Old 09-12-2016, 02:22 PM   #29
Teseo
Drives: frs
Use energy drinks with boner pill and talk about sex machine
Old 09-12-2016, 02:30 PM   #30
Originally Posted by radroach View Post
@humfrz don't mix your blood pressure medication with your boner pills
No problem ...... I don't take the boner pills anymore ....... they quit working for me .....
Old 09-12-2016, 02:35 PM   #31
Originally Posted by FX86 View Post
might make a person go blind actually
Heck, I can't hardly see the way it is.
Plus, I need all the blood I have just to run my brain ..... and that is barely enough .....
Old 09-12-2016, 03:01 PM   #32
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
what wheels do you have OP?
Old 09-12-2016, 04:58 PM   #33
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
I'm not sure why, but this car feels MUCH wider than it really is when maneuvering around curbs and parking spaces.
Fishbed77 is offline   Reply With Quote
Old 09-12-2016, 10:00 PM   #34
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
My 2004 Audi A6 had a feature where the passenger mirror would tilt down as soon as the car was put in reverse. It was awesome for parking and you could see exactly how far you were from the curb or painted line. You could even adjust how far down you wanted it to tilt and each key fob memorized different driver preferences (as well as seating position etc). You really miss this kind of stuff when you ditch luxury brands, and you start to see why its worth the $$.
[ame="https://www.youtube.com/watch?v=xYl5wQB-OHM"]Audi A6 | Reverse Mirror Tilt. - YouTube[/ame]
headlikeahole is offline   Reply With Quote
Old 09-12-2016, 10:16 PM   #35
Maybe because our butts are only a few inches off the ground ......??
Old 09-12-2016, 10:26 PM   #36
stevesnj
stevesnj's Avatar
For passenger side parking nearest curb just point the side mirror down until you get a feel of the distance. Drivers side your sideview while reversing should be fine without moving down. In no time you will have it down without worrying. Practice Practice Practice.
My 2016 Build thread
Old 09-12-2016, 11:48 PM   #37
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Ruff Racing R364.
geezerbrzeezer is offline   Reply With Quote
The Following User Says Thank You to geezerbrzeezer For This Useful Post:
Teseo (09-13-2016)
Old 09-12-2016, 11:54 PM   #38
geezerbrzeezer
Geezer
I have a backup camera which makes reversing near anything easier. My main problem ironically is pulling over to curbs on the passenger side, which should be the easiest manoeuvre.
I'm starting to think it might be the very low driver position - I've got the seat 3 cranks up from the lowest point. I guess though I'd still rather be positive 12" away than negative 1".
Old 09-13-2016, 12:15 AM   #39
Here ya go, geezerbrzeezr ........ remember those ........
Old 09-13-2016, 12:42 AM   #40
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by Cole View Post
Funny you mention that, I can back my work truck (Silverado with the extra big cab and regular box) straight as an arrow. The FRS? Always off kilter. I think it's the paranoia of backing into the curb. The one time I pulled into a spot (that isn't the garage) was the day after I installed my splitter, I got out of the car, and there was maybe half an inch between the curb and my splitter. What a lucky day that was.
I had this same issue - I wonder if it was my side mirror setup (I had them angled out wide to cover the blind spots, which also made them useless for checking if I had backed in straight).
That's the only reason I'd want a rear-view camera (especially with exhaust and/or rear diffuser)
How does this work? Does it make a sound when it scrapes the curb? Does it hang out at all times?
Asking for a friend (yes, that should stick....)
daiheadjai is offline   Reply With Quote
Old 09-13-2016, 01:26 AM   #41
Yal
#subaruambassador
Yal's Avatar
Drives: Wheezy
my grandmother had those on her 64 Impala. Man, I'd love to have that car now.
Yal is offline   Reply With Quote
Old 09-13-2016, 01:36 AM   #42
....... I was just funnen ol @geezerbrzeezer.
Actually, they are (were) called curb feelers. They would transmit a screeching sound through the metal body of the car. Yes, they stuck out all the time.
Useful back-in-the-day for a car was lowered, chopped and channeled to protect the flipper hubcaps, port-o-walls, side pipes and rear fender skirts from curb rash.
The low rider behind the wheel, couldn't hardly see over the dash, let alone where the curb was .......
bcj (09-13-2016), daiheadjai (09-13-2016)
