Old 11-05-2016, 04:32 PM   #15
Norinradd
Drives: 2013 frs
I dunno what i need to buy for the rear now. I thought with 1" drop i wouldnt need to adjust rear camber. Wtfffuhg
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 11-05-2016, 04:40 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Just get rear LCA, which stands for lower control arm. SPC (same as whiteline & eibach) should be cheapest.
Norinradd (11-06-2016)
Old 11-05-2016, 04:48 PM   #17
Google is your friend. I suggest you do a little research on double wishbone suspensions.
Old 11-05-2016, 04:55 PM   #18
Norinradd
Drives: 2013 frs
Hah yes i know what lca stands for.
Once again. As i said. I read you didnt need to buy anything for such a small drop. I dont want to spend 800$ on lcas. That is ridiculous.
Why is the camber -2.5 on one side and -.9 on the other?
That makes no sense to me. Is it the springs settling?
Old 11-05-2016, 04:56 PM   #19
Norinradd
Drives: 2013 frs
Front camber? Noob
I have. Google didnt answer my question. Do you have an answer? As to why camber is -2.5 one side and -.9 other side.
Old 11-05-2016, 05:06 PM   #20
Not yet.
Did you measure the camber before you lowered it?
Old 11-05-2016, 05:19 PM   #21
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
FWIW, I run -2.5 up front, and -2.0 at the rear, and have yet to notice any uneven wear on my Michelin Pilot Super Sports.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 11-05-2016, 05:53 PM   #22
Norinradd
Drives: 2013 frs
Not yet.
No i dont know how to do that. Just visually it looked okay. But the drop may have excentuated it. Alignment tech says most probably answer is the strut is bent
Old 11-05-2016, 06:27 PM   #23
So may i ask how the fuck my rear drivers tire is at -2.5 after the lowering springs. One rear is -2.5. The other is -.9. That seems like somethings is really messed up?!?! No!?
Not yet.
Did this alignment tech ever look underneath the car before taking those measurements?
Again, google up on double wishbone suspensions. If you find a picture you'd like to discuss, post it up here. Let's start with the absence of a "strut" on the diagram. Shock, yes, but if your guy blamed the asymmetry on a bent shock, you need a new guy.
Did he not show you what was going on down there? Next time you have a chance to look, ask. Most guys will be happy to give you a brief rundown. I know I would.
wparsons (11-06-2016), x808drifter (11-05-2016)
Old 11-05-2016, 08:02 PM   #24
Norinradd
Drives: 2013 frs
Front camber? Noob
I already know whats going on? Everything looks good underneath. He looked on the hoist aswell. I installed the springs, i was underneath yesterday. I understand camber. He said bent strut.
Now, What i dont undrstand is whats causing the 1.5 degree variance in camber. It could be a bend barely visable to naked eye in a handful of components. I was just hoping this had happend to someone.
Old 11-05-2016, 08:04 PM   #25
Norinradd
Drives: 2013 frs
And what diagram are you talking about?
Old 11-05-2016, 08:19 PM   #26
Norinradd
Drives: 2013 frs
Although i did read over this step. Upon re reading instructions. I dont understand the "75-85 degree" business. Im gonna have to check if the coils are pointing the correct way. Might have overlooked that!!
Old 11-05-2016, 10:59 PM   #27
Any old diagram illustrating the components of a double wishbone suspension. I'm trying to help you understand with clarity the reason your shocks have absolutely nothing to do with your rear wheel alignment.
strat61caster (11-06-2016)
Old 11-05-2016, 11:54 PM   #28
Norinradd
Drives: 2013 frs
When i say shock i nean the entire strut assembly.
Are you saying the whole strut and spring have nothing to do with alignment? As they most certainly do.
This is how camber affects toe in front. Also RCE camber plate info. Pat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-04-2016 11:08 PM
Basic Noob Questions - Camber bolts/alignment/etc Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-28-2015 02:59 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
