Old 07-20-2016, 01:22 AM   #1
Tal
Tal's Avatar
Drives: Scion FRS 10 Series
CEL
Ok guys. So, I have a small issue. My CEL came on one day and I started to lose power at certain rpms. I went to Toyota and had them diagnose the problem. They came with 2 codes. P219a, and P119f. Since I was running ethanol they told me to just run 93 for a while and clean out the system with some injector cleaner. It has been more then a week now and even though I dont lose power anymore. The CEL keeps coming back with the same codes.
Any ideas on what i can do to stop the ECU from reading the same codes?
10 Series Owner. Love it.
Tal is offline   Reply With Quote
Old 07-20-2016, 01:47 AM   #2
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Are you logging?
tofurun is offline   Reply With Quote
Old 07-20-2016, 02:02 AM   #3
Tal
Tal's Avatar
Originally Posted by tofurun View Post
Are you logging?
I logged with the dashcommand app.
Old 07-20-2016, 12:02 PM   #4
FX86
have you checked under the hood to make sure the engine is still there?
Old 07-20-2016, 12:11 PM   #5
STV3
Señor Member
STV3's Avatar
Dumb question but i have to ask..... You are running a tune for e85 right?
STV3 is offline   Reply With Quote
Old 07-20-2016, 01:41 PM   #6
tofurun
tofurun's Avatar
Post the log?
Old 07-21-2016, 02:22 AM   #7
Tal
Tal's Avatar
Yes, I am tuned. However, at this point in time im running my stock tune.
Old 07-21-2016, 02:27 AM   #8
Tal
Tal's Avatar
Post the log?
Hope that opens up
The Following User Says Thank You to Tal For This Useful Post:
Zeuseidon (07-27-2016)
Old 07-21-2016, 03:17 AM   #9
steve99
Drives: FT86
What mods does your car have intake headers ?
what tune are you using for e85
straight e85 tune or full flex kit or map switch ?
e85 will clean out the system bettercthan 93
your getting those codes as you have either a hardware problem like exhaust intake leak or bad sensor o2 maf or dirty maf from oiled filter. low fuel pressure, leaking injector
or your running incorrect tune for e85
