#2983 | |
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Bramick (07-26-2016) |
#2984 |
Drives: CRV AWD 5MT
Hi. Im new here. Recovering S2k/Honda guy. Three questions:
1-Is it a common practice to disconnect the rear sway on this car to take advantage of more active droop? 2-what is the ideal droop (or "sag" in the motorcycle world) for this car on say, 7k springs with -20mm static ride height for the street? 3-On my RSX-S I rotated the front camber plates 90 degrees and set the shafts at the very back of the slots to achieve more caster (or more correctly SAI) and then just used crashbolts to get the negative camber i needed. Granted these are RWD and outside of tight AX, perhaps more caster isn't needed as badly, but has anyone here experimented with this (or is it even possible for the bolt pattern of the strut mounts?) Thanks!!!!!!!!!!! I hope i haven't stumped you!!!11
#2985 | |
The Stig's German cousin
2. No idea, sorry. I worry more that available travel is enough, how I get there is secondary. 3. Oh, you had a Type S and tried to better the suspension? Sorry to hear. Certain camber plate options for the FRS allow you to mount different ways to make camber or caster adjustable, while making sure the static setting is as large as can be. Nearly everyone I know prefers to use the plates to adjust camber. I think with crash bolts plus a shock with slotted mounting holes you can maybe get enough camber, but it's doubtful in my opinion. The geometry just isn't very friendly to that approach.
| The Following User Says Thank You to renfield90 For This Useful Post: | prj3ctm4yh3m (07-30-2016) |
#2986 | |
Drives: '13 FRS - STX
2. As above, I don't think about suspension setup that way and I don't think many around here do. We generally set static ride height as desired and the rest of the suspension lands where it does. I can't really wrap my head around the preload/height adjustable setups, seems to me you'd always maximize travel in the needed direction (on this car, compression) and set your ride height as desired via spring perch height. Sorry that's probably not helpful, I feel like I'm trying to mime a different language on that one, hopefully someone understands your perspective better. 3. I made a post about that over here: http://www.ft86club.com/forums/showt...=1#post2713773 You could, but the car wants more camber. |
| The Following User Says Thank You to strat61caster For This Useful Post: | prj3ctm4yh3m (07-30-2016) |
#2987 | |
Drives: CRV AWD 5MT
those rear control arms were a joke. no doubt about it. |
#2988 |
Drives: CRV AWD 5MT
Are Roll Center Adjusters (taller lower frt ball joints) beneficial on this car at a 20mm drop?
#2989 |
#2990 |
Drives: brz
I am currently using rsr club racer suspension. And i am thinking to change to rce t2 cause of 2 way ... is there real benefits on the track??before i dont wanna get the t2 cause i am thinking 2 way is hard to set up..but now i think 2 way is a lot better on track??thank for all the reply
#2991 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
@Racecomp Engineering since I know you guys are proponents of the rear UCA bushings can you guys confirm of they are STX legal for autox (ie no more metal then stock)? I dont have the stock bushings anymore to do a side by side comparison.
#2992 | |
#2993 | |
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | finch1750 (09-02-2016) |
#2994 |
No prob. I know the mentions dont always work. Thanks!
#2995 |
Drives: 2014 BRZ Limited
Looking for a quick explanation since I'm a noob.
At the track through hard corners I feel as though I cannot take them as fast as other 86 guys (using AIM solo data) without losing grip from the initial load transfer left to right or right to left (250lbs/in spring rate). Without changing the springs/shocks themselves, what would happen if I increase the strength of my whiteline front and rear sway from soft setting to hard setting? Would I lose my mechanical grip? Would it theoretically benefit me? |
#2996 | |
Drives: GT86
250lb springs are pretty soft for track use so you probably are getting a lot of weight shifting around. When I was on tein flex a's with 6kg (350lb) springs I ran the rear and front Whiteline bars on their stiffest position but still found it a little soft. |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
