#29 | ||
@GSpeed is going to measure transmission temps next, so they should have an answer to your q soon. ![]() Quote:
2022 BRZ Build 2013 FR-S Build |
#30 |
Drives: Full race 4cyl boxer
Now I just wish that MT engineers were smart enough to design in a oil pump in the mechanicals.
For a stock setup it would do nothing but keep the oil circulating. For an add on aftermarket cooler, you would just tap into the correct galleys and have a trans cooler that requires no pump. Otherwise you need an external (usually) electric pump in addition to the cooler.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
#31 |
Huge E85 fan!
Drives: 2016 Scion FRS
The problem there is, if there is too much cooling, the trans would not get up to and maintain operating temp as a DD. A car has to be designed either as a track car or a DD in some respects. To be a DD, it requires certain upgrades to be a good track car- trans oil and motor oil coolers are a must. If they were included on the stock car, either it'd be expensive to include because of the additional equipment (some system to disable for DD and enable for the track) or run too cool which is also bad.
| The Following User Says Thank You to guybo For This Useful Post: | humfrz (10-04-2016) |
#32 | |
#33 | |
#34 | |
Drives: swp mt '14 brz premium
#35 | |
humfrz |
#36 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (10-04-2016) |
#37 |
#38 | |
#39 |
#40 | |
![]() Here is an interesting read: http://www.machinerylubrication.com/...tion-lubricant So, I reckon that the transmission oil in a FR-S/BRZ can be "broken down" by the process of oxidation. So, if the temperature of the oil exceeds a threshold point, the oxidation process can take place. As @Spartarus mentioned, "(I scraped it off the Internet) generally, oxidation will reduce the service life of a lubricant by half, for every 10 degrees C (18 degrees F) increase in fluid temperature above 60degrees C (140 degrees F)". However, the manufacturers can add antioxidants and other compounds to slow down the process. I want to thank @Spartarus for his insightful and thorough contribution to the discussion. What is the conclusion .......hell, I'm not sure ..... ![]() humfrz |
#41 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
@JacksTrans is supposedly developing a transmission cooler
| The Following User Says Thank You to Drakiv For This Useful Post: | Spartarus (10-04-2016) |
#42 |
...Just add nauseum
Drives: 2003 (AP1) S2000
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | Drakiv (10-05-2016) |
| OFT Overheat Problem?? | Phil0rd | Software Tuning | 3 | 09-12-2016 01:04 PM |
| AT overheat safeguard? Tracking the Auto Transmission. | Tye300 | Engine, Exhaust, Transmission | 8 | 10-14-2013 01:16 PM |
