TC , XB, XD,IQ, FR-S
After you press the MULTIKNOB 4 times, it should look like this:
Attachment 7926
For those who have the base audio in their FR-S, you may want to check this setting.
Note: I haven't compare the differences between different Car Type, but base on my experience of owning a 1st gen tC, a correct Car Type always sounds the best. You may found another Car Type sounds better, so feel free to play with it.
Tc sounds so much better than FRS in our head unit. I had mine set to TC, changed it to frs, and immediately went back to tc
Sent from my HTC6535LVW using Tapatalk
WallsAndFoundations is offline   Reply With Quote
Old 06-08-2015, 01:31 PM   #102
Pretty much, but that's not uncommon for OEM radios.
Old 06-08-2015, 01:54 PM   #103
Had mine set to TC but didn't like it. Set it to FRS and fiddled with settings for a while and got it to a pretty good level.
Old 06-08-2015, 02:03 PM   #104
zman
zman's Avatar
Drives: scion frs
This junkyard has a 2014 Tc , you guys think it's worth it if I replace that with my current 2013 base head unit?
Old 06-08-2015, 02:13 PM   #105
I've been pretty happy with the 2014 Pioneer/NAV unit I installed in mine. I can't tell a lot of difference in the sound but the functionality is better.
Then again, I'm not a good judge of the sound quality.
zman (06-08-2015)
Old 06-10-2015, 03:08 AM   #106
zman
zman's Avatar
Drives: scion frs
Does anyone know what unit from Toyotas work for our car ? I basically want a touchscreen without loosing sound quality. Also to be able to use my subwoofer with RCA outputs.
Old 11-18-2015, 03:40 AM   #107
Kerber23
Kerber23's Avatar
Drives: Turbo FRS
Thank you so much... no more distortion... I got it used and thought the speakers where blown or messed up.
Kerber23 is offline   Reply With Quote
Old 02-22-2016, 01:30 AM   #108
Sam677
Drives: FRS
How do I access this car selection panel on the bespoke lcd layout versus the basic head Unit?
Sam677 is offline   Reply With Quote
Old 02-22-2016, 03:20 AM   #109
Knshro13
Drives: 10 series FRS
when I had my OEM Audio + installed, they recommended the tC setting over FRS. And like a few of you, I toggles between FRS and tC. tC definitely sounds better.
Knshro13 is offline   Reply With Quote
Old 06-14-2016, 06:17 AM   #110
azynneo
For an audiophile.. that setting change was a NIGHT and DAY difference. Music actually makes sense now.
azynneo is offline   Reply With Quote
Old 11-07-2016, 05:47 PM   #111
gedster314
Drives: Thunderbolt Grease Slapper
I use the IQ setting in my XB and set it to feel the bass. Sounds better than the XB and TC setting.
gedster314 is offline   Reply With Quote
Old 11-07-2016, 06:13 PM   #112
86Boyz
Drives: on the highway to hell
tC is the best! Too bad they discontinued it.
86Boyz is offline   Reply With Quote
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 07:08 PM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 12:17 PM
Base BRZ exterior pictures? mines13 BRZ First-Gen (2012+) — General Topics 15 12-05-2011 03:11 PM
Feds find majority of Toyota unintended acceleration cases were people hitting wrong ichitaka05 Other Vehicles & General Automotive Discussions 15 03-16-2011 02:19 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 11:55 PM
