Old 09-15-2016, 08:49 PM   #1
golemslord
Drives: 2014 White FRS
Lowering springs bad?
Was thinking of getting lowering springs either
Eibach pro kit
or
H and R sport springs
however been told by a mechanic saying springs have little to no performance increase and itll eventually blow the struts. My question is will the struts really die that fast and how long will they last with 1 inch lowering springs? I daily the frs and occasionally do spirited drives but no tracking at all. Thanks
golemslord is offline   Reply With Quote
Old 09-15-2016, 09:00 PM   #2
gramicci101
Off Topic
Your mechanic is not a suspension engineer, and it shows.
There is a definite improvement over the stock handling. As with everything, there are trade offs. The aftermarket springs will have a firmer ride, even if it is more stable than OEM. Being excessively lower will put additional strain on the OEM struts, but this is really only an issue with the springs that lower 1.4". 0.7" from RCE yellows or 1 inch from several others won't be an issue. I've been on RCE Yellows and OEM struts for two years now with no issues.
Here's one catch though. Struts are wearing components and will eventually blow. A set of Bilstein B6 struts runs about $900, which means now you're into springs and struts for around $1200. You can buy several nice sets of coilovers for less than $1200, namely the Tein Flex Z, ST Suspension, and Bilstein B14. So do you commit all of the money now for coilovers, or some now for springs and some later for struts? Or some now for springs and more later for coilovers?
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
DriveDriftDogfight86 (09-19-2016), wparsons (09-16-2016)
Old 09-15-2016, 09:54 PM   #3
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Going to have to agree with your mechanic for the most part. Lowering springs aren't ideally matched to the stock struts and will always be a compromise. You can get away with them for a while, but you should replace your struts with better matched ones.
I had 25mm lowering springs from Mann Engineering and they blew my stock struts after 15,000 miles. Mann said that was even longer than they expected from their lowering spring.
Sure, stiffer feels better in the transitions, but ride suffers. Take a ride in a properly set up car and you'll get a better picture about what a car is supposed to feel like. Stiffer isn't always better!
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
The Following User Says Thank You to PandaBRZ For This Useful Post:
ShadowReaper (02-27-2021)
Old 09-15-2016, 10:23 PM   #4
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
Unless you buy lowering springs that are specifically matched to the stock struts, like the TRDs. Won't even void your factory warranty if installed correctly.
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
The Following User Says Thank You to everythingsablur For This Useful Post:
Toyarzee (09-16-2016)
Old 09-15-2016, 10:25 PM   #5
gramicci101
Off Topic
Or RCE Yellows. The OEM struts overpower OEM springs, so a slightly stronger spring works well with the OEM strut.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
smg1138 (09-16-2016), Toyarzee (09-16-2016), wparsons (09-16-2016)
Old 09-15-2016, 10:27 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Your mechanic is half right, half worng. But overall if he isn't actively on a race track I wouldn't agree with everything he says.
The problem he sees is high mileage cars that put lowering springs on old and tired struts. The loss in the support puts extra work. So yeah the strut would give out shortly.
Ideally you want new lowering springs and performance dampers when you swap it out.
In your case since you don't plan to track your car, you'll be ok. If your car has over 80k miles on the original struts then it might me a good idea to replace the struts. Also keep away form super low drops, they just add more stress.
I'll go with TRD springs or from what I seen they are rebadged Eibach pro kits
Old 09-16-2016, 09:25 AM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
If it is just a general mechanic don't listen, they are good for what they do but bad when it comes to performance modifications. Talk to someone who knows what you want to do, not to someone who just generally repairs cars.
And supposedly all lowering springs will increase the wear on shocks, but they will all eventually wear out anyways.
why? is offline   Reply With Quote
Old 09-16-2016, 10:49 AM   #8
wparsons
wparsons's Avatar
A mechanic friend told me I would ruin my tires by running more camber, he didn't have an answer when I showed him they were wearing better after going to -2.2* from 0*.
The big reason lowering springs get a bad reputation is twofold:
1) Cheap springs with rates that weren't tested against the stock shock rates.
2) People putting lowering springs on 10 year old shocks with 100k miles on them. Shock manufacturers typically recommend a replacement interval of about 50k miles. That's a guess at best, but if shocks have seen lots of miles they're probably due for replacement anyway.
I have almost 130k km's on my car, with at least 80k of those being on Swift sport springs. It's a true daily driven car, that has seen terrible roads (Toronto...) plus 30+ track days. The shocks are tired, but not blown.
flickr
Old 09-16-2016, 11:21 AM   #9
MeisterR
MeisterR's Avatar
Drives: BNR32
It is a very general statement, and alot of factors are involved.
Will a lowering springs destroy dampers right away? Highly unlikely.
But it will depend on the OEM suspension design.
If you don't have a lot of travel to begin with, a big drop will mean you will be running out of travel often, and dampers do not like that.
As for the little to no performance gain? Again, it depends on what you justify as performance gain.
Lowering springs will help reduce body roll a little due to the higher springs rate.
