#57 |
Drives: Rip 04 golf gti rip 05 scion TC
I have drove stick in the past. 10 years ago with an 80s style clutch on a econobox of a car. So this sportier clutch is throwing me off and as i age my cordination seems to be getting worse. Haha. I have less then 500 miles on the car, and am pretty much getting comfortable with this no feedback huge travel of a clutch. I may lower it so im way more comfortable with it. My father had his where almost as soon as you took your foot off the ground it would start to catch. So this travel is new to me with no feel. You almost have to listen for the catch.
#58 |
Waited 5 years for this
Drives: '18 MX-5 Club
I think you and I are hearing the same noise. I hear it in the Parking lot going back and forth between 5 mph and 10 mph. And it's louder during deceleration. And 1500 RPM should not be too low of RPM as the gear shifting indicator of this car suggests to up shift when the RPM drops to 1500. I've been driving MT since 15 years ago and I've never experienced this noise.
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | Vracer111 (06-25-2012) |
#59 |
Re-member
Drives: Toyota camry
Not to mention the rear brake pads and rotors.
Nothing decays like progress, and nothing preserves like neglect.
#60 | |
Drives: VW GTI
All right let me explain to you what I did when I was learning. Push clutch and put it in first. SLOWLY release clutch to the catch point where the car will start to inch forward. Then press on the gas pedal and release clutch simultaneously. You should be doing this under 1k rpms. The amount you gas is actually not so much. TBH most ppl can even move the car without even gassing. Heck I can even get into second gear without even using the gas pedal on my car (VW). Also, the clanking you are hearing shouldn't be right. I think you have to time your clutch release better. I have a gut feeling you are releasing either too fast or too slow. |
#61 |
6/22/12-2/6/24
I feel weird using the hand brakes, using the foot brakes until the clutch hits the catch point and gassing is what I've done.
Just felt natural to me, but that means moot of course. |
#62 | |
Drives: 1982 Toyota Corolla Coupe SR5
If your shifting at 1500 rpm that sound your gettting is the synchros grinding because they are not synchronized. Unless the trans is well broken in I would not shift at that low of an RPM. The synchros require some RPM to create friction to be able to synchronize. Shift at least over 3000 RPM or at a high enough RPM that gives you a smooth shift.
Don't force the trans into gear if its grinding, let it go in on its own with a light pressure. If you force the trans into gear while its grinding your going to end up with bits of metal in the oil that will make shifting even harder. If it gets real bad shifting it maybe time to change the transmission oil to try and get the metal bits out. The transmission gears are always in mesh, it is the synchronizer collars? and whatever that lock the transmission into specific gears. Let the clutch fully out before getting on the gas. The car rocking back and forth is the clutch springs or rubbers taking the shock of engagement or the clutch bouncing if your on the gas before the clutch is fully engaged/released. Quote:
| The Following User Says Thank You to Sleeperz For This Useful Post: | Nate219BRZ (06-25-2012) |
#63 |
Drag racing, dropping the clutch at high RPM many times will cause the clutch to blow up, break apart, disintegrate, etc. Maybe not right away but most likely eventually.
#64 |
Drives: 2-door
Question:
How do I smooth out my shifts from 1st to 2nd? I duno what it is about this car but I can't make the shift smoothly unless I let off the clutch very slowly. 2nd to 3rd sometimes also gives me this problem - all other gears seem fine. |
#65 | |
6/22/12-2/6/24
I just pretend its just like 1st gear and slowly release the clutch
#66 |
Drives: car
When I first started out, I would rush the 1-2 shift and it would be really jerky. What helped me was waiting a little longer for the RPMs to drop more. Think of it as rev-matching.
#67 |
Drives: Hot Lava MT
I find it really hard to accelerate quickly if I wait a long time to shift to 2nd. About how high should I rev to 1st on this car?
#68 |
Drives: VW GTI
Yea, 1st to 2nd gear is horrible on almost every car in the world. It's always knotchy and jerky. The revs will tend to drop more, so take this shift slower.
#69 | |
Drives: car
#70 |
When your shifting gears your not actually going gear to gear like 1 to 2 , 2 to 3 etc. Your actually going 1 to neutral to 2, 2 to neutral to 3, etc.
You can try pausing briefly in neutral before shifting into 2. But usually the detents are so light you just go 1 to 2. For 2 to 3 you end up moving the shifter over so there is usually enough time in neutral. With older truck manual transmissions you had to yank the shifter hard or hammer the shifter into neutral then into the next gear because the detents were so heavy. The synchros have to do more work in the lower gears to match the shaft speeds. 3rd to 4th or 4 to 5th gear 1:1 are probably the easiest. Don't let off the clutch slowly , just release it smoothly and fully then get on the gas. |
| Second Impression with a Manual Transmission | Bristecom | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-30-2012 08:21 PM |
| FT-86, manual or automatic transmission??? | luisjr | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-25-2012 03:00 AM |
| Raven manual transmission $25,364.00 | terrypm | Dealer Cars | 0 | 06-01-2012 12:49 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
| Another reason to buy a manual transmission car... | xantonin | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 08-10-2011 11:30 AM |
