Old 09-23-2016, 12:47 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Seating position for a pinched nerve.
I've recently come across a huge problem.
Over many years I unknowingly developed bad posture habits with my head tending to be positioned out in front of my shoulders with a downward slant.
Just recently the pain transformed into my neck going numb instantly on the drive home and I now know what I have to work on to turn this around.
The problem is that the bucket seats are undoing any progess I make to regain my blood flow. If you can imagine the recommended sitting posture is an aligned back and neck at 90 degrees to the thighs..and if you look at the fr-s it's a strong acute angle with the headrest protruding my head exactly where it doesn't need it to be.
I've tried all kinds of angle and height adjustments. I tried reversing the headrest but there doesn't seem to be enough clearance to get it inserted. I even removed the headrest but it seems that even the slant of the back rest is enough to agitate my problem as if I would have to look at the celing to have good vertical alignment all the way.
I will be working through exercise and rehab to build muscle strength but the drive to work sets my nerve in place to be pinched and it lasts throughout the entire day with my neck and limbs becoming numb until I can rest at night and then it recovers. I have no other travel options for now, the fr-s is my only car.
If anyone has had similar problems or can offer advice it would be greatly appreciated.
Thanks.
Spacemane969 is offline   Reply With Quote
Old 09-23-2016, 12:50 PM   #2
Brayden_23
Drives: Asphalt 2015 FRS
You didn't have enough clearance to insert the headrest backwards? You should try again. They were designed to be reversible for people wearing helmets on track days.
Brayden_23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Brayden_23 For This Useful Post:
humfrz (09-23-2016), KalbiCool88 (09-29-2016)
Old 09-23-2016, 02:03 PM   #3
Yep, the headrest (at least on my 2013 FR-S) will turn around.
I suggest you get some large foam pads and modify/cut/tie together/stack them to make a temporary seat cushion that will suit your rehab positioning.
I hope you get better soon .....
Old 09-23-2016, 02:38 PM   #4
Spacemane969
Just tried the headrest again and It seems to have helped alot. Never thought of using foam, thats a good idea. Thanks guys
The Following 2 Users Say Thank You to Spacemane969 For This Useful Post:
humfrz (09-23-2016), Tcoat (09-23-2016)
Old 09-23-2016, 03:20 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Head rest or head restraint?? My understanding is that the device is a head restraint to stop head whiplash.
Old 09-23-2016, 03:27 PM   #6
It is but they have been colloquially called "head rests" since they came out.
"Head restraints" sounds to scary for many.
Old 09-23-2016, 03:53 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
See link below:
https://en.m.wikipedia.org/wiki/Head_restraint
Old 09-23-2016, 05:44 PM   #8
Ah yes. Just like I said they are indeed restraints.
BUT have commonly been called "rests" since they first showed up. You will even find them called that in brochures.
JD001 (09-24-2016)
Old 09-23-2016, 05:58 PM   #9
I experimented with something similar but, for me it didn't quite work out.
If you reverse the head "restraint," unless you are wearing a helmet, you really must fashion some sort of custom piece to support your head.
I carved a spacer out of that high density styrofoam stuff. I covered my headrest with a couple layers of paper, taped the spacer to it with shipping tape, and then slipped a headsock over it.
Old 09-23-2016, 09:45 PM   #10
Oh, I DO hope you dyed the headsock to match the interior .....
Old 09-23-2016, 10:42 PM   #11
g e
Two words:
Massage parlor
g e is offline   Reply With Quote
The Following User Says Thank You to g e For This Useful Post:
Eighty 6 (09-26-2016)
Old 09-24-2016, 12:01 AM   #12
It was already black.
humfrz (09-24-2016)
Old 09-24-2016, 12:02 AM   #13
Originally Posted by g e View Post
Two words:
Happy ending
fify
Old 09-26-2016, 05:32 PM   #14
frsvr4
Drives: '13 FRS
Almost 2 years ago I noticed a pinched nerve in my neck. Driving was the worst because the subtle impact loads of imperfect roads were torture. Sharp stabbing pains down my left arm. I'd always used chiropractic care for acute injuries, like that time you had to twist and torque to get a bolt loose in the engine bay only to immediately feel the not so subtle pain.
I had to use massage therapy to loosen the spasming muscles. Once I thought I had it under control, I tweaked my lower back playing volleyball. Stabbing pains down my leg.
I was 29, fit, but not as active as i should be, and desperate to fix myself, so I did some research. I bought Esther Gokhale's 8 steps to a pain free back from Amazon and read it cover to cover over 24 hours, using a mirror and folding chair to practice.
I can't recommend that book enough. Bad posture is an epidemic in this country and our car seats reflect that perfectly. The head rests are simply following the average American's head forward.
Her stretch sit cushion could improve your frs's seat considerably, allowing you to get your shoulders back, take weight off your lower back, and get some traction against the head rest to elongate your neck. I put these in the cars I drive more frequently that the frs, but there's no reason it won't work.
Good luck. Posture is critical to long term health and happiness...
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
What position do you sit in FR-S/BRZ??? cry7670 Scion FR-S / Toyota 86 GT86 General Forum 25 05-09-2015 01:08 PM
Seating and comfortability issues Frs x3 Issues | Warranty | Recalls / TSB 11 06-16-2013 06:19 PM
The seating position of BRZ is too low to reach at a drive-through-ATM yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 28 07-16-2012 03:18 PM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 02:28 PM
FT-86 II Studio pictures + seating chart DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 09-25-2011 01:22 AM
