Pat.Thornton
Old 09-24-2016, 03:05 PM   #491
JB86'd
JB86'd's Avatar
Drives: JAWS
So around 20k miles (like most with this issue) clutch started squeaking, and has progressively gotten worse. I can feel slight crunchiness in end of pedal travel, and it's now happening with car on and off, usually starts after driving for a while. No abnormal TOB squealing or high pitch noises, just this creaking noise:
Dry clutch fork? Or throwout bearing binding on transmission snout? Dreading taking my car to the dealer.
[ame]http://youtu.be/hQnkycC_6fQ[/ame]
@Ultramaroon
JB86'd is offline   Reply With Quote
Old 09-24-2016, 03:44 PM   #492
That sounds like a spring (as in screen door spring) squeaking.
However, it could be the shaft from the slave cylinder making that sound, which can be lubricated - see discussed methods).
I suppose it could be the fingers on the pressure plate .. ??
If our cars have a clutch return spring (a little help here @Ultramaroon), I would place that as the #1 suspect.
Good clear video ....
Old 09-24-2016, 04:01 PM   #493
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It isn't the clutch return spring. If you have someone depress the clutch while you look under the hood, you'll be able to pinpoint where the noise is coming from.
I got my entire clutch assembly replaced due to this noise, but I think it's already coming back less than 1,000 miles later, so maybe it is just a lack of grease on the clutch fork shaft thing.
Stang70Fastback is offline   Reply With Quote
Old 09-24-2016, 04:09 PM   #494
@Ultramaroon
Yup. That's it. Lubricant failure/contamination. The crunchiness at the bottom is not the dry fork. It is the TOB binding against the front cover.
When they drop the transmission make sure they don't just dab grease in there. That snout needs to be fully cleaned. If it is worn or scored, it must be replaced.
JB86'd (09-24-2016)
Old 09-24-2016, 05:53 PM   #495
JB86'd
JB86'd's Avatar
Drives: JAWS
That's what I figured. I tried lubing both sides of the slave cylinder piston, and reached down to grease top of clutch fork pivot, with no success. Looks like it's going to the dealer. Thank you sir.
Old 09-24-2016, 05:59 PM   #496
Stang70Fastback
A.K.A. Starlord
What if I have crunchiness already and the entire assembly was just replaced less than 1,000 miles ago? Lol.
Old 09-24-2016, 07:43 PM   #497
Look at your invoice. I bet they did not replace the transmission front cover.
Something about the clutch mechanism, the materials, the lubricant, something is critically flawed. I think they should lengthen the bushing on the TOB to better prevent binding when it starts to wear.
Maybe the specified lubricant sucks. Maybe the bell housing ventilation blows dust from the disk in just the wrong way. So much to consider.
jcw99 (09-25-2016)
Old 09-24-2016, 08:06 PM   #498
Stang70Fastback
A.K.A. Starlord
http://www.seriesblueadventures.com/...nder-warranty/
Old 09-24-2016, 09:25 PM   #499
I don't see it there. It's not a trivial job. If you didn't get more than a thousand miles out of it, I'll guess it was already worn and they did not carefully clean it. Go back and look at my pictures.
Mine is still ok after about 5000 miles but I don't expect it to last forever.
Old 09-24-2016, 09:34 PM   #500
Stang70Fastback
A.K.A. Starlord
At this point I'll just let things go for a bit and see what happens. I'd rather bring it back with it making proper TOB failure noises this time so that they can be certain that whatever they did didn't fix and/or exacerbated the problem.
Old 09-24-2016, 09:42 PM   #501
Show them the crunch now. Less than 1000 miles? I'd be furious.
Old 09-24-2016, 09:49 PM   #502
Stang70Fastback
A.K.A. Starlord
I'm not furious because they didn't seem to know what the issue was the first time around, so they just replaced all the clutch stuff hoping that would fix it. Everyone gets a "chance" to fix something as far as I am concerned, and since the replacements they made did solve the problem initially, I don't blame them. The crunch doesn't always happen yet, but as soon as it becomes persistent I'll look into bringing the car in (my schedule is so busy lately it's hard to coordinate that stuff) and hopefully they will take a deeper look at things.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Ultramaroon (09-24-2016)
Old 09-24-2016, 09:50 PM   #503
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
When aren't you furious? You grouch.
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
Jonesy86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jonesy86 For This Useful Post:
humfrz (09-25-2016), Stang70Fastback (09-24-2016)
Old 09-24-2016, 09:54 PM   #504
lolol Grrrrr...
humfrz (09-25-2016)
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
