Old 07-22-2016, 05:07 PM   #1
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Slyphen's BRZ - Luna - STX Build
Vehicle Purchase 5/10/14 from Carter Subaru
Lighting
  • Diode Dynamics Always-On Module
  • Helix Clear sidemaker + White LED Bulb (replace iJDM side marker)
Exterior
  • Beatsonic Shark-Fin Antenna
Interior
  • Clutch assist spring removal
SuspensionPerformance
  • Drift Office Tune (188whp/149wtq on 92 Gas with UEL)
  • Perrin Intake Tube
  • Stoptech Slotted Rotors (F/R)
  • Stoptech SS Brake Line (F/R)
Miscellaneous
  • Fumoto Oil Drain Valve
  • K&N Drop-In Filter
  • Carbon Hydraulic Hood Strut
[/LIST][/INDENT]
slyphen is offline   Reply With Quote
Old 07-22-2016, 05:08 PM   #2
slyphen
Drives: Man
Activity and Maintenance Log:
03/23/15 - Oil Change: Royal Purple 0W20 and filter @ 4252 Miles
05/08/15 - Rear left tire replaced (unfillable puncture) - Discount Tires @ 4844 Miles
07/16/15 - Oil Change: Royal Purple 0W20 and filter @ 7300 Miles
07/16/15 - Cabin Air Filter change: FRAM cabin filter
08/20/15 - Shark-fin Antenna and frameless rear view mirror installed
10/09/15 - New front left strut (Warranty) - Carter Subaru (did not fix issue)
10/09/15 - Wheel Alignment - Carter Subaru @7800 Miles
10/09/15 - New DRL LED module swap (Warranty) - Carter Subaru
10/09/15 - Roof Dented
10/28/15 - Roof panel and windshield replaced by Special Interest Auto Collision
11/20/15 - Oil Change: Royal Purple 0W20 and filter @ 11700 Miles
11/20/15 - Transmission and Differential: Motul Gear 300 75W90 @ 11700 Miles
11/20/15 - Tire Rotation
11/20/15 - K&N Drop-in Filter Change
12/04/15 - NAV Unit Replaced - Carter Subaru (Warranty)
12/04/15 - *Shifter Collar, Bushing, Clamp Snap Boot Dust, Plate Washer replaced - Carter Subaru (Warranty) (did not fix rattle issue)
12/04/15 - Shifter Knob replaced - Carter Subaru (Warranty)
12/04/15 - Rear deck brake light module replaced - Carter Subaru (Warranty)
12/11/15 - Front Strut Mount, Coil Spring Replaced - Carter Subaru (Warranty)
12/11/15 - Wheel Alignment - Carter Subaru @ 12207 Miles
12/11/15 - Gear Shift Lever Assy. Replaced - Carter Subaru (Warranty) (did not fix rattle issue)
01/11/16 - Shifter bushing and O-Ring changed - Carter Subaru (Warranty) (issue relatively fixed)
02/27/16 - Fortune Auto 500 Coilover Installed @ 13940 Miles
02/27/16 - SPL Titanium Rear Lower Camber Arms Installed @ 13940 Miles
03/02/16 - Autocross Custom Alignment (Cam 2.4f/1.5r, Cas 6.5, Toe 0.0f/0.15r) - Chase Race @ 14005 Miles
05/02/16 - Oil Change: Royal Purple 0W20 and filter @ 16650 Miles
07/05/16 - Clutch Assist Spring removed.
07/08/16 - Lady backs into Luna in parking lot. Bumper cover damaged, headlight scratched, driver side fender deformed with paint cracked, driver side side marker damaged.
07/22/16 - New bumper installed(paint/clearcoat), driver side fender reformed(paint/clearcoat), headlight polished. New clear sidemarkers installed.
07/22/16 - Raceseng Slammer Shift Knob installed.
08/17/16 - Front bumper cover clearbra installed Xpel Ultimate - Accutint
08/17/16 - 20% ceramic window tint installed - Accutint
08/20/16 - Oil Change: Royal Purple 0W20 and filter @ 21400 Miles
08/20/16 - Wedssports TC105N w/Bridgestone RE71R mounted for SCCA #7
08/20/16 - raised suspension on all corners by .15"
10/12/16 - Mount and balance Continental Extreme Contact DWS 225/45R17 @ 24360 Miles
10/29/16 - Gruppe-S Unequal length header installed (Drift Office)
10/29/16 - Drift Office Tune (Bob Watanabe)
10/30/16 - Oil Change: Royal Purple 0W20 and filter @ 26380 Miles
10/30/16 - OEM style rear diffuser installed.
