Old 09-26-2015, 04:43 PM   #71
White64Goat
Just did this upgrade today. One thing that got me was the 3 retainers at the back of the headliner. They are the push-pin type and I was trying to pry out the entire clip at first and then finally realized that the 2 piece clip is just that, 2 pieces. If you look at the first post, picture 5, what looks like a gray shadow right under the black part of the clip is actually the 2nd part of the clip, so you need to insert your small screwdriver BETWEEN the black part of the clip and the white inner part to pop them apart. Was going to take a picture of the clip but forgot and put it back together. You can also use a pair of Channel-Lock pliers to loosen the antenna nut and save yourself some dough on buying a 22mm socket or wrench. Nut is not that tight.
Old 02-05-2016, 06:10 AM   #72
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Just bought 86321CA610RL from Subaru for my GT86 (FR-S). I feel anxious to remove the old antenna. lol Thanks for the information OP!
Fenix is offline   Reply With Quote
Old 03-02-2016, 12:46 PM   #73
jtiptonk
jtiptonk's Avatar
Drives: 2013 WRB Subaru BRZ Limited 2.0
Just bought this one:
http://www.frsport.com/Subaru-86321C..._p_398683.html
Free in store pickup if you live in so-cal. Also they have a tax season sale going on now (30% off), so all said and done (tax, shipping) it was $158.21
I'll be sure to give an update when it arrives
jtiptonk is offline   Reply With Quote
Old 03-07-2016, 04:22 PM   #74
Lync
Drives: 2014 Scion FR-S Ultramarine
I'm a little confused, I looked up the part number for my scion ultramarine and the image displayed doesn't look like the shark fin. Can you confirm if this is the correct part? I don't want to buy a second antenna... http://toyotaparts.bochtoyotasouth.c...ota/su00305514
Lync is offline   Reply With Quote
Old 03-08-2016, 01:11 AM   #75
jtiptonk
jtiptonk's Avatar
Thumbs up Donezo!
Originally Posted by jtiptonk View Post
…I'll be sure to give an update when it arrives
UPDATE: It came pretty fast and I just installed it. Here are a few tips:
• When removing the 3 black rivet things, dont just shove a screwdriver under it and pull as hard as you can, there are TWO layers a black sitting right on a white plastic layer. Be sure to slip your flathead carefully between the two and it should pop right off. You can then just pull out the white part of it with your fingers.
• They didnt have a 22mm socket at my home depot, so I got a 22mm flat wrench instead, this turned out to be a good thing because…
• I didn't fully pop off the back of the lining because when I went to remove the trim piece it didnt want to come off and I got a little sketched out since there's an airbag right behind it. Instead i just removed the 3 rivets and was able to slide the flat wrench in (with the help of a flashlight) and remove the bolt.
• I used a knife to slice the electrical tape, and performed the whole operation without creasing my lining or having to pull off any trim pieces.
• I freaked out for a second because my satellite said no signal (not that i ever use it), but upon moving my car out from under the carport I realized that was just blocking the signal, the antenna was working fine. So I popped the 3 rivets back and and everything's good so far!
• also since I was sliding my hands between the roof and the lining, I got some weird scratches from some sharp fibers in the lining, I'd recommend gloves and long sleeves.
All and all a very easy procedure and it looks way better than any of the aftermarket ones— worth it!
Old 04-03-2016, 10:40 PM   #76
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Installed the oem black sharkfin cause I knew I was wrapping my roof gloss black.
BoxRZ_86 is offline   Reply With Quote
The Following User Says Thank You to BoxRZ_86 For This Useful Post:
SuperDave (06-18-2016)
Old 04-11-2016, 02:56 PM   #77
kbye
kbye's Avatar
Drives: 2014 FR-S
Sorry for the late response, I'm not on forums as often as I used to be. Yes, it is the correct part, that is just a stock image.
If you are unsure, best thing to do is order from the dealership, they will generally accept returns with no restocking fees. But I am confident it is the correct part number.
kbye is offline   Reply With Quote
Old 04-11-2016, 02:59 PM   #78
kbye
kbye's Avatar
Drives: 2014 FR-S
Also the Beatsonic antenna on my wife's Impreza ended up coming loose after 2 years of daily driving :/
OEM >>> aftermarket
Old 04-29-2016, 11:38 PM   #79
carczar87
Perpetually Sideways
carczar87's Avatar
Drives: '14 DGM BRZ, '94 Volvo 940 Turbo
Thank you for this DIY and also the part numbers! I just did this today on my 2014 DGM. Pretty easy all in all!
carczar87 is offline   Reply With Quote
Old 05-10-2016, 11:52 AM   #80
cshinn89
cshinn89's Avatar
Drives: 2014 FRS Ultramarine
has anyone tried using the BRZ antenna on a FRS and wiring up the satellite radio to it?
cshinn89 is offline   Reply With Quote
Old 10-19-2016, 09:00 PM   #81
tb303
Drives: GT86
Can anyone confirm the Part Number for an GT86 (GTS version) in Australia colour code K1X?
thanks!
tb303 is offline   Reply With Quote
Old 12-16-2016, 01:30 AM   #82
infusion101
Drives: 2013 Red Subaru BRZ Limited
I have a beat sonic on my 2013 BRZ. I've noticed that my GPS is spotty when searching for addresses and that barely have access to HD stations. Anyone else having that issue, and will installing a 2015+ OEM shark fin fix the issues?
infusion101 is offline   Reply With Quote
Old 12-16-2016, 04:18 AM   #83
churchx
churchx's Avatar
Drives: 2014 GT86
In my GT86 there is separate round antenna to be installed near base of front windshield, at least for stock toyota's Touch & Go navi. Is it different for BRZs? If same for them aswell, how should antenna type on top of car affect GPS reception?
Old 01-16-2017, 01:58 PM   #84
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I was able to swap out my '13 antenna for the '15 last week.
My reception is still fine, however, every time I start my car, the radio tells me to "Check Antenna." Has anyone else experienced this and/or been able to fix it?
BigTuna is offline   Reply With Quote
***NEW***Beatsonic Version 2 Sharkfin Antenna FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 29 03-27-2016 05:32 PM
WTB: sharkfin antenna/clear side markers _frs Want-To-Buy Requests 0 10-27-2014 05:02 PM
Nav w/Sharkfin Antenna Ryan5x Electronics | Audio | NAV | Infotainment 1 06-25-2014 04:37 PM
Pic Request: Red Beatsonic Sharkfin Antenna on Raven FRS Lemar58 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 03-21-2013 12:26 AM
grazio & co. sharkfin antenna ategs1992 BRZ First-Gen (2012+) — General Topics 1 12-09-2012 07:11 PM
