#15 | ||
...Just add nauseum
Drives: 2003 (AP1) S2000
Pic reference. It has an inside and an outside tread block. They will have to be re mounted correctly. Cheers.
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | humfrz (10-17-2016) |
#16 | |
This tire does not care which direction it rotates.
#17 |
Huge E85 fan!
Drives: 2016 Scion FRS
I've seen directional tires mounted backwards and it causes feathering of the tread blocks. When turned around and mounted the right way, the tire has a vibration and chops real bad which causes further damage. It depends on how aggressive the tread pattern is, but the damage can happen quickly.
#18 |
Drives: 2013 Toyota 86
They're all mounted the right way. It has inside written in huge letters on the inside so it's impossible to miss. The tyres seem to be asymmetrical which means the outer tread faces in different directions on either side of the car. In order for a tyre to be directional doesn't the tread have to be symmetrical like the Advan ad08r's?
#19 | |
| The Following User Says Thank You to Midjetv8 For This Useful Post: | Tcoat (10-17-2016) |
#20 | |
| The Following 2 Users Say Thank You to Midjetv8 For This Useful Post: | Tcoat (10-17-2016), Ultramaroon (10-17-2016) |
#21 |
Huge E85 fan!
I googled those tires and saw some pics. I didn't see if they are directional but they have an inside and an outside like @Midjetv8 says
| The Following User Says Thank You to guybo For This Useful Post: | Ultramaroon (10-17-2016) |
#22 |
Little Member
Drives: Bloo - The 13' BRZ
I will confirm that our RE003 and the new NA market Firehawk Indy 500 (sharing a tread pattern) are Assymetrical and non-directional. as long as the larger treadblocks (denoted by an outside and inside label) are on the correct side, they are mounted correctly and can be rotated to any position on the vehicle. directional tread is symmetrical wrt the centerline of the tire.
Besides tire pressures, I am not sure what else with regards to the tire could cause your pulling issue. I would try looking into the alignment again
| The Following User Says Thank You to yelsew For This Useful Post: | Ultramaroon (10-17-2016) |
#23 |
i always come into these threads hoping the OP is stock but that is never the case around here
#24 |
Because people with problems with stock ones just quietly take them in and have them fixed under warranty.
#25 |
Drives: AP1 Honda S2000, Focus RS
This is good advice, possibly save yourself a headache and more money by trying another shop. Iv'e been down this road before only to find out that a different shop has found the alignment to be WAY off.
| The Following User Says Thank You to deejaylew For This Useful Post: | Ultramaroon (10-17-2016) |
#26 |
Huge E85 fan!
#27 | |
...Just add nauseum
I just though he may have had some inside sides on the outside. I suppose not. Back to square 1.
-Spartarus |
| The Following 2 Users Say Thank You to Spartarus For This Useful Post: | Tcoat (10-17-2016), Ultramaroon (10-17-2016) |
#28 |
Ya I thought we had it. At this point I think he needs to look elsewhere other than just focusing on tires. Could have a bad damper, improperly seated spring or any of a 100 other things with the modded suspension. We all got so wrapped up in the tires that we are totally overlooking many other possibilities.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Spartarus (10-17-2016), Ultramaroon (10-17-2016) |
| Aggressively pulling to the left on acceleration | sero901 | Issues | Warranty | Recalls / TSB | 39 | 01-12-2021 06:39 PM |
| Pulling up floor rug? | ndsleep612 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 12-11-2013 02:23 AM |
| Brz pulling trailer? | subiesteve | Southwest | 7 | 11-20-2013 10:04 PM |
| 94 octane not pulling | Scalzo | Forced Induction | 44 | 10-08-2013 11:15 PM |
| Pulling your FRS off of the lot, what are you bumpin'?? | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 201 | 06-09-2012 10:52 PM |
