Old 07-10-2016, 12:33 PM   #1
FRSure
Drives: Toyota
Moisture Build up
Upon washing car, there is moisture between the window seals.
Is this normal?
http://imgur.com/a/QQeXl
Thank you
FRSure is offline   Reply With Quote
Old 07-10-2016, 12:46 PM   #2
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Looks similar to what I see on mine when washing.
Subaru STI :
The Following User Says Thank You to Kimsey47 For This Useful Post:
FRSBRZGT86FAN (07-14-2016)
Old 07-10-2016, 03:05 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yes. It's normal for any car with frameless windows. You're blasting water at super-high pressure at a gasket that is meant to protect from rain and wind.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Old 07-10-2016, 04:04 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
IBTITP
In before the "it's totalled" post
guybo is offline   Reply With Quote
Old 07-14-2016, 01:20 AM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Is this normal?
Thank you
Totally normal, important note is after washing don't roll the windows down for a day or two, otherwise you'll get water spots and streaking all over the window, water likes to get trapped in the felt seals. Also you can go over the area with the moisture in the picture with rubbing alcohol and a towel to clean it.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
anytimeparking (07-14-2016)
Valenti Red Lens Tail Light-moisture build-up Agent 86 Cosmetic Modification (Interior/Exterior/Lighting) 86 12-21-2015 01:22 PM
Moisture?? Cacophony Issues | Warranty | Recalls / TSB 12 11-21-2015 09:48 PM
Damp rid, condensation and moisture radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 08-28-2014 12:21 AM
Moisture in taillights Mikegraves777 Issues | Warranty | Recalls / TSB 21 03-19-2013 03:59 PM
Moisture in lights Sileighty_guru BRZ First-Gen (2012+) — General Topics 12 08-30-2012 10:22 PM
