Old 06-20-2016, 02:00 AM   #1
Mattstermh
Drives: '13 FR-S A/T - Stock
Buying with high miles
Buying with 50k, what should I look out for versus buying one with 20k?
Mattstermh is offline   Reply With Quote
Old 06-20-2016, 02:22 AM   #2
Celica00
Celica00's Avatar
Drives: 86
It's a Toyota/Subaru. If it's been even a little bit taken care of, there shouldn't be any issues that wouldn't be there at 20k. If there is something when you test drive, I'd just hold out and put a few more hundred dollars in for a lower mileage or better taken care of FRS/BRZ
Celica00 is offline   Reply With Quote
Old 06-20-2016, 05:05 AM   #3
About the same things.
The higher mileage one may be closer to needing new tires and new brake pads.
Cole (06-20-2016)
Old 06-20-2016, 05:18 AM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
You call 50k high? Piff add 100k then come back and ask.
The Following 6 Users Say Thank You to Mr.ac For This Useful Post:
@Art_Mighty (06-20-2016), funwheeldrive (06-22-2016), FX86 (06-21-2016), S84kam (06-20-2016), Scenic Driver (06-20-2016), soulreapersteve (06-21-2016)
Old 06-20-2016, 06:09 AM   #5
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It's not a hand built (falling apart) Aston
Old 06-20-2016, 09:20 AM   #6
DasFrs
Drives: 2013 Firestorm Red FRS
Maintenance and condition.
Check carfax history, look for any red flags.
50k car was most likely a daily driver, including in winter time (exceptions apply, assume the worst). If that bothers you at all, ask if it was driven in winter.
If its a short term car and you're going to sell it within 3 years, lower miles will help you sell the car easier. However, if its a short term car, I wouldn't recommend even buying it to begin with.
Since these cars aren't old, there really isn't much to look for other than owner abuse. And thats easy to spot with any car.
DasFrs is offline   Reply With Quote
The Following User Says Thank You to DasFrs For This Useful Post:
Kincaid (06-21-2016)
Old 06-20-2016, 09:57 AM   #7
Mattstermh
Thanks for the reply. I'm a young guy and only purchased one other car. I'm not positive I know how to spot owner abuse other than how the interior looks, feels and smells.
Old 06-20-2016, 10:23 AM   #8
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Have a pre purchase inspection done by someone that you trust
Scenic Driver is offline   Reply With Quote
The Following 3 Users Say Thank You to Scenic Driver For This Useful Post:
Dadhawk (06-20-2016), soulreapersteve (06-21-2016), Tcoat (06-20-2016)
Old 06-20-2016, 10:27 AM   #9
Mattstermh
I'm having someone get the car for me, the car is certified pre owned. It was driven 14,000 miles in 8 months.
Old 06-20-2016, 10:38 AM   #10
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Certified PreOwned doesn't mean much these days. Check the actual requirements of a CPO designation. I know that Audi will CPO a car even if it has a carfax history.
CPO mostly means you are buying additional warranty which is good, but doesn't necessarily insure that your car is perfect.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
The Following 3 Users Say Thank You to Braces For This Useful Post:
soulreapersteve (06-21-2016), strat61caster (06-21-2016), Tcoat (06-20-2016)
Old 06-20-2016, 10:44 AM   #11
Signs of "abuse" can be tricky. My car looks like the front bumper was hit by several shot gun blasts, there is a big chunk of the splash pan under the rad missing, the engine compartment looks like I left the hood open in a dust storm and I have little nicks all over the place from highway debris. To look at it you may say "oh now that is an abused car" but the reality is that this is all just signs of heavy highway use and the car is probably one of the least beat on found on this forum. About 98% of my driving is straight line highway with the cruise on, I have 40 years of MT experience and it has probably only seen red line about half a dozen times. All maintenance has been done by the dealer (they are a good one) and I have not had one of the common "issues" that we see so often.
Meanwhile their are cars that look pristine but have had the living shit kicked out of them and are lucky if half the required maintenance was ever done or if done was even remotely done the right way.
The moral of the story is that it is very hard to tell if a car has been beat on. If you can get info on the previous owner it can help.
This is the best way to go ^^^^^
86kahl (06-20-2016), soulreapersteve (06-21-2016)
Old 06-20-2016, 10:52 AM   #12
I regularly buy cars with between 50k and 100K miles on them and have not had any non-maintenance issues for the most part any more than you would if you had bought the car new. Most modern cars need very little break/fix service within their first 150,000 miles in my experience, if they are well maintained.
If you are buying at 50K, it should still be under the 60,000 mile/60 month drivetrain warranty so there is some minimal protection there.
In general though, the best advice is to get a mechanic to do a check on it. Most likely it will need tires/brakes. Also, you are coming up on the 60K service which can be expensive since it includes plugs.
Old 06-20-2016, 11:02 AM   #13
toeout
Transmission will shift a LOT better at 50K than 20K, so that's definitely a bonus.
toeout is offline   Reply With Quote
Old 06-20-2016, 11:19 AM   #14
Braeden
Something you should always check when buying used for proper documentation and maintenance logs proving the previous owner has taken care of it throughly. Good luck on your purchase!
Braeden is offline   Reply With Quote
The Following User Says Thank You to Braeden For This Useful Post:
Tcoat (06-20-2016)
FS: 1000 miles used Berk Technology Front Pipe with High Flow Cat, For both AT/Manual Eric_FRS Engine, Exhaust, Bolt-Ons 0 02-17-2016 02:44 PM
GTR pulled a High 8 seconds in 1/4 miles Whitigir Other Vehicles & General Automotive Discussions 21 06-18-2013 02:26 PM
200 miles too high?? mwy23 BRZ First-Gen (2012+) — General Topics 36 05-05-2013 09:34 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 01:32 PM
