#463 |
Boost Creep
Drives: 2016 HyperBlue BRZ
Yeah I was actually just about to try that. I think I'm going to switch to a more powerful unit next month regardless, these hangups aren't acceptable to me since the whole purpose of having this thing is gauges.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#464 |
Drives: 2016 BRZ Series.HyperBlue
Mine was super slow as well, but after disabling Google App and Google Play Services and tweaking some values in the Governor it's relatively quick now.
More info on the governor stuff here: http://forum.xda-developers.com/show...66&postcount=3 I'm using the latest Malaysk MTCD rom which has root access. I used kernel adiutor to set the go_hispeed_load to 60 and hispeed_freq to 1608000 and it's been pretty good since then. Downside of disabling Google Play Services is that you can't store offline areas in Google Maps (among other things), but I guess I can live with that. |
#465 | |
Original lines with the real trajectory on the ground: Modified lines png file: Modified apk with the new trajectory lines MTCBackView.zip I didn't get a picture yet, but it's pretty decent now. |
#466 |
TRACKBREAD
#467 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Has anyone on 5.1.1 noticed significant increases in performance from upgrading to JY_1.90 (Sept) from JY_1.63 (June)?
Also, has the sound output changed? I am worried that if I upgrade then it will mess up my oem audio+ tune.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#468 |
Addicted
Update, I retuned my sound and it's great with OEM audio Plus. If anyone has the Joying 5.1.1 HU or OEM Audio Plus setup I would recommend pairing the two as it sounds amazing.
As for the 5.1.1 headunit, I decided not to root it and stuck with v1.90 as it fit my needs. Disabled a bunch of google services which sped up the unit ALOT.
#469 |
Drives: Asphalt FR-S
They added the new 2gb units running Intel processors (rockchip partnership)
https://www.carjoying.com/us-warehou...entertain.html |
#470 |
Drives: Scion FR-S RAVEN
how are you guys getting your units (internet) ?
I'd perfer not to use a hotspot. Does BLUETOOTH Internet connection sharing work? Everytime I go into google maps it needs a connection when I have GPS. what am I missing? |
#471 | |
Sent from my Pixel XL using Tapatalk |
#472 | |
Grip>Slip
#473 | |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
#474 | |
Grip>Slip
if i recall, before i disabled it, pushing the eject button did elicit a keypress beep, so it should still be functional. but i can confirm further once i figure out more about how it works. I can confirm that my USB OBD2 adapter works great, which means super fast refresh rates. |
#475 | |||
Basically you activate the mtc-keys xposed module and create an mtc-keys.ini file on the SD card. The file contents map the buttons ID to the package/action/intent you want it to run...mine looks like this: Code:
# Remap physical HU buttons to apps # MUTE button [home] action_4=home # DVD button [mtcmusic4] app_42=com.microntek.music # BAND button [torque] app_43=org.prowl.torque # NAVI button [HERE WeGo] app_51=com.here.app.maps https://forum.xda-developers.com/sho....php?t=3246426 Quote:
![]() Quote:
#476 |
Drives: 2013 Subaru BRZ Limited (Black)
Evening All -- Has anyone updated to the latest march or february firmwares for their 2GB 5.1 unit?
I had OEM Audio+ retune my amplifier but the imaging and sound balance was far off. I'm on the Dec 2016 firmware and they had based their tune off of the Nov 2016 firmware. Joying must be modifying the sound output with some firmware revisions. I'm trying to decide if I want to stick to Dec 2016 firmware and let OEM+ tune to that (I am sending my headunit in with the amplifier for retuning), or if I want to upgrade to the latest firmware so that i'll be current before they begin the tuning. It's tough to know, because there aren't too many folks providing feedback on the february or march firmware updates. Anyone have thoughts? |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
