#127 |
There were a couple of threads on this and it appears the answer is no. Or at least not without substantial changes to the whole rack system.
#128 | |
Thank you for sharing and I hope all is well after your repairs!
#129 | |
Drives: FT 86
| The Following User Says Thank You to Tomking For This Useful Post: | Sarlacc (02-27-2015) |
#130 | |
Drives: FT 86
Toyota Recall Steering issue
#131 |
Interesting. I wonder why just Australia. RHD? But then all the RHD markets would be affected.
#132 | ||
/dev/null
Drives: Uphill
From your early posts it seems the answers are no, no and no. So not the same problem at all, then. Interesting information, though. |
#133 | |
"During normal driving operation, the EPS rotation angle sensor terminals may wear over time. This wear of the connector terminal plating accumulates in debris which may oxidise and become non-conductive. Under this condition if the driver’s knee contacts the knee airbag lower cover, the EPS wire harness routed behind the cover also moves significantly which allows the terminal to contact the debris resulting in electrical contact failure. In this condition, the EPS ECU turns on the warning light and the steering assist is interrupted whilst manual steering is maintained. The loss of power steering assist will increase the steering effort at low speeds which may increase the risk of an accident." Odds are the contacts will wear on all of them but the debris doesn't have a place to collect, oxidize and get pushed into the contacts.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (08-08-2016) |
#134 | |
Huge E85 fan!
Drives: 2016 Scion FRS
| The Following 2 Users Say Thank You to guybo For This Useful Post: | Nickosport (08-09-2016), Tcoat (08-08-2016) |
#135 |
Yeah, saw that. The unique factor here is that knee airbag which I assume is stuffed under the steering column.
#136 |
Power steering died when I was on the Freeway
I have a new 2015 LS and I was actually thinks nag about taking it in because this motor reminded me of a hamster wheel
So this is normal?
#137 |
You may want to ask that question on a Lexus forum. They are not the same unit.
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 04:41 PM |
| power steering | ender2664 | Engine, Exhaust, Transmission | 32 | 03-21-2015 05:16 PM |
| Electronic Power Steering Failure | tjdiz92 | Issues | Warranty | Recalls / TSB | 17 | 06-18-2014 02:34 AM |
| Electronic power steering | Mathewgzlz | Issues | Warranty | Recalls / TSB | 9 | 01-22-2014 02:50 AM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 11:11 AM |
