Old 06-18-2012, 12:56 AM   #15
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Writeup!!
Lee358 is offline   Reply With Quote
Old 06-21-2012, 05:49 PM   #16
Cornerman
Drives: 2013 WRB BRZ
Originally Posted by sportsguy83 View Post
I will pull out the Nav assembly on Tuesday to try and find the ground cable.
Any luck finding the ground? I am hoping to do this mod myself when I find the time...
The Beauty of Rear-Wheel Drive
2013 WRB BRZ Semi-automatic
2011 WRB WRX Sedan (sold)
Cornerman is offline   Reply With Quote
Old 06-21-2012, 08:55 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I actually did not have time, (working 72 hours a week) but I tried doing some test, and I think grounding the e-brake will not accomplish what I want, which is full functions of phone while driving. I think this is GPS based, so as soon as the car gets moving, the phone capabilities are limited, it doesn't matter if the e-brake is engaged.
Old 06-22-2012, 12:19 AM   #18
xcelir8brz
Drives: 2013 BRZ Limited
The ground is on 10-pin power/speaker harness...
12--34
5678910
Pin 7 is Ground.
I just cut the grey wire on the 16-pin rear camera socket (i.e. where the e-brake lead is), and extended the wire from the stereo side connector to the above pin 7 and electrical taped the far side grey wire so as to not short out anything.
xcelir8brz is offline   Reply With Quote
Old 06-22-2012, 11:18 AM   #19
Cornerman
Good info! Does this allow you to play video from USB while moving?
Old 06-29-2012, 09:18 AM   #20
xcelir8brz
Yes.
Old 06-29-2012, 09:35 AM   #21
xcelir8brz
Subaru BRZ Limited Wiring Diagram / Fujitsu Ten Head Unit
1 2 - - 3 4
5 6 7 8 9 10
(orientation: viewing pins on car's factory plug, wires pointed away from you)
Code:
1 RF+
2 LF+
3 +12V Accessory
4 +12V Battery/Constant
5 RF-
6 LF-
7 Ground
8 Power Antenna (provides power to Subaru's antenna booster amp)
9 [NC] {amp remote turn-on signal on Toyota HUs, not Subaru}
10 Illumination+
6-pin power/speaker harness
1 - - 2
3 4 5 6
Code:
1 RR+
2 LR+
3 RR-
4 [NC]
5 Dimmer (Illumination-)
6 LR-
28-pin SWC/aux/mic harness
1 .. 14
15 .. 28
Code:
1 [NC]
2 Reverse Gear
3 Illumination Dimmer Cancel (Bright mode)
4 Mic ? (separate, possibly ground)
5 Mic ? (twisted w/ 19)
6 Ground (not connected to mic)
7-14 [NC]
15 [NC]
16 [NC]
17 VSS
18 [NC]
19 Mic ? (twisted w/ 5)
20 [NC]
21 SWC Audio (Seek, Volume)
22 SWC Mode + Phone
23 SWC Common
24 [NC]
25 Aux enable
26 Aux audio Right
27 Aux audio shield/ground
28 Aux audio Left
1 ... 8
9 ... 16
Code:
4 ?
5 ?
6 Parking brake
7 Camera +6V supply (HU sends power to OEM Camera)
8 Camera Video In
15 Camera Detect (connect this to chassis ground)
16 Shield/ground
The Following 7 Users Say Thank You to xcelir8brz For This Useful Post:
Cornerman (07-01-2012), dangerfield (10-02-2012), Proud of BOXER (07-02-2012), Scooby South (04-13-2013), Thefuzz (07-06-2012), Vlad (10-17-2012), wheelhaus (08-12-2012)
Old 06-29-2012, 11:18 AM   #22
sparks
sparks's Avatar
sparks is offline   Reply With Quote
The Following 2 Users Say Thank You to sparks For This Useful Post:
Cornerman (07-01-2012), SVXdc (07-01-2012)
Old 06-30-2012, 06:28 AM   #23
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
It's about time I weighed in here...