01/29/17 - Fortune Auto 500 Coilover Removed.
02/18/17 - KW V3 with 400lbs./in springs installed @ 29930 Miles
02/22/17 - Race Alignment (Cam -3.0f/-2.0r, Cas 7.5, Toe 0.0f/0.15r) - Chase Race @ 30075 Miles
04/08/17 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 31539 Miles
04/08/17 - Transmission and Differential: Motul Gear 300 75W90 @ 31539 Miles
06/30/17 - Race Alignment & Corner Balance (Cam -3.6f/-2.5r, Cas 6.6, Toe 0.0f/0.10r) - Joey Sim @ 38500 Miles
07/06/17 - BFGoodrich G-Force Rival S 1.5 Mounted and Balanced (race setup)
07/23/17 - RX7 crashed into luna. suffered front driver side damage. No frame damage. Damage to driver side fender, bumper cover, bumper, front wheels/tires, front suspension, driver side headlight, side markers.
08/07/17 - Towed to Mark 2 Collision for repair.
08/28/17 - Repair Complete by Mark 2, Installed new KW V3 Suspension, New Front Continental DWS 06 225/45/17.
09/07/17 - Autocross Custom Alignment (Cam 3.4f/2.5r, Cas 6.5, Toe 0.0f/0.15r), Corner Balanced - Chase Race 40755 Miles
09/11/17 - Full Front End Clearbra by Polished Image @ 40800 Miles
09/30/17 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 41037 Miles.
12/09/17 - Hydraulic Hood Strut - SJ part out
12/09/17 - Perrin 2.5" resonated catback exhaust - SJ part out
12/09/17 - Perrin Intake Tube - SJ part out
02/10/18 - Front/Rear Stop Tech Slotted Rotor + Stainless Lines Installed - 44603 Miles
02/10/18 - Front / Rear Ferrodo DS2500 Brake Pads + Motul RBF 600 DOT4 Brake Fluid (Brake and Clutch Fluid Flush) - 44603 Miles
02/10/18 - Motiv High Flow Cat + Perrin Over Pipe Installed - 44603 Miles
02/11/18 - Driver Side Rear Axle CV Joint broke @ 44850 Miles
02/14/18 - Rear Axle Partout x2 (14k Miles) replaced both rear axles - In-Tune Auto (Jason Merritt) @ 44850 Miles
03/15/18 - Autocross Custom Alignment (Cam 3.4f/2.5r, Cas 6.5, Toe 0.0f/0.15r) - Chase Race 44930 Miles
04/29/18 - Replica tS Aero Package (front lip, side skirts, rear side diffuser) Installed @ 46033 Miles
05/27/18 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 47806 Miles
09/19/18 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 53424 Miles
09/21/18 - Endlink Bushing replacement, Front Sway Bar Bushing Lubrication @ 53460 Miles
10/13/18 - Spark Plug and Coil Pack Replacement @ 54634 Miles - Drift Office
11/19/18 - Timing Cover Seal Repair (TSB) @ 57420 Miles - Michael's Subaru of Bellevue
11/19/18 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 57420 Miles - Michael's Subaru of Bellevue
11/26/18 - Exedy OEM Clutch Replacement @ 57539 Miles - Chase Race
11/26/18 - OEM Revised TOB and Bearing Retainer Replacement @ 57539 Miles - Chase Race
11/26/18 - Varus Billet Aluminum Shift Fork and Pivot Installed @ 57539 Miles - Chase Race
11/26/18 - TS Billet Aluminum Cam Plate Installed @ 57539 Miles - Chase Race
03/21/19 - Autocross Custom Alignment (Cam -3.5f/2.7r, Cas 6.5, Toe-in 0.0f/0.15r) @ 60440 Miles - Diftech
04/22/19 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 62710 Miles
08/30/19 - Throwout Bearing Change (OEM Revised) @ 67001 Miles - Diftech
08/31/19 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 67030 Miles
09/14/19 - Transmission Oil Change Motul 300 @ 67120 Miles
02/01/20 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 71034 Miles
08/23/20 - Oil Change: AMSOIL 0W20 + Genuine Subaru Oil Filter @ 75034 Miles
08/23/20 - New Battery Installed
08/23/20 - Returned suspension/exhaust/wheels to stock
09/04/20 - Luna has found a new home, ending this epic chapter and my journey with her. hope to see her again one day.
