Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: Toyota 86
t86rs rear suspension. stock but 2.6 degree neg camber???
Hi Guys,
So I am just wondering if oem parts could be mixed and matched to somehow add neg camber to the rear? Many of the cars at the lower end of the field sit around 1.5 degree neg camber at minimum ride height. some cars "that came like this from factory with all factory parts" have up to 2.8 degree neg. any ideas on how this has been achieved. I have looked around and all i have found is upgraded bolts but they dont change anything. I know rear camber is ride height dependent as well, but max I have seen is 1.7 neg at below min ride height. Is this just a case of someone measuring hundreds of factory parts to find arms that are slightly longer, cradles that are slightly wider, and hubs that are slightly more offset and combining them? or am i missing something here? I AM DEFINITELY NOT SAYING ANYONE IS CHEATING. I THINK THERE ARE JUST SOME VERY SMART PEOPLE OUT THERE! ![]() |
#2 |
Not a troll
Go jack your car up, then loosen every single bolt on the entire suspension assembly.
Then, tighten them all up and get it aligned. Do that 100 times and you'll get different results every time. |
#3 | |
Drives: Strangely.
If you manage to do that while on the ground, you'll end up with more camber.
My FR-S has a build thread!
(It's mostly full of Nissans) |
The Following User Says Thank You to NissanGuy For This Useful Post: | Crunk81us (09-21-2016) |
#4 |
Drives: Toyota 86
#5 |
#6 |
Where are you finding someone that had -2.8* in the rear at stock height on all stock parts? That seems really unlikely, and is WAY outside the factory spec.
#7 |
Drives: FR-S Whiteout
If it's been lowered, maybe. Unlikely a completely stock one to have that much camber.
These look like they have been lowered a good amount. http://www.caradvice.com.au/441862/2...ew-track-test/ Also, how much are you lowered? According to my records, with completely stock suspension on my MY13 I had -1.0*L/-1.4*R in the rear, no driver weight. After installing some swift lowering springs (-1.0" or 25mm) I had as much as -2.3* camber with all else stock.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 09-21-2016 at 01:03 PM. |
#8 |
Drives: Strangely.
It's a pain in the ass, but yeah, basically. Most notably on the front strut-to-knuckle bolts. But at that point, you may as well put in some camber/crash bolts.
The rear has enough camber, and some very aggressive geometry. I think the rear subframe bushing flex reduces your dynamic camber; rear subframe bushing inserts definitely improve rear grip.
#9 |
Drives: Toyota 86
#10 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
i would probably protest if they were between me and a trophy |
#11 | |
You didn't actually mean ALL factory parts, or came from the factory like that...
#12 |
...Just add nauseum
Drives: 2003 (AP1) S2000
It sounds like he's repeating a claim made by someone else in the series, probably by the team with the aforementioned mystery camber...
There are many ways to displace.
-Spartarus |
The Following User Says Thank You to Spartarus For This Useful Post: | wparsons (10-19-2016) |
Alignment with stock suspension + camber plates | Pat | Tracking / Autocross / HPDE / Drifting | 9 | 08-18-2015 12:39 PM |
FOR SALE: 62 Degree front suspension kit. | Ringnes | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 11-07-2014 04:07 PM |
WTB: caster/camber plates - Or rear suspension alignment pieces | STS-V | Want-To-Buy Requests | 0 | 06-27-2014 09:24 AM |
How to achieve -2.0 front Camber with stock suspension (if possible)? | glamcem | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 66 | 04-06-2014 02:11 AM |
Cheapest way to get more camber on stock suspension | Snake | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-11-2014 08:45 AM |
