Pat.Thornton
Old 08-26-2016, 04:48 PM   #449
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
Between the first time you took in the car to them telling you "it's not the lube," how long did it take? Minutes, hours?
Again, I'm going to ask to see it and see if they'll lube it again just in case
SuperDave is offline   Reply With Quote
Old 08-26-2016, 05:13 PM   #450
shellslinger
Drives: Whiteout FRS
My squeaky clutch came back after 30,000 miles since they fixed it. I lubed up the clutch fork. The clutch fork was extremely dry so I thought, "Ah that's gotta be it!". But nope, kept on squeaking for another 2 weeks. So I thought the worse and bought a new Stage 1 Exedy Clutch thinking it my TOB was done for. Well it turns out this week the squeak went away and the clutch pedal got super smooth. WTF
BTW I used that Lucas Red 'N Tacky #2.
shellslinger is offline   Reply With Quote
Old 08-26-2016, 06:41 PM   #451
Originally Posted by SuperDave View Post
3-4 hours
Hmmm... the plot thickens. Well, definitely don't mention my namecalling and rush to judgement.
That would have been enough time to pull the transmission and actually inspect.
Old 08-26-2016, 06:44 PM   #452
Exactly which points did you lube? Mine started acting up at about 20,000 miles, IIRC.
Old 08-26-2016, 07:50 PM   #453
shellslinger
I lubed up as much as the metal rod as I could see. I had my brother step on the clutch and pulled back the rubber cover and lubed it generously.
Old 08-31-2016, 09:26 PM   #454
shellslinger
Just wanted to update everyone. After lubing up my clutch fork the noise never came back and the pedal is as smooth as ever.
The Following User Says Thank You to shellslinger For This Useful Post:
humfrz (09-03-2016)
Old 08-31-2016, 10:11 PM   #455
Is there a DIY thread on this procedure .. ??
If not, what is the procedure .. ??
TIA
Old 08-31-2016, 10:26 PM   #456
shellslinger
TIA
I just followed these procedures from here:
http://www.ft86club.com/forums/showthread.php?t=99578
humfrz (08-31-2016)
Old 09-01-2016, 11:24 PM   #457
SuperDave
SuperDave's Avatar
I wasn't able to get photos of anything but the throwout bearing but they replaced everything in the clutch assembly. The clutch is ridiculously light now and smooth as butter!
The Following User Says Thank You to SuperDave For This Useful Post:
Stang70Fastback (09-01-2016)
Old 09-01-2016, 11:27 PM   #458
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Sounds like me. When I got mine back two weeks ago the clutch pedal was so light it really caught me off guard. It's been two weeks now and it STILL surprises me every time I get into the car.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Bach415 (09-01-2016), SuperDave (09-02-2016)
Old 09-01-2016, 11:39 PM   #459
Bach415
Bach415's Avatar
Does the squeaky clutch pedal happen for you guys on a cold start or does it come after driving a while?
Bach415 is offline   Reply With Quote
Old 09-02-2016, 12:07 AM   #460
shellslinger
Usually after driving around a bit.
The Following 2 Users Say Thank You to shellslinger For This Useful Post:
Bach415 (09-02-2016), Stang70Fastback (09-02-2016)
Old 09-02-2016, 12:59 AM   #461
Stang70Fastback
A.K.A. Starlord
Same. It only really did it once warmed up.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 09-02-2016, 02:12 AM   #462
SuperDave
SuperDave's Avatar
mine happened all the time, and my throwout bearing looked "perfect" according to my advisor and the clutch was good to go, but they replaced it anyhow.
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