Old 07-22-2016, 05:08 PM   #3
slyphen
Drives: Man
Trophy Case (Podium Only)
SCCA 2018 Event #7 - NS4 STX - 2nd Place - 68.825/67.536)
2017
SCCA 2017 Event #1 - IST Class - 2nd Place - 58.869/58.505
SCCA 2017 Event #2 - IST Class - 3rd Place - 64.776/62.282
SCCA 2017 Event #3 - IST Class - 2nd Place - 60.911/60.679
SCCA 2017 Event #4 - IST Class - 2nd Place - 69.791/69.642
SCCA 2017 Event #5 - IST Class - 1st Place - 50.878/50.878
SCCA 2017 Event #6 - IST Class - 1st Place - 50.969/50.969 (STR Miata)
SCCA 2017 Event #7 - IST Class - 1st Place - 58.676/58.676 (STX BRZ Scott Engler)
SCCA 2017 Event #8 - IST Class - 2nd Place - 50.735/49.425
SCCA 2017 IST Class Champion
2016
BSCC 2016 Event #3 - Nov Class - 3rd place - 65.626/63.473
BSCC 2016 Event #5 - Nov Class - 2nd place - 59.051/58.103 (AM)
BSCC 2016 Event #5 - Nov Class - 3rd place - 59.493/56.615 (PM)
BSCC 2016 Event #8 - Nov Class - 1st place - 54.942/54.942 (AM)
BSCC 2016 Event #8 - Nov Class - 1st place - 54.526/54.526 (PM)
http://www.conechaser.com/driver/QingRui.(Jim).Zhu
Old 07-22-2016, 05:36 PM   #4
slyphen
Drives: Man
Mod Photos
Exterior
Suspension
Wheels/Tires
Old 07-23-2016, 01:41 AM   #5
Infinity
Drives: 2016 Scion FR-S
Did you modify the SPL rear lower control arms to be STX legal? They have solid bushings.
Infinity is offline   Reply With Quote
The Following User Says Thank You to Infinity For This Useful Post:
whataboutbob (02-02-2017)
Old 07-23-2016, 01:54 AM   #6
e1_griego
e1_griego's Avatar
Drives: Many
Subscribed
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
slyphen (07-23-2016)
Old 07-23-2016, 02:27 PM   #7
slyphen
Drives: Man
Not yet, i'm still running Novice and IST class for the next year or 2. but when the time comes for me to enter STX and compete at National Tour, i will certainly get legal bushings put in.
Old 07-25-2016, 02:02 AM   #8
slyphen
Drives: Man
I love the new shift knob!
Old 08-17-2016, 01:21 AM   #9
slyphen
Drives: Man
Wheels finally showed up!
Old 08-20-2016, 03:36 AM   #10
slyphen
Drives: Man
opticoated, mounted and balanced!!!
Old 10-31-2016, 12:29 AM   #11
slyphen
Drives: Man
2nd gear
3rd gear
4th gear
Old 02-02-2017, 01:07 AM   #12
slyphen
Drives: Man
FA500 has served me well for the novice season. time to step up the game.
The Following User Says Thank You to slyphen For This Useful Post:
FujiwaraTofu86 (02-02-2017)
Old 02-02-2017, 08:52 AM   #13
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
Out of curiosity, why not upgrade your Fortune Auto coil-overs?
-Carlos
Carlos_M is offline   Reply With Quote
Old 02-02-2017, 01:10 PM   #14
slyphen
Drives: Man
-Carlos
I was going to keep using my FA coilovers if no 1 took it off my hands. someone decide to grab them for slightly less than what i asked for, but it was enough for me to curb the cost of the upgrade.
These are 2 way adjustable, and a much better damp range than the 1 way adjustable FA. Half of these also have custom swift springs, while i'm getting the spec and the front swift springs ordered(annie took the front springs and used them on her MCS). On top of all that, i'm also getting setup notes from a multiple time national champion.
FA served me well for novice autocross and daily, but i'm ready to move on to a bit more serious competition.
Carlos_M (02-02-2017)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 10:41 AM
Slyphen's BRZ - Luna slyphen Member's Car Journals 14 06-27-2016 03:58 PM
Slyphen's Phantom slyphen Member's Car Journals 1 06-25-2015 09:32 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 11:14 PM
