Old 06-27-2016, 04:05 PM   #351
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Yeah without a 200 shot of nitrous I don't see it.
Originally Posted by DustinS View Post
I don't ever expect to see it out of their set-up either. Especially not with the supercharger in the way. I suspect they have a lot to learn in the Twin World, They seem more attuned to V8 stuff, and some of the comments have me concerned at even that.
They'd be pushing it to get 750-800 out of the fa20 on boost, then a 200 shot might get them there, maybe that's what they're considering?
Jaden
Jaden is offline   Reply With Quote
Old 06-27-2016, 04:06 PM   #352
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by Jaden View Post
Even 666 is pretty insane when you think about it..
that's over 300hp per litre...lol...
Jaden
its pretty nuts lol. im geared towards drag racing so lag doesn't concern me much. its definitely laggy, but when it hits, it hits hard. realistically 750whp would be a solid end goal for me. i think i can hit that with 35 ish psi, but we will see. for highway pulls, motec rolling launch makes the lag a non-issue haha
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
DustinS (06-27-2016)
Old 06-27-2016, 04:07 PM   #353
spitfire481
Drives: 2JZ FRS
Jaden
do you think the blower would become a restriction once you get past a certain amount of volume/flow from a turbo that large? like a bottle neck holding it back?
MoTeC
Build Thread
@spitfire481
Old 06-27-2016, 04:09 PM   #354
Jaden
Road-hole
yep...
That's the beauty of a compound boost setup. You can use those big laggy turbos but still have the low end power and torque, you just sacrifice some top end power.
Actually I hate saying that because really you aren't sacrificing top end power. You just don't have the top end power that the same sized turbo used alone will net you. IOW, you have to use a larger turbo to get the same top end power.
Jaden
Old 06-27-2016, 04:09 PM   #355
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Or I ditch the Supercharger and put that money towards Motec and shoot for 500s on a GTX3076 with a solid ECU that will support much more later on.
Edit: I would assume the bottleneck would be not being able to turn the pressure from the turbo up due to the compounding. The turbo needs to flow enough air at around 10-15psi for your total power numbers.
Old 06-27-2016, 04:12 PM   #356
Jaden
Road-hole
With PD it shouldn't.
The only problem you can get is blow by because the seals can't handle the excess pressure.
So you can end up with lower overall pressure in the cylinder and you reduce the duty life of the seals on the S/C.
Having a slightly larger s/c can reduce the blow by that you can get with a smaller s/c.
however, in a compound setup flow and restriction is all about the lead in booster.
Air flow is all about the device pulling air from the atmosphere, the s/c only takes what air it gets and compresses it at the p/r it's set to. Not necessarily the s/c, whatever the second compressing device is.
In a compound turbo setup, you'll often see a relatively small turbo as the secondary device because it spools much faster and all it has to do for the higher boost is compress the incoming air charge at whatever p/r you need from it(i.e. you don't have to worry at all about what it flows), but it's infinitely more complex to control than a turbo feeding into a PD S/C.
Jaden
The Following User Says Thank You to Jaden For This Useful Post:
Old 06-27-2016, 06:00 PM   #357
DustinS
DustinS's Avatar
From the looks of it, I would have to almost completely swap out my current turbo kit. Which got pricey when I started looking, that was counting in the fact I would do my best to do all the welding.
Edit: The Company I was talking to is suggesting a Borg Warner Twin Scroll with the SPS 335 Blower.
Old 06-29-2016, 04:06 PM   #358
DustinS
DustinS's Avatar
Last weekend this happened and forgot to post it:
I also received my Downpipe parts in. Someone posted a concerning picture about the exhaust side of the turbo, might not work. I really hope it fits up though.
Image Posted of Exhaust Housing:
There will also be a pretty big change happening to the car over the next few weeks. Kind of excited, yet hesitant at the same time.
Old 07-05-2016, 02:40 PM   #359
DustinS
DustinS's Avatar
Well. I made the switch to ECUtek today (well I ordered it today). I have outgrown the OFT for the most part. Instead of upgrading to OFT Flex-Fuel Kit and having to switch to ECUtek when I upgrade the turbo, I figured it was easier to just switch now.
Moto-East Ecutek Tune
Moto-East Flex Fuel
DW300 Pump
ID1000s
Grimm Speed Boost Control
The Wait is going to kill me.
The Following User Says Thank You to DustinS For This Useful Post:
D_Thissen (07-05-2016)
Old 07-06-2016, 05:42 PM   #360
DustinS
DustinS's Avatar
Went for a good drive last night heading to a friends house. At ~208F Oil Pressure was staying at 50psi from 4k RPM on up and would start to drop every so slightly when getting close to 6k. I Did my best to keep it under 5k from there on out, which wasn't near as fun.
I also double checked with Moto-East to make sure everything was in stock as I meant to do that yesterday before I ordered. They re-assured me that everything was in stock, and it would go out tomorrow. A little bit of a bummer as I was hoping to have it by Friday (even paid extra for three day select) and have the weekend to install the injectors and pump. Such is life. I can deal with 280whp for a little longer.
Old 07-11-2016, 11:49 AM   #361
DustinS
DustinS's Avatar
Well it seems my package is out for delivery. Update when I run home for lunch.
ECUtek by Dustin[Smith], on Flickr
Old 07-12-2016, 03:11 PM   #362
DustinS
DustinS's Avatar
Interesting turn of event. Package #2 was shipped UPS Ground. So Paid for UPS 3-Day select. Package #1 Arrives USPS Priority 3-Day, Package #2 UPS Ground. Glad packages are here. Hoping to install the pump today possibly. Pictures to come.
Well. Seems there is a third package. The one with the Flex-Fuel. Should hopefully be here tomorrow. I still have to get spacers for the ID1000s as I figured they would come with the injectors (which they don't). Need 8mm spacers with longer bolts. Spencer Fabrications sells some, but they are not available right now.
Old 07-14-2016, 11:54 AM   #363
DustinS
DustinS's Avatar
Fuel Pump installed last night. I was expecting it to be a lot worst with how people were talking about it. It was a piece of cake compared to my Saab. Everything seems to be running great. Need to run and get some spacers for the Injectors. Anyone know if they need to be metal to ground the fuel rail? or is a high temp plastic spacer okay?
I contacted Moto-East about the Flex-Fuel Kit that seems to have been missing in the mail. Few hours later I get a tracking update that it had been received by the USPS. Seems it may have fell off the cart or was forgotten. Although a bummer, I have worked in shipping and know it happens. Happy to report the Flex-Fuel kit is getting regular updates from USPS and should be here Saturday.
Old 07-14-2016, 02:16 PM   #364
spitfire481
Drives: 2JZ FRS
I have been using half inch nylon spacers for well over a year. no issues
MoTeC
Build Thread
@spitfire481
DustinS (07-14-2016)
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 11:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 12:43 PM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 06:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 01:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 03:50 PM
