go_a_way1
Old 08-16-2016, 09:02 PM   #3627
snowdog
Drives: 2013 Scion FRS
Update on sound from the engine bay. I believe it is coming from one of the idlers. Anyone think why this may be.
snowdog is offline   Reply With Quote
Old 08-16-2016, 09:03 PM   #3628
snowdog
Finally a legitimate use for a selfie stick
The Following 3 Users Say Thank You to snowdog For This Useful Post:
CSG Mike (08-17-2016), Pat (06-26-2017), PikachuBRZ (01-23-2023)
Old 08-17-2016, 04:45 AM   #3629
FRS Justin
Drives: 2013 Asphalt FRS
Idler noise has my vote, quick test wd40 and see if it changes. Go easy don't douche it....... It wont fix it but it will change to diagnose or if your brave enough get a long rod or screw driver and put it on the bolt and the other end on your ear you will hear it if its a bearing.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
snowdog (08-17-2016)
Old 08-17-2016, 10:49 AM   #3630
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
280whp. Who is doing it with the c38 kit on 93? I find it really hard to believe people need e85 to get near that. Most turbo guys are running 300-325 on 93, before having to go e85 for higher power levels.
If I spend 7k to get this kit installed and tuned right... And have 240whp... I'ma lose it.
I run a couple dozen hours at the track a summer, I'm looking for a SC kit because I would like to maintain stock power band like charteristics.
@Jackson Racing
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 08-17-2016, 01:01 PM   #3631
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
@Jackson Racing
Where did you get 240whp? Obviously dyno's read differently, but percentages will always be the same. a 45%-50% increase is what you can expect. The dyno's on the Jackson Racing website show increase from 186-282. That is also 100% stock, no mods, on the CARB calibration. After HP numbers can only show so much, without the before.
JDMChris is offline   Reply With Quote
Old 08-17-2016, 03:28 PM   #3632
CSG Mike
CSG Mike's Avatar
@Jackson Racing
Every dyno reads different.
I dont think you'll be losing it when the turbo guys are going home on a tow truck, and you're not.
FRSBRZGT86FAN (08-18-2016)
Old 08-17-2016, 03:32 PM   #3633
_Se7en_
Drives: Whiteout Scion FR-S
For comparison....
Mustang dyno
Dynapack
Same mods, different dyno, different day. Readings are vastly different depending on dyno.
This is E85 with C30.
Sent from my SM-N920T using Tapatalk
_Se7en_ is offline   Reply With Quote
Old 08-17-2016, 11:29 PM   #3634
snowdog
Ok, so I did determine that the sound was not coming from any of the pulleys. My thought now is that it is coming from the intake, which makes me think it is the Rotrex unit. Can anyone confirm if this is a normal Rotrex sound? Maybe I am just being paranoid.
Old 08-18-2016, 12:46 AM   #3635
TouchMyHonda
Vtec Jesus
Ok, but I'm looking for just under 300 whp. 275-280 would make me happy. That's the power I'm looking for. Sure every dyno reads differently, I understand that. Most dynos around here are dyno jets, and mustangs. I know the mustang would read lower.
I'm looking to have this tuned on a dyno, and not use an e tune. Have you seen people with this power range, and do you have an ideal of what's needed to achieve this?
Old 08-18-2016, 01:06 AM   #3636
enivid
enivid's Avatar
Drives: WRB JR BRZED
Go get a baseline dyno on your car now and the you'll know.
Sent from my Nexus 5X using Tapatalk
enivid is offline   Reply With Quote
Old 08-18-2016, 01:29 AM   #3637
TouchMyHonda
Vtec Jesus
I don't see how that helps me with my question. I get that would give me a comparison to an extent. I'm probably making 190-200whp now and I would like close to 70-80 more whp. Are you running closer to the 300whp mark? If so, what cocktail did you use to get there with 93?
I'd like a specific power to weight ratio.
Old 08-18-2016, 02:53 AM   #3638
CSG Mike
CSG Mike's Avatar
You're being told to go get a baseline, because we need to know how your local dyno reads, to understand what your version of "just under 300whp" really is.
If you're talking flywheel horsepower, I can tell you exactly what you need, any time, any day.
I need to know how YOUR chosen dyno reads, to get you to YOUR horsepower goal.
What does that local dyno read for a 100% stock FRS, in 5th gear, with a MT?
Old 08-18-2016, 03:58 AM   #3639
Dru670
Drives: 2016 Scion FR-S
A butt dyno usually gives you greater results than the other dynos lol
Dru670 is offline   Reply With Quote
Old 08-18-2016, 08:37 AM   #3640
TouchMyHonda
Vtec Jesus
My last car had well over a hundred pulls on a dyno. I understand what a dyno is.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
