#15 |
Drives: Toyota GTS 86
We are going back to preparation and have a look underneath the boot, where we removed the boot lock plastic cover.
There is a reverse cable (positive) that we will have to tap into. At start of thread the video link "Tail as Turn™ + Backup LED Module for Scion FR-S, Subaru BRZ" by Diode Dynamics also shows which wire to tap into. Their car is FRS. Mine is a right-hand drive Australian market, Toyota GTS 86. The other video by SLOPOK's BRZ, mentioned and pointed at the same place. Luck have it that cable colour looks similar plus in the same lead position; cable is arranged so looking down the top of the plug as shown, the blue-greenish cable, the one towards the back of the car is the one I tapped into; yellow eclipse. You may do your own testBut for me it was a risk I took ... gamble, assuming the reverse positive lead goes into that male connector at the same pin position. This seems to be the case for the
If somehow your lead and pin position is different from ours, so made a mistake. Solution:
Disclaimer: Please do your own research, study and make your own decision. Your car, year, model and market location may be different to mine so if you choose to proceed you do so at your own risk, I can not be held responsible as to why your car is different from mine. Last edited by jliongh; 08-02-2016 at 11:47 PM. |
#16 |
Make a special joined cables of 2 unequal length and 3 connectors
Measure & cut the lines We measure from the place for tapping the reverse cable to the tail-light compartment, make sure you give the new cables enough slack so there is no stress, you may trace the OEM lines from below the boot mat as it goes up towards the compartment again add plenty of slack as you may be working on the lines or tucking it away in a way that you may not have thought of initially.
#17 |
Procedure 2 Your mod. is about to be completed. Our final work is to tap into the reverse cable with the "cable power take off (scotch lock)". Caution: You are drawing more power out of the reverse circuit. Use only LED switchback on the signal socket together with the LED for the reverse light in the original lower reverse light compartment; do NOT use any incandescent "reverse" globe in this system! The same caution was given in the "Tail as Turn™ + Backup LED Module for Scion FR-S, Subaru BRZ" video by Diode Dynamics. It is ok to use OEM 7440 amber globe as it will Not draw power when car is reversing. The photos are self-explanatory. Since we have only 1 leg of the 7443 female socket left, connect your special cable to that final conductor, one to each tail-light compartment as you had measure and cut them. Advice: use the "combination plier" to crimp the scotch lock, so make sure its contact is firm and the external plastic coupling is real tight. The final test is to see if the reverse light works on the switchback and if the indicator still works after the connection... just to make sure
#18 |
Mod completed Items cost: 2x 7443 sockets = AU$3.11 2x 7440 male wiring harness retrofit = US$6.99 100x copper 2.8mm female spade crimp terminals 22~16AWG 0.5mm connector = AU$2.79 100x 2.8mm male spade red crimp terminals = AU$4.95 10x cable power take off (scotch lock) red = US$1.29 10m 22AWG red wires = AU$4.79 7 Die Quick Change Ratchet Crimper & kit = AU$120 (Not counting the crimper if you have it) 2x reverse signal switchback LED White/Amber 7443 (22x 5730 SMD, half amber and half white) = AU$12.22 Unfortunately the amber turn signal is Not bright enough during day time, they are not as bright as the OEM incandescent. Therefore I may go into what I have researched but not as yet tested.Overall this mod could be cheap or expensive depending on what you have. Congratulation for those who implement this modification, you will have the brightess reverse light ever for the 86/FRS/BRZ ! Bad luck for the newer version of our car from 2017 onward, their tail lights are LED including signal but at present they do Not seem to have a place to add a bright reverse light Hey IMHO you will one day make other upperty 86 owners envious when you unintentionally went reversing, the brightness! And there show off your bright reverse light and when they figure it out... they will think what about their expensive LED tail light, how it compare to your simpleton down-to-earth OEM old tail light... Not as useful in the dark when reversing, ah sorry that is beauty without overall fundamental (reverse) use; in your case your tail lights are still the 86 beauty yet hidden with an exemptional talent & purpose!
#19 |
Switchback 7443 socket (amber/white) If you just want a brightest switchback without trouble and money is not much of an issue, I recommend you buy it off reputable sellers. At present, I did a quick search and found http://www.saving-star.com/smd-led-comparison/ Looking at its SMD chart (assuming trustworthy) With my layman understanding, a few possibility:
#20 |
54x 4140 SMD switchback arrived and installed
Summary of finding of this switchback The signal light is much brigter than the OEM incandescent globe, it is bright even in day time however the colour is like wash out yellow, Not orange or amber like the OEM.Photos
#21 |
Disclaimer: I am only sharing what I have done, I am not responsible for any damage or injury associated with releasing these information and no harm is intended. If you attempt the modification, you do this knowing you are fully responsible for your own decision and its consequences.
Thank you for reading; this mod post is complete. Content may change due to correction or updates. Last edited by jliongh; 09-04-2016 at 07:41 AM. |
#22 |
Someone private message me concerning my front signal LED which I claim (above) to be brighter than OEM incandescent, the LED is Amber only and Not a switchback. So here is a short review:
Amber LED 7440 W21W T20 21x 3535-SMD CREE Total price I bought AU$33.94 (from ebay Hong Kong seller, China) Note I am not sure if the advertiser is truly selling CREE, indeed the LED is incredibly bright even in day time, it is definitely seem to me it is much brighter than the OEM incandescent!
| Tags |
| brightness, mod, reverse led, switchback, tail light |
| Switchback LED turn signals (white/amber) + Relay | FRSpdDmn | Exterior Parts (Aero, Lighting, Etc.) | 11 | 08-02-2013 11:23 AM |
| ***FR-S/BRZ LED Turn Signals (6K WHITE/AMBER FOR TURNING, NO HYPER FLASHING!)*** | Vicious LED | Exterior Parts - The Rest | 7 | 11-02-2012 10:05 AM |
