Old 09-25-2016, 08:42 PM   #15
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by ryoma View Post
what if you're stranded out in the middle of no where and you got a leak in your car with no water to pour in... do you piss in the filler cap? would it work?
Pretty sure piss boils at or close to what plain water boils at, maybe slightly higher due to salt content or maybe uric acid, so no.
No, I will not conduct an experiment to find out!
Old 09-25-2016, 09:48 PM   #16
Why not? I have probably poured worse in a rad to get to civilisation.
Old 09-25-2016, 09:51 PM   #17
By over filling the expansion reservoir you are completely defeating it's purpose.
Old 09-25-2016, 09:59 PM   #18
wbradley
Sarcastic SOB
wbradley's Avatar
Not much above the notch. It will never overflow. And actually it wasn't deliberate but it seems fine.
The Following User Says Thank You to wbradley For This Useful Post:
Tcoat (09-26-2016)
Old 09-25-2016, 10:29 PM   #19
NO! ...... silly (especially for females) ....... you piss in a container, then pour it into the radiator.......
Old 09-25-2016, 10:35 PM   #20
............... I just filled it a bit higher so it's maybe an inch above max level hot to extend the top up cycle. .
... welp, there goes your warranty, documented on the Internet ... too bad ......
Coolant, Anyone tried this?? stevo_12v Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-27-2016 05:50 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
coolant leak or burned rubber smell Saf Issues | Warranty | Recalls / TSB 7 02-27-2014 02:33 AM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 12:46 PM
