Old 10-07-2016, 12:34 PM   #43
shattered_memory
Drives: Satin White BRZ Limited
Originally Posted by zc06_kisstherain View Post
how is it?
I was just wondering what others have.
I heard -1.2 front and -1 is good
It handles very well. The balance is neutral with a little bit of understeer, if I go into a corner too hot. I have 0 toe all around, so wear is even on the tires. I drive spiritually on a daily basis and I do not get any camber wear on the tires. I would recommend my alignment for the street.
shattered_memory is offline   Reply With Quote
The Following User Says Thank You to shattered_memory For This Useful Post:
zc06_kisstherain (10-07-2016)
Old 10-07-2016, 12:49 PM   #44
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
do i need to wait few days to settle spring then get alignment?
my endlink came so gonna install tomorrow then get alignment on same day if possible.
Old 10-07-2016, 01:02 PM   #45
mclovin85
mclovin85's Avatar
Drives: scion fr-s
im thinking about purchasing these very soon... is it worth it? and will i need to upgrade my lca and stuff? or can i just run it stock with just the coils.. thanks in advance
mclovin85 is offline   Reply With Quote
Old 10-07-2016, 03:26 PM   #46
Valfred
Friendly Person
Valfred's Avatar
Drives: CWP Aozora
I'm no expert but I'm pretty sure you can!
If anyone can confirm this, that would be appreciated.
Valfred is offline   Reply With Quote
Old 10-07-2016, 04:10 PM   #47
Shady195
Drives: '13 10 Series FRS #1203
Depends on how low you go.
If you do a 1-1.5" drop you should be able to get away with stock and a little camber. I would however plan to get LCA's and Toe arms for the rear at somepoint.
Shady195 is offline   Reply With Quote
Old 10-07-2016, 04:12 PM   #48
bfrank1972
Drives: 2013 FR-S Argento
Sure you can run just the coils with no camber adjustment. The lower you make your car, the more camber you'll have in the rear. Fronts suspension is not multilink so camber stays roughly the same, so you'll eventually have much more rear camber than front, which will make your car understeer too much. At the very least get some SPC camber bolts for the front and max them out, they're cheap. If you go really low then you'll probably want adjustable rear LCA's as well - ideally you want adjustability on front and rear as whomever aligns your car can set it up right.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Valfred (10-07-2016)
Old 10-07-2016, 04:14 PM   #49
Shady195
how is it?
Anything under 2 should be good without hindering drive ability, once you start going over that more so in the front the car will start to grip imperfections in the road more from my experience, which can suck on long road trips.
The Following User Says Thank You to Shady195 For This Useful Post:
Old 10-07-2016, 04:35 PM   #50
bfrank1972
Hmm, I don't have this issue, thought I would, but I'm at -2.7 in the front, 0 toe, and it tracks fine down the road. I think there are other factors (i.e. tire compound/tread/sidewall stiffness, tire pressure, etc) that can help or hurt this. Making sure you have a good even alignment helps too. YMMV.
Old 10-07-2016, 05:05 PM   #51
zc06_kisstherain
Drives: SWP BRZ
no. you dont lower much you dont need but i would get one.
to add, Flex Z has camber top at front so you dont need to get camber bolt unless you want super low
Old 10-07-2016, 05:05 PM   #52
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Hopefully you keep your eyes open, unlike this other spiritual driver:
http://www.nydailynews.com/news/nati...icle-1.2708311
shiumai is offline   Reply With Quote
Old 10-07-2016, 05:06 PM   #53
zc06_kisstherain
Drives: SWP BRZ
anybody has applied ani-sieze on collar? i didnt and forgot about it might get seizing up later...dont want them to seize
Old 10-07-2016, 05:18 PM   #54
HachiRo
Drives: 2013 White-Out FRS
Sorry for my noob question, but if base drop is 1.2 inches and I only want my car lowered that much, I wouldn't need to make any adjustments right? Would I have to in the rear still as the rear is usually higher than the front? Or am I mistaken.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 10-07-2016, 05:39 PM   #55
mclovin85
mclovin85's Avatar
Drives: scion fr-s
thank you everyone for your input and i will probably be dropping like an inch or maybe .8... lol im not tryna mess up my front bumper just yet lol...
Old 10-07-2016, 07:44 PM   #56
shattered_memory
lol I meant "spiritedly." That was funny though haha
shiumai (10-07-2016)
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Street Flex Review! Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 04-20-2016 06:56 PM
Tein Street Flex Review and Short Video! RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 04-13-2016 02:17 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
New Tein Street Flex Coilovers - Review and Initial Impressions RallySport Direct Announcements, Contests, Giveaways 6 02-18-2013 12:06 PM