However, as the damper is still the same, your suspension actually isn't changing the way forces are applied to the tires.
So do you get "little" performance gain? Possibly.
Is it enough to justify it as saying it is true performance gain? That depends on the person you are talking to and how picky he is.
Jerrick
MeisterR is offline   Reply With Quote
Old 09-16-2016, 12:32 PM   #10
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
@golemslord, I was in the same boat as you when I first got my BRZ. I wanted to drop it about an inch, so I bought the Swift Sport springs and had them installed along with rear lower control arms (necessary for rear camber adjustment), front camber bolts, and got an alignment.
They were exactly what I was looking for. Mild drop, ride quality wasn't harsh, less body roll in corners - seemed pretty planted when taking turns. They seemed to perform just as well as stock...until I did some canyon driving and hit bumps and uneven pavement mid-turn. I first got the sense that the rear end was more 'floaty' than before when I hit a dip on the freeway going at around 70mph before I went to the canyons. The rear end wiggled and felt unsettled, and didn't inspire confidence.
Up in the canyons, every time I encountered mid-curve dips, the rear end wallowed and felt unsettled. I wasn't happy with the way it felt.
So, after some research on here, I went with the Tein Flex Z coilovers. One of the best decisions I made. Now I tell everyone who has the similar needs that I have, to skip the lowering springs and just go to something like the Tein Flex Z's if they're on a budget like me; you're not spending that much more, and you do get more for what you spend.
With the adjustable coilvers, you also get the ability to adjust ride height (which you can't with just lowering springs), corner balance, and vary the damping depending on the road condition. I typically drive it on 'soft' for daily street driving, but firm it up in the canyons and smoother roads. It now feels like I had expected it to feel. Much more stable and predictable in uneven corners, with a better (adjustable) ride quality than the lowering springs + stock dampers.
So for me, who doesn't track the car and only does occasional spirited canyon runs, the stock dampers + lowering springs didn't cut it. And I don't think I'm even that picky.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
RJasonKlein (09-17-2016)
Old 09-16-2016, 12:46 PM   #11
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Originally Posted by shiumai View Post
@golemslord
Your description of the downfalls of lowering springs on stock dampers is spot on. I can't believe I lived with them for a year lol.
After switching to AST coilovers, the ride was so much better and the car never feels unsettled.
If I could go back, I would have probably purchased Bilstein B8 struts to go with the lowering springs.
shiumai (09-16-2016)
Old 09-16-2016, 02:34 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There's a shitstorm of debate just a few clicks away about how in autocross the street class FR-S are allowed to use TRD springs and the BRZ's are stuck on OEM because it's a noticeable advantage.
Some people claim the TRD springs (and swaybars, FR-S can use OE sway, TRD sway, and one aftermarket sway, BRZ only get one aftermarket sway) give the FR-S as much as a 1 second advantage over a ~50s course.
Personally I'd try quality lowering springs and OE replacement dampers over most <$2k coilovers. Shit parts are shit parts, everybody is trying to make a buck and you can get shafted by a shift knob or a header or by the biggest names in the business.
On an 86 there's a couple options with good reputations for lowering springs, a couple bad ones, and a few in between. This is lucky, some cars only have one or two options with nothing standout and OE springs are actually more valuable than the aftermarket after the car is a few years out of production.
Dampers wear out, period. For the most part the OE units seem up to the task, only a few cases of early blowout. If you want to do it then do it, it won't blow your car up if you take your time and have it done right. And it's reversible, the best quality to look for in most mods.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Cole (09-17-2016), wparsons (09-16-2016)
Old 09-16-2016, 02:40 PM   #13
gramicci101
Off Topic
Can BRZs not use STI springs in CS?
Old 09-16-2016, 02:45 PM   #14
strat61caster
No as they are not a 'factory option' available in the United States. Those are actually JDM springs being imported in as far as I can tell. You might be able to make a case if you can order them through a Subaru USA dealer and installed by their service department, but as far as I can tell you can't.
Nevermind the fact that the TRD springs aren't a factory option either, they're dealer installed but Scion/Toyota USA installs them 'at port' 'before the car is delivered' and calls them 'factory'...
Point is the FR-S has a OE supported lowering spring in the U.S. and the BRZ doesn't. SCCA rules can be whack because they're written to classify 50 year old Mustangs alongside Chevy Vegas alongside brand new Focus RS and GT-R's and have a 'level' playing field after indexing. If they covered every case the rule book would be thousands of pages long.
ineedyourdiddly
gramicci101 (09-16-2016), wparsons (09-16-2016)
WTB: Lowering Springs pooch Want-To-Buy Requests 1 03-29-2016 12:50 PM
WTB trd lowering springs Heyitsryan Want-To-Buy Requests 0 07-20-2014 01:52 AM
which lowering springs should I get? abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 03:27 PM
WTS H&R Lowering Springs (Never used) g0ast Brakes, Suspension, Chassis 3 05-21-2013 12:34 PM
TRD Lowering Springs? kALMIGHTY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-29-2013 11:10 AM
