Old 07-15-2016, 12:44 PM   #43
DAEMANO
Time Traveller
Originally Posted by velvetx View Post
Lets hold off right now regarding the performance packaging being legit (not trying to derail the hype train I am getting a 2017 BRZ and pretty stoked on pricing). However few things we need to know before we invest in the performance package.
New Wheels: Are they lighter or is it just for looks?
Brembo Brakes: Is this the big brake fronts or the cheap brembos?
Sachs Dampeners: Is this even worth it over OEM?
Just saying for that price it seems like we are getting something at a great value but really what are we getting as the company needs to make money?
The tooling for the car is likely paid for or nearly paid for. Mid-cycle refreshes are where all the money is made. That probably plays into the low costs of the performance package as quoted. Sure the prices could go higher at the release date, but the auto press is also quoting the same costs sourced by Subaru.
http://www.caranddriver.com/reviews/...aru-brz-review
Wheels, made to be stronger and have lower offsets to clear the new BBK. They're probably very close to the weight of the standard wheels give or take an inconsequential amount.
Pricing - See below
Brakes - See below
Dampers - same
Performance, Packaged
A new Performance package also is available for 2017 BRZs equipped with the Limited trim level and the manual transmission. An $1195 option, it includes Sachs dampers, Brembo four-piston front calipers with two-pot fixed clampers in back (replacing the standard sliding calipers), bigger 12.8-inch front and 12.4-inch rear brake rotors (up by 1.2 and 1.0 inches), and 0.5-inch-wider wheels (wearing the same tires) to accommodate the larger stoppers. The optional dampers further improved body control through the speedway’s fast corners, and the steering was predictable yet razor sharp. Entering the high-speed braking zone, it was immediately noticeable that the Brembos, with their better pedal feel and reduced fade, were superior to the standard binders. The car still rides on slide-happy Michelin Primacy HP tires, and the brakes quickly overwhelm the available grip, leading to early ABS activation. As before, a BRZ owner heading for the track will want to opt for more serious performance rubber....
Old 07-15-2016, 12:57 PM   #44
velvetx
velvetx's Avatar
Drives: 2015 Honda Civic SI (sold)
Pricing - See below
Brakes - See below
Dampers - same
So do you think we are getting these?
http://www.ft86speedfactory.com/brem...l#.V4kVrfkrKUk
velvetx is offline   Reply With Quote
The Following User Says Thank You to velvetx For This Useful Post:
DAEMANO (07-15-2016)
Old 07-15-2016, 01:00 PM   #45
DAEMANO
Time Traveller
No. It'll likely be some version Brembo offers only to OEMS customized to Toyobaru's specs.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
gramicci101 (07-15-2016), krayzie (07-15-2016)
Old 07-15-2016, 01:00 PM   #46
gramicci101
Off Topic
What are the "cheap Brembos"?
The rotors are the same size as the STI rotors at 326f/316r, which is larger than our current rotors at 294f/290r. The piston sizes are different than the STI, which I assume is to manage brake bias. Will it be as effective as the $3500 Brembo front BBK? Probably not. Will it be better than our current OEM brakes? Very likely.
Old 07-15-2016, 01:07 PM   #47
velvetx
velvetx's Avatar
I would say the "less expensive" brembos are the OEM ones. But you are right definitely better. Maybe the reason for this is because though Toyota has been mum on what they are doing from a manufacturing standpoint the FT86 has to have this same package offered to significantly reduce costs.
Old 07-15-2016, 01:39 PM   #48
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
Well one of the main drawback of the brembos in the PP vs aftermarket is that they will probably have a full iron rotors, where as something aftermarket will have an aluminum hat and iron rotor discs. This cuts down on weight but also increases costs.
Also people comparing the PP brakes to the aftermarket, don't forget you are getting front and rear BBK with the PP with a correct front/rear bias. It's a killer deal, not to mention the wheels and dampers that come with it.
I actually prefer the new base wheels though, the PP wheels are a little strange where the spokes meet the barrel.
goldenfri is offline   Reply With Quote
The Following User Says Thank You to goldenfri For This Useful Post:
Old 07-15-2016, 02:54 PM   #49
Marat
Drives: '15 Ultramarine FR-S
Anyone know if the specs on these brembo calipers is identical to the new STIs calipers (i.e. piston size, rotor diameter/thickness etc)
Marat is offline   Reply With Quote
Old 07-15-2016, 03:38 PM   #50
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Originally Posted by Sport-Tech View Post
PP not till early 2017. Why do they delay the release of the good stuff? Seems to be SOP with car manufacturers a lot of the time. Fiat's doing the same with the new 124 - no Abarth version for the first several months.
That's to ease the burden on the manufacturing side. New process, equipment, traning, etc throwing in too many extra options is begging for more mistakes.
I've been through that a few times now.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 07-15-2016, 04:28 PM   #51
WorldRallyB
Performance Ricer
Drives: 19 WRX, 19 ND2
Originally Posted by dragon1522000 View Post
2017 price as follows
Msrp
Premium 6spd 25495
Limited 6spd 27645
Limited. AT 28745
Yellow series 29695
Performance package 1,195 added to above pricing of premium and limited models yellow series already includes that added price
Thought I'd let the Forum know.. I called my dealership today, confirmed these prices! Placing a order for a 2017 WRB Limited 6spd for $27145 on Monday!
WorldRallyB is offline   Reply With Quote
Old 07-15-2016, 04:38 PM   #52
Irace86
Drives: BRZ + Ducati M796
Originally Posted by CBR600RR View Post
1195 for brembo brakes and different wheels seems a little low.
It does but it isnt really a huge cost difference for Subaru over the stock brakes and rims. I think we are just used to aftermarket prices then trying to sell used or like-new parts online.
Irace86 is offline   Reply With Quote
The Following User Says Thank You to Irace86 For This Useful Post:
CBR600RR (07-18-2016)
Old 07-15-2016, 05:29 PM   #53
Elleteeh
Elleteeh's Avatar
Drives: '17 Subaru BRZ CWP Limited 6AT
Just placed my order today for a white limited today at invoice. Going automatic this time, tired of manual lol. I wonder if this means I'm going to miss out on the PP or not since I thought I saw it was only offered on the manual.
Elleteeh is offline   Reply With Quote
Old 07-15-2016, 05:31 PM   #54
ayau
Drives: Some rust bucket
Do you mean MSRP? Invoice price is below MSRP.
Old 07-15-2016, 05:40 PM   #55
Elleteeh
Elleteeh's Avatar
No, I'm getting it at invoice. Never paying MSRP. Not even for this refresh.
Old 07-15-2016, 05:45 PM   #56
WorldRallyB
Performance Ricer
Have you done your share of reading on the '17s? There is very little incentive to get an auto..
2017 BRZ price in Japan and new 4.2" LCD screen information HappyDriftFriends BRZ First-Gen (2012+) — General Topics 64 07-04-2016 10:36 PM
2017 BRZ or wait for 2018 redesign? Different car around the same price? Icedude1011 BRZ First-Gen (2012+) — General Topics 39 03-30-2016 09:38 PM
2013 Scion FRS Lux Motion Wide Body *PRICE UPDATE* nyczronny Cars for Sale/Trade 6 01-05-2016 02:43 PM
FS: MD. Advan RS 18x8.5 +50 5x114.3 Silver PAIR - PRICE UPDATE frslee Wheels and Tires 5 11-20-2015 10:59 AM
FS:PRICE DROP UPDATE!! SOCAL: 2011 WRX WHEELS 17X8 +53 offset Turboblades Wheels and Tires 5 09-26-2013 04:49 PM
