| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
I was at the track a couple of weeks ago and was helping someone change out his brake pads. He had been using 70 lbs-ft for his lug nuts and they were SCARY loose. There's probably a fairly wide range of safe values, just don't go too low (or high).
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | Tristor (04-16-2018) |
#30 |
Drives: SWP BRZ
I know bit also heard some people breaking stud torquing 89 ft lb.
#31 |
Yeah I think the studs on these cars are just a weak point. I've been ok so far using 90 lbs-ft, but will probably change studs at the end of the year.
#32 |
Drives: SWP BRZ
#33 |
Drives: 15 BRZ LTD, 05 FXT
No issues using Muteki lugs to 85 ft lbs for a year and change here.
I ran the same lugs and torque values on my 05 Forester XT for 4 years/80k miles before switching to ARP hardware, because I figured it was time.
#34 |
Drives: '14 DGM BRZ Limited 6MT
Extended muteki lugs snapped on two studs on my passenger front hub and then snapped one stud on the front driver hub. Replaced stock studs to APRs and hadn't had a issue since. Stock studs are garbage.
| The Following User Says Thank You to Ayoitszritchie For This Useful Post: | Tristor (04-16-2018) |
#35 |
So the stock studs failed, you happened to be using Muteki lugs, and since switching to ARP you've been golden, right?
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Tristor (04-16-2018) |
#36 |
Drives: 2015 halo white fr-s
I cant seem to find the info on these.
https://www.rallysportdirect.com/par...s-35mm-12x1-25 Anyone know if they have are rated to something other than stock ft-lbs? |
#37 | |
Drives: FRS
| The Following User Says Thank You to 8R6 For This Useful Post: | p1l0t (09-29-2018) |
#38 |
Ok so whatever the manual says should be good then?
| The FRS torque curve | smbrm | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-30-2016 04:10 PM |
| Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com | Josh@FullyBolted.com | Wheels and Tires | 1 | 06-25-2012 02:04 PM |
| What's the reason for Torque dip in BRZ Dyno ? | yuli8466 | Engine, Exhaust, Transmission | 82 | 06-23-2012 07:06 PM |
| Calling all wheel nuts. | Staticfrost | AUSTRALIA | 90 | 06-13-2012 09:33 AM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
