Old 09-17-2016, 08:50 PM   #29
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by BxrFnd17 View Post
For those lowered 1 inch, have you had any issues with your axles?
I'm lowered on Hotchkis, and no problems after 2.5 years, and 30k miles, if not more.
The Following User Says Thank You to Gunman For This Useful Post:
DriveDriftDogfight86 (09-19-2016)
Old 09-17-2016, 09:29 PM   #30
BxrFnd17
Drives: 2017 BRZ Limited
Thumbs up
That's awesome, just what I wanted to hear.
BxrFnd17 is offline   Reply With Quote
Old 09-17-2016, 09:39 PM   #31
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
xD you know you want it just need a confirmation
turtlefeeder is offline   Reply With Quote
Old 09-17-2016, 09:47 PM   #32
BxrFnd17
I want to do so bad, I already have the springs. Might have to get them installed next weekend now.
Old 09-18-2016, 04:33 AM   #33
vincelive123
Drives: Scion FR-S
I had eibach lowring springs which lowered my car 1.6 down. Had no issues. Drove my car in almost 30 states. Also had 18x9.5 wheels all around....
vincelive123 is offline   Reply With Quote
The Following User Says Thank You to vincelive123 For This Useful Post:
Old 09-18-2016, 07:20 PM   #34
jxl00
Drives: scion frs 2014
does lowering the car make the car less tail-happy?
i'm thinking of getting TRD springs and getting them installed at a shop. i'm guessing 500 dollars total. is it worth it?
jxl00 is offline   Reply With Quote
Old 09-18-2016, 07:27 PM   #35
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The TRD springs actually keep the front/rear stiffness ratio (both are stiffer by the same percentage) so the rates themselves shouldn't change the car's balance.
However, I found that the rear picked up more negative camber than the front from the lowering. More negative camber in the rear generally helps keep the rear planted when turning.
Twinz is offline   Reply With Quote
Old 09-18-2016, 08:26 PM   #36
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Installed Pro Kit strictly for the fender gap and crossed my fingers about ride quality . . . which is actually better than stock for 90% of typical road undulations. But there is a noticeably harsher ride vs stock over the last 10% of the real nasties.
Handling - no difference for me.
geezerbrzeezer is offline   Reply With Quote
Old 09-18-2016, 09:41 PM   #37
Gunman
ARB's are your best bet if you want to tune the under/over steer of the car.
Old 09-19-2016, 01:39 AM   #38
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Norville Rogers View Post
On what car?
http://www.ft86club.com/forums/showthread.php?t=49511
ineedyourdiddly
Old 09-19-2016, 02:23 PM   #39
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Originally Posted by golemslord View Post
Was thinking of getting lowering springs either
Eibach pro kit
or
H and R sport springs
however been told by a mechanic saying springs have little to no performance increase and itll eventually blow the struts. My question is will the struts really die that fast and how long will they last with 1 inch lowering springs? I daily the frs and occasionally do spirited drives but no tracking at all. Thanks
I have the TRD springs, approximately 1 inch lowering. I really cannot tell the difference in ride and as others have mentioned, this is a dealer option that has no impact to warranty so I truly doubt there is any significant issue with the struts if installed properly. I installed these springs solely for cosmetic reasons and am quite pleased overall - I would do it again and have absolutely no regrets.
I never track this car - it is my daily driver with occasional spirited runs. If you do not track your car I doubt you will notice a difference on the street other than an improvement in the wheel well gap.
Good luck!
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
everythingsablur (09-19-2016), golemslord (09-21-2016)
Old 09-19-2016, 06:55 PM   #40
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
I just got Eibach's and I couldn't find a shop to install them for under $400 which I thought was crazy. After getting several ridiculous quotes I decided to try it myself, I'm not anything close to a mechanic and I'm glad I tried because it wasn't that difficult to do at home. I didn't have a spring compressor so once I got the struts out I took em to a shop and paid $20 to have them safely pop off the stock springs. Definitely worth it! The Eibach's are designed with the stock struts in the mind and the car looks fantastic now. Not too sure about the handling abilities yet.
DriveDriftDogfight86 is offline   Reply With Quote
Old 09-19-2016, 08:16 PM   #41
gramicci101
Off Topic
If you're doing it yourself, you don't need a spring compressor. You don't even need to completely remove the strut from the car.
Originally Posted by gramicci101 View Post
If you're only changing springs, not struts or coilovers, you only need to unbolt the top nut, the brake line clip, and the swaybar nut. The springs are on so little static load that you can unbolt the nut and let the spring decompress as you raise the car. You just need to be careful fishing it out of the fender. The only special tools needed are a pass-through socket set and long allen wrenches.
DIYs:
DarrenDriven's very comprehensive strut remove/replace DIY
http://www.ft86club.com/forums/showthread.php?t=10842
Jeebus' simpler spring remove/replace DIY (builds off of Darren's)
http://www.ft86club.com/forums/showthread.php?t=32414
Read both in their entirety before attempting. There is good info all through both threads.
Example:
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
Cole (09-19-2016), ShadowReaper (02-27-2021)
WTB: Lowering Springs pooch Want-To-Buy Requests 1 03-29-2016 12:50 PM
WTB trd lowering springs Heyitsryan Want-To-Buy Requests 0 07-20-2014 01:52 AM
which lowering springs should I get? abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 03:27 PM
WTS H&R Lowering Springs (Never used) g0ast Brakes, Suspension, Chassis 3 05-21-2013 12:34 PM
TRD Lowering Springs? kALMIGHTY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-29-2013 11:10 AM
