| Software Tuning Discuss all software tuning topics. |
Drives: FRS
Open flash issue
Open flash tune: I haven been running corn fuel for approx 3000 miles an never had a problem. Two weeks ago I switch back my tune to the original for my free oil change at the dealer. I immediately went back to corn fuel and stage 2 EL tune but a couple day after the traction control light and check engine light came on. I drove the car for a couple of days and at times the car would lose power...I tuned the car back to the original time and both lights went away. I am hesitant of going back to E85 but sure miss the power. Is a 2015 with only 11k miles. Any thoughts?thx
#2 |
Drives: frs
What codes threw?
#3 |
Drives: FRS
Not sure what you mean...just the traction control and check engine lights came on and once loss power as I was on first gear. Got concern thinking it wasn't related to the open flash and reading articles of having to open the motor to address this issue I then decided to flash it back to the original tune to be able to take it to the dealer and when I concluded with the tune I realized both lights when off. Sent from my iPhone using Tapatalk |
#4 |
Drives: frs
Open flash tablet can read/clear codes, if you can read them, then report here for more help. Without them its just guessing
| The Following User Says Thank You to Teseo For This Useful Post: | MrFisty (07-04-2016) |
#5 |
Drives: 2017 BRZ
Any codes?
Anything plugged into the odb port when this happened? I had a similar issue with my 86Nanny plugged in, turned out to be a weird/bad batch of ODB connectors that made intermittent connection - every time it lost connection and regained it, it would try to handshake and sent the ECU into fits. Fixed the connector and no issues since. I should add, support was awesome -it could be anything not quite properly seated on the ODB causing this. Also, the code is important, just in case it's something else. |
| The Following User Says Thank You to cjd For This Useful Post: | Beastronix (07-05-2016) |
#6 | |
Drives: FT86
Use your OFT (under diagnistics i think) to read out the check engine light (CEL) code is will be something like Pxxxx or Uxxxx. if you post up what the codes are we might be able to help |
#7 |
Huge E85 fan!
Drives: 2016 Scion FRS
A check engine light always has a code associated with it that gives you an idea of what the problem is (well, it gives you a place to start looking for a prob anyway). An OBD2 port reader or your OFT can read what this code is
#8 |
Drives: 2013 FRS Asphalt
Post the codes. Also a log containing your fuel trims would be helpful.
#9 |
Why did you flash back to stock for an oil change? They aren't going to plug into the OBD port for that, and even if they did they wouldn't have the tools at the dealership to compare the ROM on the computer to a stock ROM.
#10 | |
Drives: FRS
Are you serious. I had no idea. I was under the impression they would find out. And the car was running incredible....I will flash it back in a couple of day when I fill up e85 and see how it goes. Sent from my iPhone using Tapatalk |
#11 |
Drives: FRS
#12 | |
| The Following User Says Thank You to phrosty For This Useful Post: | wparsons (07-05-2016) |
#13 | ||
Drives: FT86
With OFT or Tactrix you can flash back a 100% stock rom and CVN will match the stock rom calid CVN. As stated its extremly unlikely thet they will check the CVN at standard service. as they have to look up the value of stock rom CVN, but its possible. They would only usually check CVN if you had problems or maybe other obvious mods . They usually plug in their diagnostic tool at any service to check for stored codes also not all fault codes the CEL light. |
#14 |
Drives: FRS
Thank you sir. You da man
| My experience with Shiv & his products at Open Flash Tablet / Open Flash Header | TouchMyHonda | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 10-23-2015 09:57 AM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| Open Flash Tablet template issue | BuBlake | Software Tuning | 3 | 10-13-2014 07:47 PM |
