go_a_way1
Old 08-31-2016, 01:49 PM   #3669
CSG Mike
CSG Mike's Avatar
Originally Posted by Khánh View Post
I'm looking to get jrsc in the future and if i have no symptom or code.. can I go to the dealer and have the ecu reflash before installing the jrsc? if not, what happen if I install and later down the road, this code shows up?
We recommend performing all TSB/recalls/services before installing your JRSC.
Old 09-02-2016, 12:26 AM   #3670
Khánh
Khánh's Avatar
Drives: sc00ter
what if there isn't any TSB/recalls before installing the kit on my car and the code shows up after like @etc.. what can he do to fix it?
Khánh is offline   Reply With Quote
Old 09-02-2016, 12:50 PM   #3671
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
If there is no TSB for it on your car... then it will not come up.
If you have a early model car, then I would contact your dealer to see if your car is affected.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
Khánh (09-03-2016)
Old 09-02-2016, 01:40 PM   #3672
LS1M
Drives: 2015 BRZ
This hasn't affected me yet, but let's say there's an update or some issue and I need to get my CPU flashed by the dealer. How does that work? Do I get him to flash it, then I flash my latest tune on top of it? Because the OEM tune will not work now that I have the blower installed.
-Mark
LS1M is offline   Reply With Quote
Old 09-02-2016, 01:56 PM   #3673
JDMChris
Drives: 2016
-Mark
You have a 2015, it won't have the issue.
If you have a early model car that has the issue and you didn't get it fixed before the SC, You will have to remove your supercharger, reflash to stock. Go to the dealer for the fix. Re-install the supercharger and reflash the SC Calibration.
Old 09-03-2016, 09:00 AM   #3674
indy
indy's Avatar
Drives: blue GT86, AT
my blower was dead...
I wrote in JR support, let's see what will say.
It was bought in April 2014, mileage 29000km.
the car goes without any problem, but the sound ...
indy is offline   Reply With Quote
Old 09-03-2016, 09:16 AM   #3675
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Wow clean your engine!
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 09-03-2016, 10:36 AM   #3676
indy
indy's Avatar
already done)
The Following User Says Thank You to indy For This Useful Post:
Bramick (09-03-2016)
Old 09-08-2016, 09:33 PM   #3677
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
Help! I have one of the first ever jrsc kits on a '13 and was running great until last month when it threw a CEL. I cleared it but the code came back about a week ago (system too rich, forgot the #). Car seems to be running fine except I can't use cruise control and traction control has been coming and going. The blower started whistling on cold start today that went away after a minute (twice). Any suggestions about where to go from here in southern California? I've tried emailing CSG and Jackson tech support and don't yet have an answer. Help please!
hamlet is offline   Reply With Quote
Old 09-08-2016, 11:30 PM   #3678
CSG Mike
CSG Mike's Avatar
Have you scheduled an appointment to get the car checked out?
Old 09-09-2016, 12:21 AM   #3679
hamlet
Haven't made appt because you stopped responding to my pm's Mike. I'm free Monday at noon and Tues at 10
Old 09-09-2016, 03:38 PM   #3680
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
I've finally decided on this kit after reading every single post here. Christ.
60k miles on a '13 limited. Thinking about doing a coolant flush, (just did the trans and diff last year with motul), new spark plugs, make sure the ecu has the latest revision, pads, rotors, fluids .. anybody ever boost an FA20 with around the similar mileage? Any other preventative maintenance I should bang out of the way first?
Jesse36m3 is offline   Reply With Quote
Old 09-09-2016, 08:15 PM   #3681
JDMChris
Drives: 2016
You will be fine!
Old 09-09-2016, 08:17 PM   #3682
Bramick
Bramick's Avatar
Call CSG and get on their schedule
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
