Old 09-27-2016, 12:35 PM   #1
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Rub limits
Well, it's about that time... I'm going to stop putting tires on the stock wheels.
It's time to replace them.
There are all kinds of guides for fitment, dimensions, and a whole directory of wheels, but there's no definitive information on what's going to rub and where.
Does anybody know the offset limit where the a wheel/tire of stock size and width will rub at full compression, full lock, or both? Here's a little more information:
I hate the way the stock wheels are hiding way back there in the wheel wells. It looks like garbage. I'm staying with 17x7's, and the stock 215/45 size, but I'd like to pull them further out toward the fenders. Thinking of picking up Motegi Racing MR221 2-piece in a custom offset. I like the weight and the design.
I know this will initially alter the wheel rate for the same spring rate, and it will change the scrub radius. I will be replacing the entire suspension with an adjustable setup, but I want to be free to make adjustments based on performance and handling, not to tuck in wheels that don't fit properly.
I'm an engine guy, not a suspension guy. I'm new to most of this. If nobody knows the answer, I will do the only thing I know how to do: measure for myself. I will put the car on a lift, pull the stock suspension, find full travel for all 4 dampers. I will then crack them open, remove the springs, reinstall them, and bolt the wheels up. I will then use a floor jack to compress each corner of the suspension and do my own measuring.
I know it's not realistic to expect nothing to rub anywhere ever, and if you're worried about full lock and compression at the same time, you're probably a passenger at that point anyway. Some advice there from people who know about that would be helpful. Again, I do engines, not suspension. I can tell you all about valve springs, but nobody has ever suggested "lowering springs" for those.
Also, If I've overlooked something, tell me. If I'm going to DQ from most competitions by changing the offset, I'm going to be sad. If altering the offset can't be properly compensated by spring, damping, and alignment alterations, explain why.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 09-27-2016, 12:38 PM   #2
c4lvinnn
Drives: Toyobaruion
You're way overthinking this.
c4lvinnn is offline   Reply With Quote
The Following User Says Thank You to c4lvinnn For This Useful Post:
kch (09-27-2016)
Old 09-27-2016, 12:51 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
AS far as having all bases covered, this would be very useful info for the community to have..
Old 09-27-2016, 12:57 PM   #4
c4lvinnn
Drives: Toyobaruion
not really. It's quite hard to actually make stock wheel width and stock tire size rub anywhere. They're so narrow and there's just so much room to play with. Some people have 20mm spacers f/r on stock wheels and they don't even rub even when lowered. Once you get into track-set ups, alignment, corner balancing, specific class requirements, auto-x, big meaty set ups, etc then this becomes more in depth. If you're looking for that in depth of info, http://www.ft86club.com/forums/forumdisplay.php?f=39 would be better suited.
If you're just trying to bring out 17x7s with 215/45s out more, it's one of the most basic things you can do.
strat61caster (09-27-2016)
Old 09-27-2016, 01:24 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Just read the wheel directory. It is a collection of most wheel sizes/tire sizes that will fit. And some that don't! Anyway, by just reading what fits and what does not, I chose a setup that fits perfectly for me. I am sure you would be able to do the same, especially because you want a conservative setup.
Old 09-27-2016, 01:25 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Thanks. I agree.
I leave town for work on Thursday, so I won't be measuring this week. If nobody know the answer, I'll have to buy some adjustable spacers, probably from PBM, and maybe locate some donor shocks. That would save me the shop time associated with taking mine apart.
I understand that. Once you start moving them out, you're eating up that room though. It's like running a wider wheel. Yes, you have space on the inside, but you aren't using it. You're chewing up your outside clearance.
I searched every section of the forum for the information I'm looking for. Including google. I found nothing.
I appreciate the info about having lots of space to play with, even lowered, but I could measure static clearance in a driveway... I care if something rubs under compression. I would like to retain full suspension travel, because I use all of the suspension travel. Otherwise it's not worth doing the mods.
Also, If we determine you can space it out 20mm, that means you can run a 20mm wider wheel, and change the offset to compensate, because we know the inside edge is safe, due to the location of the stock wheel. Kill 2 measurement birds with one stone.
-Spartarus
Old 09-27-2016, 01:31 PM   #7
c4lvinnn
Drives: Toyobaruion
Originally Posted by Spartarus View Post
Thanks. I agree.
There is absolutely no cut and dry formula for rubbing. There are too many variables. You cannot just say lower X amount, have spring rate at X, dampers set at X, and you will not rub. Hell, a missing push/pop rivet on a fender liner with wind flapping around could make you "rub". I don't believe you're being realistic in that sense. It's trial and error on your car alone. Choose the suspension you want, then go tinker. There are a ton of fitment threads you can look at for how something looks/fits and most even post their alignment specs.
People run stock all the way to 10" wide on stock fenders on all 4 corners. Even the aggressive wheel set up guys run 10.5 or larger. There's no "flow chart" of sorts for you to follow when it comes to choosing a subjective wheel fitment.
Old 09-27-2016, 01:31 PM   #8
Spartarus
...Just add nauseum
Spartarus's Avatar
I've read through, and there's lots of info on static clearance. But what happens when you take the suspension to full bump? Do those wheels still fit / clear? I know many of them do not, and many more have been
tucked in with camber adjustment, and rolling fenders.
-Spartarus
Old 09-27-2016, 01:36 PM   #9
Spartarus
...Just add nauseum
Spartarus's Avatar
There is absolutely no cut and dry formula for rubbing. There are too many variables. You cannot just say lower X amount, have spring rate at X, dampers set at X, and you will not rub. Hell, a missing push/pop rivet on a fender liner with wind flapping around could make you "rub". I don't believe you're being realistic in that sense. It's trial and error on your car alone. Choose the suspension you want, then go tinker. There are a ton of fitment threads you can look at for how something looks/fits.
