Old 08-23-2016, 03:54 PM   #1
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Coolant Swirl Pot
Has anyone installed one of these on a 86 ?
I used them on my 240sx with both the KA and the VQ35 and it made a noticeable improvement in temperature stability and lower temps as well.
irax is offline   Reply With Quote
Old 08-23-2016, 04:38 PM   #2
Well, no.
Is this for grins or is it for real ??......
Old 08-23-2016, 05:04 PM   #3
irax
irax's Avatar
Well, no.
I take it you never used one before.
Old 08-23-2016, 05:10 PM   #4
FX86
I'd like a blue raspberry slushie...how much?
Old 08-23-2016, 05:13 PM   #5
johan
Drives: '14 981CS, '99 NB1
I've not used one before on the main coolant system of a car, but I have used them in aftermarket A2W Supercharger Aftercoolers. They are a key element in achieving maximum efficiency in them. I've been surprised by the supercharger manufacturers for this chassis overlooking that detail.
It would definitely be interesting see how incorporating one might affect the stability of temps in our car.
@VeloxEric any thoughts on this?
johan is offline   Reply With Quote
Old 08-23-2016, 05:29 PM   #6
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Swirl pots are generally used when there is no other easy place to fill the car from. Sometimes on cars, the radiator, hoses, etc all are lower than the engine and leave few places to fill the cooling system from while getting all the air out. Enter a swirl pot, which can grab a pressure and suction from anywhere in the system (typically pressure from the head or a high point) and allows the system to "burp" itself from air.
Is a swirl pot a superior system to non-swirl pot. Yes... slightly. Swirl pots typically see less pressure spikes than caps placed directly on the radiator or hoses (stock configuration for our cars). These pressure spikes can cause the overall system to run at slightly less pressure than designed or "pop off" before desired.
Do I think a swirl pot would benefit our cars? Not enough to matter in my opinion. Our system is easy to bleed out all the air.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
BRZ68 (08-25-2016)
Old 08-23-2016, 05:59 PM   #7
johan
Thanks,
Eric
I remember our favorite feature of the swirl pot - the ability to stuff ice cubes into it in between passes
Obviously not something you'd be doing with the main coolant system on the car - but great for charge air temps
Old 08-23-2016, 06:56 PM   #8
Well, yes, I had to use a swirl pot when I was a kid, back in West Virginia, while visiting my cousins (they didn't have indoor plumbing).
The Following 5 Users Say Thank You to humfrz For This Useful Post:
15limited (08-26-2016), chaoskaze (08-24-2016), gramicci101 (08-23-2016), JazzleSAURUS (08-24-2016), Ultramaroon (08-30-2016)
Old 08-23-2016, 07:30 PM   #9
gramicci101
Off Topic
Did they not have indoor plumbing, or was this before it was invented?
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 08-23-2016, 07:41 PM   #10
As I recall, some of the rich folks in NYC had it ......
15limited (08-26-2016), NyC Zn6 (08-29-2016)
Old 08-23-2016, 07:46 PM   #11
DJCarbine
Thupercharged
DJCarbine's Avatar
So from what I can gather, the swirl pot can help with self-bleeding the system should you develop any hot spots that could boil coolant and create an air pocket.
If that happens or it is difficult to bleed the system, it should help.
Is there increased potential for coolant aerating with a swirl pot if the level dips a bit too low?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-24-2016, 12:11 PM   #12
irax
irax's Avatar
Oh, I'm sorry. How does it feel to finally use electricity and this new thing called the internet.
No, its design removes the air bubbles and cavitation. But if it were to run low, there would be other problems.
Old 08-24-2016, 01:53 PM   #13
Yep, this indoor plumbing is really neat. Going out to the outhouse in the winter was a chilling experience. In the summer it was the spiders and the smell that wasn't pleasant.
The electricity is nice ..... I tired of filling the coal oil lamps.
Internet .. ?? Is that what this dial up plug hooks up to ......
Old 08-24-2016, 02:19 PM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
It seems that since we have the cap off the rad, and up a bit, the difference would be very minimal, and a proper fill/bleed would be about as effective, (close enough to not make a difference.)
In my GD Subie it has an expansion tank up top which seems to be another step closer to a swirl pot.
JazzleSAURUS is offline   Reply With Quote
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Help on Swirl marks on my new FRS xcooperx Southern California 9 02-10-2015 06:36 PM
Aubody Swirl Marks aakash Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 04-20-2014 05:41 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
swirl marks jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 31 07-12-2012 09:33 AM
