Looking for 15 mm Spacers (1 set/rear pair)
Looking for a set (2) of 15 mm spacers to install on my rear wheels
#2 |
Drives: subaru
Dont forget you will needed extended studs as well
#3 |
#4 |
Extended studs?
#5 |
Drives: 2013 WRB BRZ 6MT
Nah just get the bolt on type. It's fine as long as your wheels have the spaces on the hub for them and most aftermarket and our OEM wheels do.
I ordered a full set (4) 15mm hubcentric bolt on spacers off Ebay for ~$200 CAD all said and done. I also see some Toronto Kijiji ads advertising the same thing so maybe look there too. I don't think linking Kijiji ads is allowed so I won't but just search spacers in Toronto and they will show up, might save you the aggravation of buying from a US seller on Ebay. |
#6 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
J-Spec Performance in Scarborough has them I believe. Check their Kijiji ads.
@bpennerz
#7 |
Drives: 2015 AOZORA EDITION
i have a 20mm if your intrested
#8 | |
Drives: subaru
#9 |
Well I am running the alloy 5 axis limited edition set of rims - do you know if the bolt ins would be fine for that?
#10 | |
![]() If so, they'll work with the spacers but if not, they won't. |
| pair of 10mm spacers | OMJM | Want-To-Buy Requests | 0 | 09-11-2015 12:32 PM |
| FS: MD. Pair of 20mm H&R bolt on spacers | frslee | Wheels and Tires | 4 | 09-02-2015 10:26 AM |
| FS: 25mm Spacers (pair) | *KID* | Wheels and Tires | 0 | 10-26-2013 11:22 AM |
| Effect of using of spacers for rear-only | mit_peid | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-05-2013 02:06 AM |
| Square Setup w/ Rear Spacers | thejevans | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-11-2013 05:53 PM |