The Beat-Sonic TVK-54 has 24-pin connectors. It will not work with the Fujitsu Ten nav HUs in 2012-up Impreza and Forester, and 2013 BRZ and FR-S.
Originally Posted by SVXdc
The TVK-54 is intended for the OEM Kenwood Navi HU, used in:
  • 2008-2011 Impreza/WRX/STI
  • 2009-2011 and some 2012 Foresters
  • 2010 Exiga
and a similar OEM Kenwood satnav, used in
  • Some 2008-2009 Legacy/Liberty/Outback outside North America
Although the back looks similar, the nav in 2010-2011 Legacy/Liberty/Outback does not have the parking brake signal on its 24-pin socket.
From the above posts, it sounds like the BRZ's nav does use the parking brake signal to disable video display while driving.
However, I seem to recall a 2012 Impreza owner with the Fujitsu Ten nav (model FW602US) saying that grounding the parking brake input did not unlock everything that is disabled while driving.
An easy way to verify is to pull up your brake lever just far enough to light the BRAKE light on the dash. Then have a passenger look for things that are still locked out while you're driving.
We theorized that the FW602US was also using the speed signal (VSS) to detect motion for the lock-out. A simple way to test that is to just unplug the 28-pin harness. You'll lose your microphone and aux input, but you should still be able to test everything else.
I've seen BRZs with model numbers FA601US (here) and FM601US (here). Does the FR-S have the same models?
SVXdc is offline   Reply With Quote
Old 06-30-2012, 06:30 AM   #24
SVXdc
SVXdc's Avatar
The pin-out tables that xcelir8brz posted are for the 2012 Impreza Fujitsu Ten nav, model FW602US, from my NASIOC post here. (I'd appreciate credit and a link)
There are several differences in the BRZ and FR-S:
  • Model number (on front) is FA601US or FM601US (Impreza is FW602US)
  • FR-S and BRZ do have speaker amp remote turn-on (used for the amp for the door speakers)
  • FR-S Does not have power antenna control on the 10-pin harness. BRZ does.
  • Antenna control for the FR-S is on the antenna connector (blue wire on the aftermarket antenna adapter), for the antenna booster amplifier. BRZ does not have that pin on the antenna connector -- uses wire on the 10-pin harness.
Possibly more differences (I haven't seen Subaru's wiring diagrams yet). Does anybody have them they can send me?
And can anyone post pictures of the back, factory harnesses, and the label on the top?
Last edited by SVXdc; 12-23-2012 at 01:59 AM. Reason: corrected to show differeneces between FR-S and BRZ antenna control
The Following User Says Thank You to SVXdc For This Useful Post:
xcelir8brz (06-30-2012)
Old 06-30-2012, 06:52 AM   #25
Sportsguy83
Drives: Limited BRZ
12--34
5678910
Pin 7 is Ground.
Are full phone functions available while driving shorting the ground like this?
Old 06-30-2012, 03:05 PM   #26
xcelir8brz
Yes.
The Following User Says Thank You to xcelir8brz For This Useful Post:
Sportsguy83 (06-30-2012)
Old 06-30-2012, 03:06 PM   #27
xcelir8brz
  • Does have speaker amp remote turn-on (used for the sub amp)
  • Does not have power antenna control on the 10-pin harness
  • Antenna control is on the antenna connector (blue wire on the aftermarket antenna adapter), for the antenna booster amplifier
You've got credit! This helped me out as well and I apologize if this is a repost, just a bit easier for the audience to view.
Old 07-02-2012, 01:31 AM   #28
fmsida
Drives: 2013 DGM BRZ
I grounded the grey wire as mentioned earlier, the movies still played while the parking brake was down, however the screen turned blued as soon as went passed 3 mph. Did I miss something?
fmsida is offline   Reply With Quote
