Old 06-21-2012, 05:22 PM   #127
Dimman
Kuruma Otaku
Dimman's Avatar
How are the AVCS controlled? Is it just based on RPM, or RPM and load?
Because titanium.
Dimman is offline
Old 06-21-2012, 07:04 PM   #128
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Originally Posted by Ben@lachute View Post
This is a stock timing map, but there is more than one...
I am working on understanding which one is used and when!
Ben
Remember this car utilizes variable timing, so ofcourse there will be more than one timing map, if I had to guess I would state three, with the actual timing being an interpolation between two maps at a time depending on driving conditions.
jedibow is offline
Old 06-21-2012, 07:08 PM   #129
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
He's talking about ignition timing.
uspspro is offline
Old 06-21-2012, 07:20 PM   #130
serialk11r
Drives: '06 AM V8V Coupe
Both, just think about it. Low load (high manifold vacuum) + overlap = tons of misfires.
serialk11r is offline
Old 06-21-2012, 07:53 PM   #131
arghx7
Drives: car
It's Subaru software so it is likely an evolution of what you find on say the current software for say an STi. Oversimplifying: there is a basic timing map, and then a map with additional degrees that can be added on top based on a multiplier. The mulitplier is based on long term learning of short term knock sensor activity.
The timing dip is there for a reason, but expecting a bunch of timing advance to add extra torque there safely may be wishful thinking.
Any word on the injection timing logic or the tip-in/wall wetting correction?
arghx7 is offline
Old 06-21-2012, 09:49 PM   #132
jedibow
So am I, there are multiple ignition timing maps
jedibow is offline
Old 06-22-2012, 07:32 AM   #133
Visconti
Drives: 05 STi
Bird is the word
Visconti is offline
Old 06-22-2012, 08:19 AM   #134
Ben@lachute
Drives: Volvo S70 T5
Word
Back on the dyno this morning!
Ben@lachute is offline
Old 06-22-2012, 09:21 AM   #135
Cotnoir
Cotnoir's Avatar
Drives: 2013 BRZ "Sport-Tech"
Cotnoir is offline
Old 06-22-2012, 01:20 PM   #136
Illusive
Drives: 2005 Subaru STi
Originally Posted by Tainen View Post
so the stock map is the one pulling timing and potentially CREATING the evil torque valley. So if we adjust the timing out, the valley probably, or mostly, goes away.
On the contrary, the timing map posted, has the stock tune utilizing more timing in the torque dip.
It seems the engineer's tried to lessen the dip with more ignition timing in the dip, and less timing before and after.
Illusive is offline
Old 06-24-2012, 02:34 AM   #137
Visconti
Drives: 05 STi
There are a bunch of different timing maps in the ECU
It's only a matter of time before someone posts a dynosheet with-out that nasty dip.
-John
Visconti is offline
Old 06-26-2012, 02:02 AM   #138
R/TErnie
Boost Junkie
R/TErnie's Avatar
Drives: Evo 9, 98 Neon R/T
John,
You said that the Pro tuner will be available before the regular end user software? When will the pro tuner software be available? ETA?
I know Hydra is very close to coming up with a solution...
Stages are for Thespians.
R/TErnie is offline
Old 06-26-2012, 02:09 AM   #139
Visconti
Drives: 05 STi
Originally Posted by R/TErnie View Post
John,
I hope Phil stepped up his game on the hydras. Back in the day the AVCS maps were password protected because no one knew how they worked.
No tuning was done today - but the boys at ecutek were working on some datalog going stuff.
We have very close. When I start posting up my own results you can bet it'll be soon.
Hoping this week.
John
Visconti is offline
Old 06-26-2012, 02:19 AM   #140
R/TErnie
Boost Junkie
R/TErnie's Avatar
I've worked on a 2004 WRX with an Ecutek and it was atrocious. Hopefully things have changed since then...as I assume they have... and as you have stated. None-the-less I'm more than a bit cautious.
The Hydra I tuned on an 04STi had some quirks, but the software was functional and intuitive. I really don't like it compared to other ECU's I've tuned, but again... maybe their datalogging sw and tuning sw has changed since then.
I'm interested in the ability to control both the intake and exhaust cams with several additional I/O's... PWM drivers, Digital Inputs (read frequency), as well as a low side drivers. Will the ECU have the ability to PIN/ define in the sw the unused sockets for this purpose?
John,
Are you still affiliated with "The Shop"? I'm not sure of the relationship there and it's not stated in your sig.
Thanks for the response
R/TErnie is offline
FS: BRZ & 86/FR-S pre-release memorabilia bambbrose Miscellaneous 16 11-19-2012 01:38 PM
SOA and BRZ Release lies SkullWorks BRZ First-Gen (2012+) — General Topics 62 05-02-2012 08:49 AM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 02:02 PM
Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin quik1987 Other Vehicles & General Automotive Discussions 0 10-27-2011 03:27 AM
