Old 06-24-2012, 11:06 AM   #1
yuli8466
Drives: MX5
is it necessary to change anti-roll bar?
I do not know. because there is no car here.
Never heard about such topic here.
Does anyone know?
yuli8466 is offline   Reply With Quote
Old 06-24-2012, 11:17 AM   #2
slimjoe
Drives: 2013 WRB BRZ
That's up to personal preference. Bring the car to a track and see how it drives first. After you know how it performs, you'll be able to make an informed decision on what needs to be modified.
slimjoe is offline   Reply With Quote
Old 06-24-2012, 12:49 PM   #3
Dimman
Kuruma Otaku
Dimman's Avatar
Does anyone know?
Search for 'sway bars'. I'm aware that the correct term is anti roll bar but most people call them sway bars.
As for needing them, it will depend on the rest of suspension setup.
Because titanium.
Old 06-24-2012, 01:37 PM   #4
seannyice81
Drives: 2013 Asphalt FR-S
Honestly, I don't see much need.
On both my previous cars, I've swapped out to larger diameter/adjustable bars. This car though seems to do good as is, and thats with a rear bar that looks like a twig.
seannyice81 is offline   Reply With Quote
Old 06-24-2012, 02:13 PM   #5
Sleeperz
Drives: 1982 Toyota Corolla Coupe SR5
From AVO:
Updates from the Option 2 magazine event, with Orido driving:
We fitted our 18mm solid rear bar halfway through to see how that would affect the handling. Unfortunately, not in a good way - it was nearly a second slower than with the standard rear bar. Orido said it was initially quite entertaining, the rear end would drift through nearly any sort of corner, but also quite twitchy, and ultimately harder to get through the course fast.
What we found so far is that, with the perfect 50/50 balance of the car from the factory, putting on a larger rear bar only, or a larger front bar only, will just upset that balance. Subaru/Toyota really did a good job of setting up the car out the door. Any swaybar upgrades need to be very carefully balanced front to rear, or you'll upset the balance, and ultimately, grip.
http://www.ft86club.com/forums/showt...?t=9101&page=2
Does anyone know?
Sleeperz is offline   Reply With Quote
Old 06-24-2012, 02:54 PM   #6
fatoni
Originally Posted by Sleeperz View Post
From AVO:
i feel like a rear sway upgrade is a bandaid for many front drive cars but i cant a matched set doing harm. also i wonder what you mean by 50/50 balance of the car
i think you just need to find out what frc you want, what frc you have and decide whether or not a sway bar or two is going to get you there
Old 06-24-2012, 04:58 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
From AVO:
Common sense with the slightest knowledge of suspension tuning would indicate that going from a 14mm rear bar to an 18mm rear bar and no front change was not going to be a great idea...
Because titanium.
Old 06-24-2012, 05:22 PM   #8
jamal
jamal's Avatar
Drives: Legacy GT
Necessary for what?
There are going to be cases where changing the swaybars will help. There are some where it won't. It depends on the rest of the suspension, tires, use of the car, and driver preference. No single setup is going to work best for everyone, which is why there are/will be adjustable swaybars in numerous sizes.
The nice thing about this car is that it is much lower and lighter than the WRX which has nearly identical suspension design. With a Subaru, you generally need to go to a fairly large bar, which has it's drawbacks. The BRZ will be able to get away with smaller sizes.
An 18mm swaybar is nearly three times stiffer than a 14mm bar btw.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
yuli8466 (06-24-2012)
Old 06-24-2012, 07:25 PM   #9
yuli8466
Drives: MX5
Yes, you are right. most people call them sway bar.
It should depend on the suspenion setup. How about stock suspension? I think the stock setup including suspension and sway bar is good enough, so balance.
Old 06-24-2012, 07:28 PM   #10
yuli8466
Drives: MX5
From AVO:
Thank you for the reference.
Toyobaru really did a good job !
Old 06-24-2012, 07:32 PM   #11
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
Just keep in mind what you'll be doing with the car in addition to your mods. A bar might help with autocross but might hurt on a road course / on the road...
mpicher is offline   Reply With Quote
Old 06-24-2012, 08:00 PM   #12
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
generally street cars that enjoy spirited driving rely on anti-roll bars to prevent "sway'" in the front and/or rear because they run softer spring rates. In a track focused vehicle, the emphasis is more on heavier/stiffer springs than anti-roll bars.
So yes, for most people wanting to improve the handling of their street car, anti-roll bars are applicable. I personally would never upgrade just one sway bar (unless you want a drift set up) as it upsets the balance of the car. You'd be best upgrading the front and rear at the same time with this car (theoretically speaking of course since most people havent played with this sort of stuff yet).
spiller is offline   Reply With Quote
Old 06-24-2012, 08:34 PM   #13
fatoni
i think youre on the right track but kind of overemphasizing things. sways are kind of a big deal on a race car. one sway upgrade works more often than you think. just look at every na6 miata that is in a stock autox class
Old 06-24-2012, 08:44 PM   #14
Dimman
Kuruma Otaku
Dimman's Avatar
Pet peeve of mine. (Not directed just at you, btw so don't take offense.) There is no motion called sway. The 3 axis a car moves in are Yaw, Pitch and Roll. Hence anti-roll bar.
And yes I know it is ubiquitous in the tuner and grassroots racing to call them sway bars. But it doesn't make it correct, and the pros don't use that term. /rant
Because titanium.
Roll cage (Stealth Inc.) Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 12-16-2013 11:51 AM
NW Prospective Owners Roll Call WingsofWar Northwest 125 08-27-2012 12:48 AM
Anti-rape condom = Condom with Teeth Giccin Off-Topic Lounge [WARNING: NO POLITICS] 27 12-08-2011 05:48 AM
Anti-drunk drink?! O_o 4point8 Off-Topic Lounge [WARNING: NO POLITICS] 2 12-04-2011 12:24 AM
