#15 |
I had similar issues today in my BRZ which I just got yesterday. I did about a 10 mile/20 minute drive down a freeway this morning and it didn't find any satellites until I slowed down and got on another freeway. I also had it lose the satellites again on a short drive and it didn't find them again until I pulled into my subdivision at very low speed.
Atlanta has a ton of tree lined streets and even freeways with tall trees so I'm hoping it isn't the height of the car and the position of the receiver which is an issue. I did check the signal strength (you can touch the satellite icon) and it had reception from 5 satellites, but nothing strong enough. When I got into the subdivision I did see the strength go up and the nav synced up pretty quickly... I do consider this to be unacceptable, and plan on taking the car to the dealer if there isn't some simple fix to be found. I have a nav system in my 2012 Wrangler and it never has an issue picking up satellites anywhere... |
#16 |
Drives: '13 BRZ Lmtd
Another Nav discussion
More discussion of the Nav issue with some example videos here:
http://www.ft86club.com/forums/showt...526#post267526 The OP to that thread had the dealer replace everything without fixing the problem. |
#17 |
Drives: 2013 DZE/01 (sold for MX5 ND1)
A quick update:
Mine has been working fine for the most part. I haven't had a repeat of it losing the signal for a long period of time, though there are two spots on my commute where it almost always says it loses the signal, but reacquires immediately. In both cases, it only loses the signal in one direction:
#18 | |
#19 | |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
my traffic notifcations doesnt work AT ALL!!! if i'm stuck in traffic I want to see where the traffic is! but nope it keeps saying NO TRAFFIC NOTICATIONS AROUND YOUR AREA! Or some times if I want to go on the MENU shows the MAP/ Find address/ and sometimes else/ MORE... the MORE button is un click able
#attackbydemons #imcomingbackbish
#20 | |
The traffic stuff doesn't seem to work for me either. |
#21 |
Drives: 2013 GBS BRZ Limited 5MT
I just picked up my GBS Limited 2 days ago and drove over 800 miles from NY to Illinois without any GPS issues. Now that it is home though, the nav unit refuses to reliably lock on to satellites. I tried sitting in my driveway with the engine running and the sat lock screen visible and I'm only getting 2 sats (low on the western horizon) and they won't lock (green dots on sky view display). My iPhone locks in immediately. I know from my flying days that there are usually at least 6 sats that should be somewhere overhead at all times. I pulled the following from the FAA site:
"With the baseline satellite constellation, users with a clear view of the sky have a minimum of four satellites in view. It’s more likely that a user would see six to eight satellites." I have to wonder if the head unit doesn't have a complete or accurate satellite position database as there should be more visible satellites. I have to agree with other posts that once moving, the unit has a terrible time trying to lock into satellites. Once it does lock in, it seems fine. Hopefully, Subaru will work on a fix for this as it is annoying to have the nav screen bouncing around. I prefer to turn the display off or leave it on audio. |
#22 |
Drives: BRZ Limited - Silver
Where is the antenna?
Does anyone know if the roof antenna is the sat antenna or just terrestrial? I went from a pioneer nav in my tC and that thing would lock almost instantly... it would also keep navigation going (using what I believe is called dead reckoning) under the tunnels of Boston.
The subaru nav sucks. I sat in my driveway for 3 minutes this morning. It gets a signal, then as soon as a I make a 90 degree turn onto the highway, it's lost for the duration of my 25 minute drive. WTF. I absolutely love this car. But the nav is awful. When it gets a signal, it works well, but I just don't know why it would take more than 30 seconds. Anxious to see Crutchfield's writeup of the internal wiring and such.. may just drop one of the pioneer units in there but I don't want to have to re-install phone mic/usb/aux ports and sat. antenna. -- oh, forgot to add... the nav traffic also does not work. It will say no issues, yet there will be stopped traffic/construction.. you name it. I've used a late model garmin with FM traffic and it actually does work. Last edited by louis; 06-21-2012 at 02:49 PM. Reason: Forgot to add... |
#23 | |
#24 |
BRZ Nav Diagnosis Appointment
I showed the Nav speedo input problem to a service tech from my dealer today, and they just called back to make an appointment for me to leave the car for a day or two for diagnosis. I don't really expect them to fix the Nav unit's problems, but I hope that they can at least help SOA get to the cause of the its issues. I will post an update on what they find out.
#25 | |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
#26 | |
Drives: 2013 BRZ Ltd/Metallic Silver
#27 |
OM NOM NOM NOM
Drives: 2013 Infiniti G37xS Sedan
Hope this thread follows through, my NAV has been pretty terrible in its limited use and the XM cuts out every now and then too. Hope SOA comes up with a fix.
#28 |
You know you want it.
Drives: '13 FR-S
Too bad it can't be ordered without the Navi. A shitty head unit makes it that much harder to justify the price of the BRZ over the FR-S.
| "Car geek" credited with finding child killer. | 1660 | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 08-04-2011 04:11 AM |
