Old 08-09-2016, 09:23 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by canadaRS1.0 View Post
wouldnt stiffer sway bars help prevent the torsen diff becoming "open"? by preventing body roll, you would keep the weight more evenly distributed between the tires and help prevent one from lifting, no?
To a point, then when your suspension becomes too stiff you are more likely to lift a wheel as posted above, kind of like lifting the corner of a sheet of paper vs. lifting the corner of a sheet of cardboard.
Think of it as an inverse, when you lift a corner of a sheet of paper it's like pushing down on the suspension, paper soft, the other 3 wheels stay where they should, cardboard stiff, the other wheels begin to 'lift' as well, in reality the corner you lifted is being super compressed the car is hunching down on that corner and the opposite corner (still on the table) is actually 'lifting' up in the air. In autoX the outside front tire takes a ton of load as you hunker down on it to turn, the inside rear wheel lifts.
But you have available to you what you have available to you, I say try going back to OE front bar, they're not that difficult to swap. iirc most are running stiffer rear bar in CS w/ OE front.
FWD cars usually end up running soft fronts and stiff rears, this is the result:
AND as another example, in oval racing the cars get setup the opposite way with relatively soft rears the car hunkers down on the right rear and the left front lifts. You can also see it in certain road course series too.
ineedyourdiddly
JazzleSAURUS (08-16-2016)
Old 08-10-2016, 09:41 AM   #16
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
What? Who is?
I'm bigger in the front, with a Hotchkis bar and TRD in the back, and love it. The OP should check out the CS thread if he hasn't already. http://www.ft86club.com/forums/showthread.php?t=35855
With a similar background in cars, my initial impression of the FRS was that it was friendly and maybe even dull. I never spent a moment on the stock tires though...
Cueman is offline   Reply With Quote
The Following User Says Thank You to Cueman For This Useful Post:
strat61caster (08-10-2016)
Old 08-14-2016, 08:48 PM   #17
Skurj
Drives: SOLD...
I was experiencing this 'shudder' at canadian nats (and not the only one) I've never experienced it elsewhere. I attribute it to the surface and my overdriving the car. I had the whiteline front bar on full stiff which certainly didn't help (rest is stock in CS).
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 08-20-2016, 03:19 PM   #18
EN2_Squirrel
EN2_Squirrel's Avatar
Originally Posted by Twinz View Post
Do you have any video of this happening where we can also see your steering inputs?
I just did my first autocross with the FRS prepped for CS and found that my first guess at sways and alignment produced considerably more understeer than stock. I was able to play on a traction circle and drive another twin for comparison and the car itself (my car) understeers.
That being said, I did not experience any shudder, so I'm wondering about your steering angle when this is happening to you. I suspect wrenching on the wheel while the car is understeering (as apposed to just lifting to tighten your line) might cause hop, but I'm unsure.
BTW, for any setup gurus, this understeers now:
TRD springs and sways
Koni shocks
Front:-1.3, 1/16" toe out
Rear: -1.8, 1/16" toe in
I am considering either going back to stock bars front and rear, or maybe even just back to stock bar front. (leave TRD sway in the back)
All the CS guys I know have close to -2F/R and the same toe and are legal. They also have koni shocks with the insert, as well as the TRD springs and sways. that setup on re71r's is very good.
as for your alignment. the rear will have more grip in the corners. so when the front grip runs out, rear grip is still there= understeer. I play in SM with mine.
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 08-20-2016, 07:28 PM   #19
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I would like to know how people are getting -2 degrees front camber in CS. I know there is a little variance from car to car, but that's a big gap.
My best guess at the TRD sways is that the front is ~70% stiffer than stock where the rear is only ~40% stiffer than stock. (Understeer)
I installed an ST front bar this week and used the softer setting (~40%) I'm hoping that the sway bar balance is stock-ish now. (-Feels better on the street, but I won't know if it's enough until I run it at 10/10 on the track)
Twinz is offline   Reply With Quote
Old 08-21-2016, 01:02 PM   #20
EN2_Squirrel
Contact Infinite Motion in San Marcos CA. GAVIN does all the alignments. He must have figured something out.
LA Auto Show 2015 KR-S Southern California 10 12-01-2015 06:19 PM
Oft 2015 auto on e85 Abe1120 Software Tuning 1 09-19-2015 05:47 PM
2015 Official 8/6 Day At Mod Auto and ModBargains continuecrushing Southern California 119 08-10-2015 11:25 PM
Alignment settings for Auto club speedway ddeflyer Tracking / Autocross / HPDE / Drifting 12 07-08-2015 09:10 PM
My Opinion of a 2015 FR-S Auto Ddreder Scion FR-S / Toyota 86 GT86 General Forum 33 04-06-2015 11:04 AM