People run stock all the way to 10" wide on stock fenders. There's no "flow chart" of sorts for you to follow when it comes to choosing a subjective wheel fitment.
Many of those variables can be eliminated completely though. I'm saying forget the suspension settings, and find the clearance at the limit of the suspension travel. Assuming the car is intact, and nothing is flopping around broken. Let me simplify the question with a dumb example... If you jump the stock car and bottom out the suspension completely, raised, lowered, who cares... The stock wheels will not rub anything on the car. The suspension will hit the bump limit first.. How far out can you push them while keeping that statement true? That's all I'm asking. No, I'm not building the car for jumping, it's just an example..
I was hoping the information already existed, because it will be the same for any wheel width at the stock tire diameter.
I would tinker, which I said I will do if the information doesn't exist, but I will tinker before I buy things, because custom offset 2-piece wheels are expensive.
-Spartarus
The Following User Says Thank You to Spartarus For This Useful Post:
Old 09-27-2016, 01:38 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What happens when you take suspension to full bump? It is as low as it can go.
If the wheels you have chosen fit, then yes! A proper setup, IMO, does not rub. My setup has NEVER rubbed. Be more specific, how wide do you want? how tall of a tire do you want? how low do you want your suspension?
Old 09-27-2016, 01:39 PM   #11
c4lvinnn
Drives: Toyobaruion
Again you're way overthinking this. You're not going from some scene-kid "stance-bro" fitment (I hate that word, by the way). You're going EXTREMELY mild and conservative. It's subjective because you need to figure out HOW you want your wheels to fit before you go and order some spec and it comes out not what you were wanting. YOU need to determine your ride height, your alignment specs, not some obscure or arbitrary reasoning. YOU need to go outside to your car, measure things, find out what other 17x7 wheels and their fitments you like, find out what offset they are running then tweak to your own preference. It's really not that hard.
FWIW, stock wheels are what? 17x7 +45? (or something in the mid-high 40s). An extremely common set up is 18x9.5 +38 all around. That is 25mm less inner clearance, but the outside edge is 39mm further out. Look how much room you have...
Old 09-27-2016, 02:08 PM   #12
Spartarus
...Just add nauseum
Spartarus's Avatar
The stocks are +48.
That is interesting. So, those are 63.5 mm wider than stock. At +38 offset, the outsides are 41.75 mm further out. The insides are 21.75mm further in.
So, That's the same as pushing 17x7's out to a +6.25mm offset. That's past flush...? There's no way that's not gonna hit the fender at full travel.
Either way, a 17x7 is no more conservative than any other wheel at the offset limit. If you push it out, eventually it will rub under compression. The unused space on the inside is irrelevant. This will probably happen before it gets to flush. Flush for a 17x7 is +25 F +18 R at stock height. If not, if it doesn't rub at perfectly flush at full bump, then my numbers are right there. I know the wheel pulls in under compression due to the suspension geometry. I know if I lower it, the wheel will pull in. The outside clearance limit at full bump is the same for everybody, regardless of wheel width, provided they keep the stock tire's outside diameter, and the stock geometry..
I will say again, If nobody knows, that's fine. I will measure it myself.
Full bump is the same for everyone, unless they've f*cked up their motion ratio or shock travel.
I'll probably buy the same offset all around and use hub centric spacers at the back. I hate spacers, but I want to retain the ability to swap front to rear as the tires wear, without re-mounting the tires.
-Spartarus
Old 09-27-2016, 02:13 PM   #13
c4lvinnn
Drives: Toyobaruion
And thats why theres too many variables. At a static 0 camber, 0 toe, suspension is non moving etc static environment, your statement could hold true.
Stop overthinking it. Go find something you like and go from there. Also please do not effectively "space out" a 7" wheel 40mm.
You cant omit these variables and get a "hard and fast" rule. Thats not going to happen.
Old 09-27-2016, 02:24 PM   #14
Spartarus
...Just add nauseum
Spartarus's Avatar
And thats why theres tok many variables. At a static 0 camber, 0 toe, suspension is non moving etc static environment, your statement could hold true.
Why not? The car handles great on N3000 215/45/17 tires. Why add a bunch more grip? I don't need it, and I don't want it. I'm not building the fastest car in the world, I'm building a car with great handling that handles really well at the limit. It drifts great, and the final power will be sub-300 at the wheels. I'm changing the turbo for a supercharger... Why get an 8.5 inch wheel and a 245 section tire if I can't spin the f*ck out of it, smoke the tire, and have a grand old time?
The only reason I'm not keeping the stock offset is I hate the way it looks. This is an aesthetics-only modification. All I'm doing is making sure I'm not sacrificing function for aesthetics. That means re-tuning the suspension to accept the altered offset, and making sure I don't hit anything. That's all.
-Spartarus
Load Limits Nah Software Tuning 3 07-15-2016 11:30 PM
Power and Speed Limits Vision86 Scion FR-S / Toyota 86 GT86 General Forum 101 01-15-2016 11:45 PM
Manual Transmission Limits? Tansey86 Engine, Exhaust, Transmission 22 07-18-2014 08:00 PM
Are politics off limits? Longhorn248 Site Announcements / Questions / Issues 35 05-16-2012 11:24 PM
why obsess over rev limits? fatoni Other Vehicles & General Automotive Discussions 39 10-12-2011 12:09 AM
