#4229 |
Drives: 2016 Oceanic FR-S
Hey guys, this is my first post here, but I just wanted to ask a few questions after my first track day. This is also my first sports car, and the first car in which I'm in charge of everything (last car was a hand-me-down), so forgive me if these are some really basic questions.
First off, I had an absolute blast, and I'm trying to go back as soon as I can, but I'm a little worried about tracking my DD. Is there anything I should look out for in regards to this? Second, do I need to change my fluids after every track day? My car is still on factory fluids (5.5k on the odo), and I clocked about 70-90 miles at my last track day. Third, I experienced a little fade towards the end of the day (after some especially hot laps and a few hotter-than-I-should-have-been corner entries), before the track day, my pedal feel was instant, with bite being pretty strong after only about 1-1.5cm of travel (or at least that's what it felt like), now it feels like I can get a good 1.5-2 inches of travel before I get anything, and the bite is far less aggressive than it was before. Do I need to replace my pads? Should I keep this set a little longer? Is there a way to inspect them without a jack or putting the car on a lift? Also speaking of brakes, what is the factory fluid, DOT3? Is there a specific brand that most people run as DOT4? How hard is it to replace the fluid myself? What would it run me at a shop? Speaking of shops... Fourth, for days that require inspection, how do I get that done? Do I just go to a shop/dealer and ask for an inspection and hand them the sheet? Is it done at the track? Finally, what do I need to bring to a full-scale HPDE? (My first trackday was an 'instruction' day that was supposed to be a lead-up to an HPDE instead of jumping in all at once.) Do I need to bring extra parts? Tape for numbers? A jack? I realize there's another thread for this, but I'm just wondering if everything mentioned in that thread is really necessary if it's not a full race-spec car. Sorry if these are a lot of questions, or if they've already been asked/answered. |
#4230 | |
driving smoother faster
Drives: Sold
Read some of the sticky threads in "Tracking / Autocross / HPDE / Drifting" http://www.ft86club.com/forums/forumdisplay.php?f=39, then ask away. |
#4231 | |
#4232 | |
Drives: 2013 Firestorm FR-S
If you do track day insurance, and know you'll be doing multiple HPDEs within a given year, my advice is to purchase a multi-event pack to save money and try to sign up for as many two day HPDEs as possible, since policies are on a per-event-basis (not per-day). 2) Short answer, no. But you should be checking your oil and brake fluid before and after every event. You should be at the least bleeding your brakes before each track day. Other fluids change intervals will vary depending on what fluids you put in, how hard you drive the car and how much you drive in between events daily. There are lots of threads on here covering each type of fluid change in more detail. 3) Brake fade after a track day is pretty normal, particularly if you were on stock pads/fluid. You might be able to get an idea of pad thickness without jacking the car up and removing the wheels/pads, but it's probably a better idea to just do that. You can check for glazing and chunking then too. The fade is most likely caused by boiling your fluid. You should at least be bleeding your brakes before every event, but you're going to be changing it fairly often if you're getting into HPDEs. It's pretty easy to do yourself with the right tools, but simpler if you have a friend. As for brands, most people seem to go with Motul RBF600 or RBF660. I use ProjectMu G-Four 355, and there are other options. All are good options, but I'd definitely recommend reading into it more. The guys at CSG were very helpful when I was picking pads and fluid for track days. Oh, and on the matter of pads, pick up a set specifically for track days. Track pads and street pads both have intended uses, and neither are ideal for the duty of the other. CSG will be great at helping you pick the right pad for your experience level and the tracks you will be driving at. 4) Depends on the organization, some do require you to get the inspection done before coming to the event. Most, at least in my experience, will do them the morning of the event. I've always gotten my tech done day of at the track. 5) You shouldn't need to bring extra pads (depending on how much life is currently in the ones you have). But as I suggested above, it's a good idea to have a dedicated set of track pads you switch to either before going to or at the track, I suppose then your OE/street pads are a backup set. Numbers are normally supplied in the form of a decal that goes on your window, but I would check with the organizing group you sign up with. A jack, tools, extra brake fluid and oil, sunscreen, a camping chair, water, and snacks/other drinks are all good things to bring with you as well. If you don't have a jack, I'd recommend getting one so you can at least take care of your brakes at home. (The simple tools required for that job are a good idea too). I wouldn't worry too much about running out and buying a bunch of tools to have handy for your first few track days. Every HPDE you go to will have just about any tool you can think of between all the participants, and nearly everyone will be happy to loan you tools and/or a helping hand. There's a lot more detailed information on these questions, and on some good ones you haven't asked yet and/or are likely to have in the future, in this thread. Read lots, don't be afraid to ask questions and have fun!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | strat61caster (10-25-2016) |
