Old 06-20-2012, 12:34 PM   #113
Visconti
Drives: 05 STi
Originally Posted by Boosted2.0 View Post
Still waiting. I also looked, and I actually don't see a target A/F ratio table....
I would more than glad to show you everything in person when I visit Texas in a few weeks.
John
Visconti is offline
Old 06-20-2012, 01:35 PM   #114
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
John
Sounds like a plan! Any idea what day you might be able to stop by?
Boosted2.0 is offline
Old 06-20-2012, 01:46 PM   #115
Visconti
Drives: 05 STi
Not 100% sure..
Still planning trip..
Visconti is offline
Old 06-20-2012, 04:46 PM   #116
serialk11r
Drives: '06 AM V8V Coupe
10.9 jesus, that makes my eyes bleed.
serialk11r is offline
Old 06-20-2012, 05:04 PM   #117
Boosted2.0
Boosted2.0's Avatar
Thats a factory Toyota tune for you. They like em rich and safe.
Old 06-20-2012, 05:15 PM   #118
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Toyota likes their tunes like I likes my womens!
Hawaiian is offline
The Following 3 Users Say Thank You to Hawaiian For This Useful Post:
civicdrivr (06-21-2012), EsoBOFH (07-04-2012), Mr.Jay (06-21-2012)
Old 06-20-2012, 10:22 PM   #119
arghx7
Drives: car
11:1 is normal, even on a nonturbo engine. They have to keep the cat from overheating at high rpm. Engines with more expensive components can handle higher heat or can reduce exhaust temperatures. This is a $25,000 car. It's not going to use expensive materials, expensive engine architecture, and expensive control strategies.
target AFR has already been logged with an OBD scantool, see top graph. Nobody's logged open/closed loop yet and posted it--a generic scantool can actually read it if set up properly. You also can look at estimated catalyst temperature with a general scantool. Nobody's posted it yet, but I suspect it's around 950C at the limit. If it gets hotter than that, the catalyst will prematurely age. It's not something an owner would notice but it affects in-use emissions testing from the EPA.
arghx7 is offline
Old 06-20-2012, 11:51 PM   #120
kanundrum
Drives: 2013 Whiteout FR-S
Random just noticed your in Norwalk. I will be there for work in July Carry on!
kanundrum is offline
Old 06-21-2012, 12:22 AM   #121
Illusive
Drives: 2005 Subaru STi
Not 100% sure..
Interesting that they're running more ignition timing in the torque dip from 3600-4000, and less in 3200 & 4400-4600 to lower the spike.
Is that the stock map or have you already bumped up ignition timing to try to take the dip out?
Also noticed the map changes to 400 rpm break points in the torque dip from 3200-4400.
Illusive is offline
Old 06-21-2012, 12:23 AM   #122
Do Boy
Turbo FR-S
Do Boy's Avatar
Send a message via ICQ to Do Boy Send a message via AIM to Do Boy Send a message via MSN to Do Boy Send a message via Yahoo to Do Boy
What he said! I would also like to know if those pics are the stock or a modified map?
Do Boy is offline
Old 06-21-2012, 01:03 AM   #123
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
If you look at my log data this appears to be the stock map, running load along the 0.70 column, and the torque dip happens right as the map is pulling timing. I live at 5500 feet above sea level which is why my car follows the lower load value ( I figured I would answer because I know somebody would ask). At sea level you would progress further along the load axis and it would pull even more timing.
jedibow is offline
Old 06-21-2012, 04:48 PM   #124
Ben@lachute
Drives: Volvo S70 T5
Hey Guys,
My Name is Ben Dagenais, I work at Lachute Performance and my prior job was Tech support for EcuTeK for 8 years.
The work I am doing at the moment is simple but takes ages. I have to confirm all the different maps present in the ECU (maps needed) so that when you present your car to a tuner... he will know that the parameters available for tuning work and are reliable.
I have not started to tune for power as I don't have the understanding of all systems yet.
I will get you some screen shots later tonight!
Ben
Ben@lachute is offline
Old 06-21-2012, 04:49 PM   #125
Ben@lachute
This is a stock timing map, but there is more than one...
I am working on understanding which one is used and when!
Ben
Old 06-21-2012, 04:52 PM   #126
Tainen
Drives: First SWP BRZ-L
so the stock map is the one pulling timing and potentially CREATING the evil torque valley. So if we adjust the timing out, the valley probably, or mostly, goes away.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline
FS: BRZ & 86/FR-S pre-release memorabilia bambbrose Miscellaneous 16 11-19-2012 01:38 PM
SOA and BRZ Release lies SkullWorks BRZ First-Gen (2012+) — General Topics 62 05-02-2012 08:49 AM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 02:02 PM
Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin quik1987 Other Vehicles & General Automotive Discussions 0 10-27-2011 03:27 AM
