#113 |
#114 |
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
#115 |
#117 |
#118 |
That guy
Drives: Ultramarine mt FR-S
| The Following 3 Users Say Thank You to Hawaiian For This Useful Post: |
#119 |
Drives: car
11:1 is normal, even on a nonturbo engine. They have to keep the cat from overheating at high rpm. Engines with more expensive components can handle higher heat or can reduce exhaust temperatures. This is a $25,000 car. It's not going to use expensive materials, expensive engine architecture, and expensive control strategies.
target AFR has already been logged with an OBD scantool, see top graph. Nobody's logged open/closed loop yet and posted it--a generic scantool can actually read it if set up properly. You also can look at estimated catalyst temperature with a general scantool. Nobody's posted it yet, but I suspect it's around 950C at the limit. If it gets hotter than that, the catalyst will prematurely age. It's not something an owner would notice but it affects in-use emissions testing from the EPA. |
#120 |
Drives: 2013 Whiteout FR-S
Random just noticed your in Norwalk. I will be there for work in July
Carry on!
#121 |
Drives: 2005 Subaru STi
Interesting that they're running more ignition timing in the torque dip from 3600-4000, and less in 3200 & 4400-4600 to lower the spike.
Is that the stock map or have you already bumped up ignition timing to try to take the dip out? Also noticed the map changes to 400 rpm break points in the torque dip from 3200-4400. |
#122 |
Turbo FR-S
What he said! I would also like to know if those pics are the stock or a modified map?
#123 | |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
#124 |
Drives: Volvo S70 T5
Hey Guys,
My Name is Ben Dagenais, I work at Lachute Performance and my prior job was Tech support for EcuTeK for 8 years. The work I am doing at the moment is simple but takes ages. I have to confirm all the different maps present in the ECU (maps needed) so that when you present your car to a tuner... he will know that the parameters available for tuning work and are reliable. I have not started to tune for power as I don't have the understanding of all systems yet. I will get you some screen shots later tonight! Ben |
#125 | |
This is a stock timing map, but there is more than one...
I am working on understanding which one is used and when! Ben Quote:
#126 |
Drives: First SWP BRZ-L
so the stock map is the one pulling timing and potentially CREATING the evil torque valley. So if we adjust the timing out, the valley probably, or mostly, goes away.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
| FS: BRZ & 86/FR-S pre-release memorabilia | bambbrose | Miscellaneous | 16 | 11-19-2012 01:38 PM |
| SOA and BRZ Release lies | SkullWorks | BRZ First-Gen (2012+) — General Topics | 62 | 05-02-2012 08:49 AM |
| Release Series | rL-gT | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 01-18-2012 02:02 PM |
| Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin | quik1987 | Other Vehicles & General Automotive Discussions | 0 | 10-27-2011 03:27 AM |