#4233 | |
Drives: Sold
![]() on track prep: http://www.ft86club.com/forums/showthread.php?t=25485 http://www.ft86club.com/forums/showthread.php?t=111225 on fluids: http://www.ft86club.com/forums/showthread.php?t=111251 on brake pads: use track pad compounds on track (not street or mixed) and inspect before and during as needed. use quality brake fluid like torque rt700 or similar. don't ride brakes on track or you will overheat pad and fluid. in time you will learn to brake later and less. if you push your car, your OEM pads will fade soon enough. on how to pick a shop to do build/maintain/inspect tracked car: - there is a section on that in my build thread http://www.ft86club.com/forums/showthread.php?t=79895 - reasons why I only change wheels and pads and don't do other wrenching though I know how: my life depends on it + I may not recognize if/when I do something wrong + when the shop does fluid changes, they can also inspect many other things and find things that I wouldn't + my life depends on it on what to bring on track: http://www.ft86club.com/forums/showthread.php?t=25485 - you at least want to be able to torque lug nuts (not right after runs when hot) with a torque wrench (Harbor Freight ones are cheap and good enough) and measure tire pressures (hot pressures should usually be 2-4 PSI higher than what's on the door frame stickers). enjoy |
| The Following 3 Users Say Thank You to dp1 For This Useful Post: |
#4234 | |
2. No, but you do want to change more often than factory intervals, as you ARE driving your car harder, and subjecting it to more heat, wear, and friction. 3. That increased travel is degraded brake fluid. Lack of response in the brake pads relative to pressure, is brake pad fade. You want to upgrade both your pads and fluid, for track duty. You can swap in stock pads between track days, but most weekend warriors eventually opt to leave in their race pads permanently. Once properly bedded, noise isn't an issue, and the only real consequence is increased brake dust. 4. It depends on the organization; ask them if it is a "self-tech", "at the event", or if it needs to be done professionally, and act accordingly. Some best practices are to always check your oil level, tire pressures, and lug-nut torque. 5. Check out this thread. http://www.ft86club.com/forums/showthread.php?t=25485 Great questions, and you're asking in the right place. We're here to help. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | dp1 (10-26-2016) |
#4235 | |
3. What are some well balanced pads for street and track use? If I go through the process of changing them myself and find out that the process is relatively simple, I might just go ahead and swap them. If it helps, the track I'm driving at is the NCM Motorsports Park. |
#4236 |
#4237 | |
Drives: '23 BRZ Limited
Keep in mind, track day insurance doesn't cover if you blow up the motor/trans/diff/etc, it only covers you hitting someone, you hitting something, or someone else hitting you. And most have a deductible in the $3500-5000 range..........so just be prepared for that as well. My only brake pad suggestions come from the Miata world where many run Carbotech's......but it seems as though some are switching to GLocs. |
#4238 | |
3. There is no "jack of all trades". That being said just get an entry level race pad. G-loc R10, Project Mu Club Racer, Winmax W5 type pads, and a good brake fluid. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ajc209 (10-26-2016) |
#4239 |
Is anyone on the forum racing in this class or planning to next year?
I am thinking about making the jump with my car. DP |
#4240 | |
#4241 |
Drives: 2013 Subaru BRZ Limited (WRB)
Going to need another set of tires for next years HPDE season. Starting the research a bit early. Suspension is 100% OEM. So far, I've used RE-11 and RE-71R. The RE-11 were nice and consistent, but the grip wasn't quite as good as the 71R. However, the 71R seemed to get slick after a few laps when driven hard.
I use Toyo R888's on my Vette, and really like that tire so far. Any thoughts on these tires for the BRZ, especially the new R888R? Anything else I should consider that could have same or better grip with better consistency throughout a session? |
#4242 | |
Drives: Sold
What size rims/tires do you want to run |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
