Old 08-21-2016, 02:56 AM   #7463
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by camelflage View Post
anyone get to 240/250hp on a 210 unit without e85? for some reason 335i drivers want to be fucbois around me lately and i know at 200 ive still got nothing for them..
With my 210, I'm at 250hp with 92 octane with the 70mm pulley and intercooler. My old neighbor had a 335i and was impressed I pulled away from him.
Old 08-21-2016, 11:26 AM   #7464
camelflage
Drives: pinto power
Sent from my HTC6500LVW using Tapatalk
camelflage is offline   Reply With Quote
The Following User Says Thank You to camelflage For This Useful Post:
stockysnail (08-21-2016)
Old 08-22-2016, 12:26 PM   #7465
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Anal0g View Post
Not sure if what Zach said a while back is still applicable, but if it's still the case then tune wise I think people w/ 2015+ are covered. What I'd like to know is 2015+ owners w/ the 210 kit would fail simply because of the technicality of the MY not being listed on the EO.
They decided to do things a bit differently than originally projected, and afaik now Sprintex does not have a CARB EO, and Innovate will not support/provide it any longer.
-Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Anal0g (08-22-2016), Dream20b (08-23-2016)
Old 08-22-2016, 01:42 PM   #7466
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
-Zach
So is this kit still an option in 2016?
Votlon is offline   Reply With Quote
Old 08-23-2016, 02:02 AM   #7467
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
So far it just sounds like Cali is a horrible place to own a FI 86.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 08-23-2016, 05:33 AM   #7468
sam69
Drives: GT 86
Originally Posted by Dream20b View Post
244/214 on 93, heartbreaker dyno. This with the 80mm pulley 9:1 compression, minimal timing advance. didn't get the e85 tune in yet.
Any further updates on this Dream20b hoping you get alot more out of it .
sam69 is offline   Reply With Quote
Old 08-23-2016, 09:09 AM   #7469
Dream20b
Y u do dis?
Other tune scheduled for the 6th of September.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 08-24-2016, 11:54 PM   #7470
yip
Drives: 1997 Chevy S10
Just picked up a 335 kit and about to order dw700 injectors, dw300c pump and a flex fuel kit per Moto-Mike's recommendation.
Going with this kit seemed like a no brainer after driving a JRSC C30 & C38 setup.
Fuggin excited!
yip is offline   Reply With Quote
The Following User Says Thank You to yip For This Useful Post:
riboyster (08-25-2016)
Old 08-25-2016, 02:42 AM   #7471
riboyster
riboyster's Avatar
Fuggin excited!
Budget for stronger internals in the near future, and have fun!
Does anybody know of a good silicone sealant/adhesive that can tolerate temps on the intake tube?
Would rubber cement melt? Car pulled some timing recently (i suspect bad gas), and I want to be sure the teeny bit of air making it through my WMI port isn't the cause.
The Following User Says Thank You to riboyster For This Useful Post:
Dream20b (08-26-2016)
Old 08-25-2016, 07:24 AM   #7472
Votlon
Votlon's Avatar
When in doubt duct tape!
Old 08-25-2016, 07:25 AM   #7473
riboyster
riboyster's Avatar
No! Lol
Old 08-25-2016, 06:48 PM   #7474
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Afternoon All,
A generous member is parting ways with his 210 non-intercooled setup so that I can jump on the FI bandwagon.
I've done research on the kit and read through a lot of this thread but still have thoughts I'd like to share with the masses:
I live in Indiana where the weather is not too hot and thus plan to run non-intercooled for the time being. The kit is being shipped to me with the 69mm pulley -- It looks like it may not be the best idea for me to run the 69mm pulley without an intercooler due to heat soak. I'll be running on 93 octane (no E85 in area at moment). It doesn't look like its easy to find the 75mm stock pulley, but I do see the 72.5mm raceseng pulley available in a few places. Would I be OK to run the 72.5 on 93oct while non-intercooled?
I may eventually spring for the intercooler, but want to keep the power down in general, as I'm not sure how much I trust my 2013's rods at 35k miles. And i'm new to the FI scene for the most part -- I want to start small. Thoughts?
ajcarson11 is offline   Reply With Quote
Old 08-25-2016, 07:02 PM   #7475
riboyster
riboyster's Avatar
Originally Posted by ajcarson11 View Post
Afternoon All,
Hey bro. I happen to be running the 72.5mm with no problem, at an average outside temp of 85. My tune is stage 1 by delicious tuning. So I can only speak from my experience with that tune (kinda conservative for obvious reasons).
Keep in mind that most tuners would reccommend that you don't.
I'm also at 35k miles.
ajcarson11 (08-25-2016)
Old 08-25-2016, 09:35 PM   #7476
ajcarson11
Thanks! I'll see if i can get ahold of a 75mm...
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
