#1359 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
If I say yes, will that make you think I understand?
#1360 |
Drives: 2015 brz
I been running this about 2 days
#1361 | |
#1362 | |
Drives: UK GT86
.: Stealth 86 :.
#1363 | |
Drives: 2015 brz
#1364 |
So, above 0.0 pressure I should have compensation above 1.0? Can you tell me that much at least? I've modified the table to be more linear. Is this what you are hinting at?
![]() Last edited by KoolBRZ; 07-14-2016 at 02:19 PM. |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | dtek (07-14-2016) |
#1365 |
What can you tell me about this?
@Kodename47, @shaynek is getting a lot of knock under boost at low rpms and I'm trying to help him fix his tune. What can you tell me about modifying this table to prevent knock under boost pressure? It looks like it's getting maximum advance at 0.0 PSI MAP, or, is that the maximum advance PULLED from the total advance? The table properties are undefined, so I haven't a clue whether it's timing added or subtracted from the total. I suspect it could also just be bad petrol, but that's another step to try later.
| The Following User Says Thank You to KoolBRZ For This Useful Post: | shaynek (07-14-2016) |
#1366 | ||
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | dtek (07-14-2016) |
#1367 | |
Drives: 86 A00I
@KoolBRZ thanks, will check out your attachment and look to future releases. No worries about going off the radar, I didn't have much time for tinkering so was watching your updates from afar. |
#1368 | |
Drives: BRZ Limited; GR86
#1369 | |
Just sent @dtek a PM
#1370 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | KoolBRZ (07-19-2016) |
#1371 |
Drives: 2015 86 GTS
Hi guys,
2 weeks on...... Stock D00G car running Wayno's Stg 1 98 v107.2 tune. Fuel - BP Ultimate 98 2 Logs attached: http://datazap.me/u/fibble/oft-stage...o?log=0&data=1 Note: ignore FLKC due to problems with OFT. Trims still look a little out and AFR a little rich. MAF scaling required? Thoughts on whether there's still work to be done (timing and fuelling) or is this acceptable variance for Stg 1 tune on an FA20? Thx |
#1372 |
Drives: 2015 Halo White FRS
First post on the forum.
So I'm running stage 2 uel 91 octane with 92 oct. 1320 headers the flex joints are gone. I wasn't going below 1 iam until the other day, and i wanted to get the differece in the command afr vs afr fixed up, but now I'm getting a lot of random small knock. i took some long logs. If someone can check them out that would be great. I haven't been able to do a couple of 3rd gear pulls, but will post a couple of logs as soon as i do. sorry still pretty new to tuning. As far as I can tell I have no exhaust leaks, but the afrs seemed way off and I don't want to damage my car. http://www.datazap.me/u/evlorin86/ss...l?log=0&data=1 Last edited by ELorinD86; 07-23-2016 at 12:18 AM. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
