Old 11-02-2016, 05:45 PM   #1149
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by TylerLieberman View Post
What suspension? Spring rates?
Fa500 v5 6k 7krear. I just looked and i do have alot of positive camber wear
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 11-02-2016, 07:40 PM   #1150
sosick
fastest frs in sbg
sosick's Avatar
https://www.facebook.com/permalink.p...00012987001670
2014 firestorm frs
Old 11-02-2016, 07:43 PM   #1151
sosick
fastest frs in sbg
sosick's Avatar
In the outside view, in the third turn i think i wiped out. And in the in car video in the third turn i straightened out.
2014 firestorm frs
Old 11-02-2016, 07:52 PM   #1152
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
If it were me, I'd increase the camber a little to around -1.5 or so. Also, maybe increase the tire pressure a bit to help if you're still struggling to keep the wheels spinning.
It was hard to really see, but it looks good man. Just keep going. Seat time is everything. If I were to give any suggestion, it would be stay in the throttle more. It looks like whenever you're starting to lift off the throttle is when you're starting to straighten out.
Given the lower power and higher amount of grip you have, you'll just want to keep on the throttle to keep the wheels spinning. Just my personal opinion.
Try an alignment change and more rear tire pressure though and see how that helps. Take away grip, and then slowly dial more in until you find what's comfortable. Once you get comfortable, you'll probably start putting a little more grip back into the car to do more throttle steering.
Old 11-02-2016, 08:02 PM   #1153
sosick
fastest frs in sbg
sosick's Avatar
https://www.facebook.com/DEENKAYv/posts/531779507025213
2014 firestorm frs
Old 11-02-2016, 08:02 PM   #1154
sosick
fastest frs in sbg
sosick's Avatar
https://www.facebook.com/DEENKAYv/posts/531511953718635
2014 firestorm frs
Old 11-02-2016, 08:04 PM   #1155
sosick
fastest frs in sbg
sosick's Avatar
https://www.facebook.com/DEENKAYv/posts/531492773720553
2014 firestorm frs
Old 11-02-2016, 08:04 PM   #1156
sosick
fastest frs in sbg
sosick's Avatar
Thanks. Ill do that. I always say im gonna check air pressure but always forget due to excitement lol
2014 firestorm frs
Old 11-02-2016, 10:28 PM   #1157
TylerLieberman
Drives: '24 GR86
Lol. My recommendation for that is show up with them really higher on pressure. Like 50psi cold. That way you can go out and do a run or two, and then just keep lowering until you find something that feels good.
It's easier to remove air, than add air, specifically in those instances where you don't have access to a compressor.
Old 11-02-2016, 11:03 PM   #1158
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
One thing I'm noticing, when you E brake initiate you aren't revving the car at the same time. While you have the clutch in, either floor it or at least give it some throttle so that when you let off the clutch and E brake you can keep the revs up and keep the tires spinning.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 11-03-2016, 01:58 AM   #1159
sosick
fastest frs in sbg
sosick's Avatar
Ok. Ur right i dont rev when i e brake ill try that next time thanks
2014 firestorm frs
Old 11-03-2016, 01:59 AM   #1160
sosick
fastest frs in sbg
sosick's Avatar
Will do!
2014 firestorm frs
Old 11-06-2016, 07:12 AM   #1161
JayForts
Drives: 2015 BRZ
Hey guys, I've been lurking thru the treads checking out setups and whatnot for a while. I've done a few events this here, my car is pretty much stock, nankangs NSII in the rear 40psi.
[ame]https://m.youtube.com/watch?v=NPKXdRwtyD8[/ame]
Second link is outside the car.
https://m.facebook.com/story.php?sto...05381446173180
Come spring I'll be doing coils and rear lower control arms. Right now leaning towards FA 500, trying to work out spring rates.
JayForts is offline   Reply With Quote
Old 11-08-2016, 10:17 AM   #1162
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Aye!! Glad to see you on the forums dude! lol clips are looking good I need to get a gopro /:
Are you going to be at stuffed moves and slay ride?
DavidBob is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
